Like Tree10Likes
Xray NT1
Old 05-02-2012, 11:35 AM
  #6271
Osiris 75's Avatar
Trader Rating: 17 (100%+)
Originally Posted by HHH View Post
Perhaps I should rephrase my main question -- has anyone had a close look at the new radio plate? Is it just like the old one with the two cross supports over the steering pivot cutaway?
Yes, that's the only mod.
Osiris 75 is offline
Old 05-10-2012, 05:43 AM
  #6272
Onetrade's Avatar
Trader Rating: 14 (100%+)
Building my NT1 and need some recommendations. I don't need the best, just good is fine
Motor
Pipe and Manifold
Servos
starter box
Onetrade is offline
Old 05-10-2012, 06:38 AM
  #6273
YLLIB's Avatar
Motor
Pipe and Manifold
Servos
starter box
JLR starter box, great but in expensive REDS MT3 W/ PIPE ---- PICCO .12 TORQUE W/PIPE --- Nova Rossi Flash PT W/PIPE all good for good prices
what kind of Radio you have? stay with the servos w/ your radio. makes it easy.
Hope this helps.
Billy
www.acornracingusa.com
YLLIB is offline
Old 05-10-2012, 08:19 AM
  #6274
pressure's Avatar
Motor
Pipe and Manifold
Servos
starter box
rbm3( personal fav)/ picco .12/ reds mt
pipe( FBF boards gonna eat your pipe)
savox servo (great value)
JL starterbox (nice and tiny)
See Richie at BK Hobbies or Diatta at Bruckner
pressure is offline
Old 05-10-2012, 08:05 PM
  #6275
Onetrade's Avatar
Will be paying Brooklyn Hobbies a visit.
Onetrade is offline
Old 05-11-2012, 01:31 PM
  #6276
valk's Avatar
Go two savox servos on mine, oldschool os12tr w/novarossi pipe i got for free. Car just as fast at our track as the newer rb/nova powered beasts. Doesnt have to cost a ton.
valk is offline
Old 05-11-2012, 02:22 PM
  #6277
LIUK82's Avatar
Angry rebound alu ammo
sorry but how you manage to get a rebound with the ammo of the NT1 aluminum
I followed the instructions to unscrew the bottom cap and push the pull rod 20 times to get a 25%
but the piston always shoots me out of everything with strong pressure
-I have tried various ways in other types of oil to fill the body
- Put the membrane and allow to rest 5 minutes, put the sponge on top
-push the piston up to the minimum rebound and close the cap onto the rod, but even so shoot me an overall 90%
-then I tried to unscrew the cap over and push, loosen and push it several times until a minimum rebound
but doing so is filled with air bubbles
manual also explains that you can use the ammo in 2 modes with 2 o-ring and 2 thicknesses close
or 1 o-ring with small thickness and a thick big, what changes?
I'm trying the rebound in oil 600, and standard 2-hole plates for front and rear
LIUK82 is offline
Old 05-12-2012, 01:22 PM
  #6278
Anyone selling a used setup thats almost RTR? Looking into racing this summer. PM me thanks
Tigerbalm is offline
Old 05-12-2012, 02:43 PM
  #6279
you might have to register with the web site to see the ad. as it's one of the club members selling his NT1
http://www.irocc.ca/irocc/forums/index.php?topic=3945.0
light is offline
Old 05-19-2012, 05:31 PM
  #6280
piper48
Guest
Posts: n/a
Default 1st gear only
I'll be visiting a couple of small tracks (don't know the size) that they don't typically run 1/10 nitro cars. I just want to run 1st gear but I'm not sure which way to set it up. To my knowledge I could just remove the 2nd gear spur or tighten the set screw so 2nd gear doesn't kick in....right? What's the best suggestion you guys have for running 1st gear only. Thanks in advance.
Old 05-19-2012, 05:41 PM
  #6281
bfong13's Avatar
Don't bother removing the 2nd spur gear. Just tighten down the 2-speed so the car doesn't shift. If the track is small, you won't build up enough speed anyways.
bfong13 is offline
Old 05-20-2012, 05:02 PM
  #6282
valk's Avatar
looks like my OS12TR might be biting the dust finally. i stripped the pinch bolt and cant find a replacement, or get the thermal insulator out without mangling it to replace the bolt anyway. might try to jbweld my carb in but probably not a great solution..
I just race in parking lots. maybe 80-100ft straight with technical infield. my 12tr was enough to keep up on a track this size but what could i get that isnt super expensive as a replacement? i see a maxpower for sale here used. how would the rb jr engine perform?
valk is offline
Old 05-31-2012, 09:48 AM
  #6283
nitrobeast's Avatar
Trader Rating: 42 (100%+)
Not sure if you are still looking, but figured i would let you know.
http://www.rctech.net/forum/r-c-item...-max-xxl3.html
Send me a PM if interested.
nitrobeast is offline
Old 05-31-2012, 10:48 PM
  #6284
JamesHealey's Avatar
What do people run on the front diff?
Spool, oneway or gear diff.
JamesHealey is offline
Old 06-01-2012, 07:17 AM
  #6285
ToysRUsKid's Avatar
Trader Rating: 16 (100%+)
I would guess mostly gear diff but oil weight depends on the driver, track, etc.
ToysRUsKid is offline
