Like Tree7Likes
Old 10-17-2012, 10:40 AM   #6481
RC MARKET's Avatar
Originally Posted by ToysRUsKid View Post
Do you have pictures yet?
I'm ask ??
RC MARKET is offline   Reply With Quote
Old 10-17-2012, 03:05 PM   #6482
jcrc's Avatar
Originally Posted by 30Tooth View Post
Well,Xray debuted the Pro with all the options so is to be expected a new version.IMO is something along the line of Wischnewski car,narrower chassis and T4 short shocks.
If you see the photo, Dirk is using the regular plastic shocks with the orange caps of the ET car. There is no way that you can use the new shorter shocks on the NT1 without mayor changes to the towers.. Hopefully Xray give us a new car early next year…
RC America / Xray, VP Fuel, Pit Lane Hobby
jcrc is offline   Reply With Quote
Old 10-17-2012, 06:31 PM   #6483
Location: Beneath a rock down by the river. Don't have money for van
My mistake,just some orange bits on Dirk's car.I can't think of anything that should be on the new version.
( ͡° ͜ʖ ͡°) https://www.facebook.com/becomeasetupguru/
30Tooth is offline   Reply With Quote
Old 10-17-2012, 07:40 PM   #6484
Racer Z's Avatar
Originally Posted by jaykay View Post
Has some one tested the graphite plate insert for the chassis? what effect does it have when you use it?
It removes flex at that end of the chassis. If grip starts to come up and the car starts to traction roll try the graphite tray in the front first. If it helps but its not enough then use the brass front plate instead. This is assuming that you are maxed out on the stiffness of your front bar. In the rear I found that it allows more rotation with the graphite plate. I haven't tested the brass in the rear yet but I would assume running the rear brass tray would help lower the center of gravity helping in high bite conditions. Hope this helps!!
RC AMERICA, HUDY, XRAY, Nexus Racing, Desoto Racing, 301 Raceway(RIP). XRAY T4/NT1 coming for that #1 spot!! AKA-Melvin Aulston
Racer Z is offline   Reply With Quote
Old 10-17-2012, 07:49 PM   #6485
Racer Z's Avatar
Originally Posted by Rhyswilldo View Post
Anybody use offset wheel hex's?? I have been given a few and not to sure when to use them and what difference it does to the handling of the car...
Any help greatly appreciated!
The offset hubs is a powerful tuning option. I have played around with the different offsets and found that it all depends on what you are looking for the car to do. A wider rear offset on the car say like 200mm assuming youre running a narrow front end like 198mm or so will cause the car to have more steering on power but will suffer a little off power as the track with is now wider than the front. This is just an example but you have to play with the different ones to see what you like. You can also play with unsprung weight and other things by using the offset hexes. The standard hexes that come with the car works well in most cases. Hope my explanation is not to confusing.lol
Old 10-17-2012, 11:51 PM   #6486
hay guys no answer yet
Brought to you by the number 4 and the letter X
Running a Kyo MP9 TKI3 and An STRR EVO truck
rcmad2700 is offline   Reply With Quote
Old 10-18-2012, 12:08 PM   #6487
JamesHealey's Avatar
Originally Posted by rcmad2700 View Post
hay all
iam going to be buying aN NT 1 in the near future but am unsure of wich one to get should i get the Pro or the 2012. what are the pros and cons between the 2
thanks
The 2012 is a standard kit.
The Pro is a 2012 kit with all the extra hop-ups.
The Pro is the better car if you can afford it.
Serpent 977 Evo | Novarossi Engines | Racing Experience Fuel | Xpert-RC Servos | Xtreme Tyres | Bitty Design Body Shells |
http://answer-rc.com/en/ - Answer RC supported driver.
JamesHealey is offline   Reply With Quote
Old 10-18-2012, 02:04 PM   #6488
Osiris 75's Avatar
Trader Rating: 17 (100%+)
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 10-18-2012, 05:21 PM   #6489
Just got my kit. I never raced 1/10 nitro TC before and could use suggestions for an engine, pipe and gearing. Home track is high bite, tight infield with 200' + straight.
triple7s is offline   Reply With Quote
Old 10-18-2012, 05:46 PM   #6490
s10dude's Avatar
stock gearing in kit is good , motor and pipe depend on the amount of $$$ you want to spend
Marc Richards / Xray NT1 / Matrix Tires / RB Motor's / Futaba
Fabricator and racer @ Speedworld Raceway & Hobby
s10dude is offline   Reply With Quote
Old 10-18-2012, 08:40 PM   #6491
Racer Z's Avatar
You can't go wrong with a Max Power and 2670 pipe. Gear it at 17/23 59/55. Start there and see how it feels. That should be a safe gearing for anything Novarossi based.
Old 10-19-2012, 03:19 AM   #6492
Rhyswilldo's Avatar
Thanks! Yes not to sure if it pays to use them yet... I'll just try every combo and see what happens...
Rhyswilldo is offline   Reply With Quote
Old 10-19-2012, 03:24 AM   #6493
Rhyswilldo's Avatar
Anybody have any word/idea on where the 2013 Euro B 1/10 tc championships will be???
Old 10-19-2012, 03:43 AM   #6494
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Michael_T is offline   Reply With Quote
Old 10-21-2012, 04:31 PM   #6495
Racer Z's Avatar
Paul Lemuiex wins US Nationals in Florida!! Mike Swauger 2nd!!! What a great result for the NT1's.
