Like Tree6Likes
Old 12-10-2012, 06:46 PM   #6556
esckalayd's Avatar
Originally Posted by triple7s View Post
Hey guys, I just started building my pro kit. In step 2, the glued brake pad set says to have the round holes oriented on top and oval on the bottom with fiber pads facing together.
The problem is one pad must have been glued on the wrong side because to face the fiber side together the hole are opposite. Should I mount them as is with 1 round and 1 oval on top and bottom or just get another set?
You should be fine, but an FYI, the pro kit should have came with the new efficient brakes. If not, go buy the new efficient brake pads which are already pre-glued and have the small spring to place in between the brake pads:
http://www.teamxray.com/teamxray/pro...p?prod_id=4189
see the note, hole orientation does not matter
Anthony Schimizzi AKA ~The Rookie~
| Serpent America - DeSoto Racing |
esckalayd is offline   Reply With Quote
Old 12-10-2012, 07:53 PM   #6557
Yes it came with the efficient brakes. The manual doesn't have the orientation note. Do these pads require longer screws?
Thanks again.
triple7s is offline   Reply With Quote
Old 12-10-2012, 08:27 PM   #6558
esckalayd's Avatar
Thanks again.
I believe the normal brakes use an M3x12, you will be ok with these screws but they obviously wont thread all they way to the edge of the bulkhead. If u have an M3x14 use that, if not, you will be ok with the M3x12. Orientation doesn't matter for the efficient brake pads. Put the old ones aside and install the new ones.
Old 12-11-2012, 05:29 PM   #6559
shakey78's Avatar
Quick question The NT1 2011 car, Am i able to use 2012 parts and is the 2011 model upgradable to the 2012 spec car?
Whats can i upgrade and what can't i upgrade??
Im happy with the 2011 but just wanted to know so when i order options i know they will fit.
www.neoplexsigns.com.au
shakey78 is offline   Reply With Quote
Old 12-11-2012, 06:08 PM   #6560
esckalayd's Avatar
Yes the model is upgradable to the '12. Everything from the '12 you can use on the '11. The major changes are the chassis, lower CG and top plate. Everything else is pretty much the same. Some upgrades i would definitely grab are the new brakes and some lightweight drive train parts if you don't already have them
Old 12-11-2012, 07:08 PM   #6561
shakey78's Avatar
Smile
Sweet thats what I thought thanks for that esckalayd
Old 12-12-2012, 01:12 AM   #6562
djiewie's Avatar
What are the benefits of the new brakes?? Haven`t read anything about them.
djiewie is offline   Reply With Quote
Old 12-12-2012, 02:51 AM   #6563
HHH
HHH's Avatar
Previous brake was great, the new brake is excellent. Literally no fade under heavy use circumstances. More material for longer life, and a spring to keep the disk and pad separated when not braking. Also, no assembly and glue required.
HHH is offline   Reply With Quote
Old 12-12-2012, 09:40 AM   #6564
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
like this on my nt1
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 12-12-2012, 12:37 PM   #6565
BardSmith's Avatar
Trader Rating: 62 (98%+)
Default NT1 For Sale
NT1 For Sale here....
http://www.rctech.net/forum/r-c-item...or-extras.html
"Bard"
On-Road Only!
BardSmith is offline   Reply With Quote
Old 12-12-2012, 12:38 PM   #6566
esckalayd's Avatar
A big +1 for not having to glue the pads and getting super glue or CA glue on your fingers.
Old 12-14-2012, 05:41 PM   #6567
Default Anti-Roll Bar
Is their other advantages of using the optional Anti-Roll Bar over the stock wire one besides adjustability?
Old 12-15-2012, 11:56 AM   #6568
esckalayd's Avatar
Quick adjust ability is the only benefit. It is interesting that the pro kit comes with this rear anti-roll bar since no pro uses it (that i have seen). Most of the guys prefer the consistency of the wire bar. Even with the upgraded one, laid flat (0 degrees) it gives the car more steering than a wire bar because it is a stiffer system over the 2.2mm wire bar. Not to mention it is tweaked more than a simple wire, which will throw off droop.
That being said, i have used it and done well with it. I would tell you to give it a try and if it doesn't work for you, go back to the wire system.
Old 12-20-2012, 10:33 PM   #6569
NR
NR's Avatar
Trader Rating: 52 (100%+)
Guys,
Can I get an estimate of what's different on the 12 Pro to the 11?
I am considering getting a new 11 as a parts car, but wondering if its worth it.
Is the ally chassis the same?
Cheers
NR
NR is offline   Reply With Quote
Old 12-21-2012, 09:14 AM   #6570
esckalayd's Avatar
Originally Posted by NR View Post
Guys,
Cheers
NR
The only real difference between the 12 and the 11 is the top plate is cut out for more steering and the center of gravity of the car was lowered a bit. The 12 pro kit comes with lightweight differential pins, not sure if the 11 pro had those or not.
The 11 and 12 chassis are both the same allowing for weight integration.
