Like Tree10Likes
Xray NT1
Old 10-18-2011, 12:00 PM
  #6151
staikosn1's Avatar
Ok so lets see...
The weather in that weekend race will be cold without sun...
The race truck, is kind of open some quick parts, but not easy... So for sure Ill some more steering and the car has to be quick from corner to corner!!
Should i use purple springs with 450 silicone front and behind??
staikosn1 is offline
Old 10-22-2011, 04:46 AM
  #6152
Default Xray batts
Hi
im waiting for my first nt1!!, can you guys recommend me an specific model of batt for the rx (life or lipo)? Any start up list of spares>? or hop ups?
thanks!
gaspar is offline
Old 10-22-2011, 05:42 AM
  #6153
i have tried Li-fe batteries for my NT1 but they are normally too long to have a perfect fit in size. Normally, my friends will cut off the protection plastic packing in order to put the battery in place. Better choose either Li-po (but you then require a voltage regulator) or the usual NIMH battery.
Yoshimon is offline
Old 10-22-2011, 06:12 AM
  #6154
asw7576's Avatar
Use dremel with flat bottom bit,
flattened the north and south corner of xray battery holder.
north corner [___________li-fe battery__________] south corner
asw7576 is offline
Old 10-22-2011, 09:20 AM
  #6155
bluer322's Avatar
Originally Posted by gaspar View Post
Hi
thanks!
Ues the Exceed lipo pack fits perfick.
bluer322 is offline
Old 10-22-2011, 10:40 AM
  #6156
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
Originally Posted by staikosn1 View Post
Ok so lets see...
I would start with ralph burch's winternats setup and adjust from there.
rx7ttlm is offline
Old 10-22-2011, 12:46 PM
  #6157
Hi
do i need a regulator? do you have the model number?
thanks!1!
gaspar is offline
Old 10-22-2011, 01:05 PM
  #6158
jca2000au's Avatar
Trader Rating: 9 (91%+)
Hi
thanks!1!
It is XCEED not EXCEED.
Li-PO part number 105001
Voltage Regulator 105002
jca2000au is offline
Old 10-22-2011, 07:09 PM
  #6159
Factory Seal's Avatar
Trader Rating: 29 (100%+)
I ran the 2011 Spec today.....W/every mod!..LOL! It is a 2 day Event......We ran 3 qualifiers...
currently im sitting at TQ.....Donnie Thomson 23 laps.....5:12.856
running the 2011 spec,with Sirio Mills and pipes,savox servo's
this is a AWESOME hotrod.....
Xray pilot....Jason Lutz........22 laps..........5:11.360
Xray Pilot....Lee Thompson....21 laps.........4:59.887
Privateer......Kevin Stephens...21 laps.........5:09.183.....
we sdtill have another qualifer and the mains tomorrow...
Wish Me luck....
Factory Seal is offline
Old 10-23-2011, 08:19 PM
  #6160
SOLOARTIST 702's Avatar
Wish Me luck....
good job
SOLOARTIST 702 is offline
Old 10-24-2011, 12:36 PM
  #6161
staikosn1's Avatar
I finally ran this weekend again...
All racers had problems cause we had to
get used to the new truck line (if I say it correct)
THe car was good enough, I changed the suspensions positions more to vertical (minor change, but finally so big) , the R3 RC was to quick, and i had to loose the centax spring a 1/4 of hour...
I used 37-40 tires, but next time Ill use 35-37 for better grip... I have to admit that i didnt change the silicone in diffs for the race..
I ll do it next time!!!!
I started 4th in 2nd final...I finished 3rd, and took place place for 1st final...
Was last in 1st final in 14 cars,and i finished 8th!!
1,5 hour of racing this weekend, perfect for practice!!!
Cheers, Nick!
Old 10-24-2011, 01:41 PM
  #6162
Originally Posted by SOLOARTIST 702 View Post
good job
Well i was in the lead in the Main shortly....5 laps before they caught me.......they had a mishap in turn 1....LOL!
anyway,I ended up 3rd.....Flame out on pit #2...UGH!!....sat there for about 1min.........15min main......LOL!!
Had a blast and the car is unreal,and easy to drive...
the X-Ray Pilots got me this time.....Can't wait until the Nat's in Feb........
a few pics....
Old 10-24-2011, 07:27 PM
  #6163
could you please tell me what your track is built out of
baldy is offline
Old 10-24-2011, 08:14 PM
  #6164
the Track is built from 3inch plastics PVC,we make T's inserts,small curves and big,,and Bend at different angles...drill holes in the ends for strapping it together...we also use Plow disc with a slot for the pipe to fit in for stops fo sharp corners.....and lots of VHT!....LOL!
......loop is 4inch pipe.....Drivers Stand is 13ft off the ground and 30ft in length..........
Old 10-25-2011, 11:35 PM
  #6165
BigDogRacing's Avatar
Actually it's 2.5" PVC conduit schedule 40.
The connectors are 2" sch. 40 PVC conduit with a small 2.5" sleeve in the center.
BTW Donnie- that guy smiling in the picture u posted is one handsome fella. He musta won?
BigDogRacing is offline
