Like Tree7Likes
Old 04-19-2007, 12:39 PM   #601
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Originally Posted by CIMRI
Ralph,
What for a tire split do you run usually? Martin told me ;he is running harder tires at the rear. For more steering. Did you do this too?
I now that, s 720 drivers do this too, because they have to much rear tire wear and for better tire wear balance (front & rear)they have to do this.
Is this the same reason by NT1?
thnx
Christian
its usually about a 1mm to 1.5mm split front and rear
Old 04-19-2007, 01:28 PM   #602
RC America's Avatar
Ralph,
thnx
Christian
I have been running the car with a 1.5mm split and harder tires on the back. With the 200m cars the rears tires always seem to wear faster then the fronts, so you need to try and run harder rears to keep the split balanced as you run.
Ralph
RC America is offline   Reply With Quote
Old 04-19-2007, 01:43 PM   #603
CIMRI's Avatar
Ralph
thnx Ralph. What is the overdrive ratio with 1.5 split?
CIMRI is offline   Reply With Quote
Old 04-19-2007, 01:46 PM   #604
Just downloaded the NT1 Instruction Manual from the XRAY Page and damn i want that car. And by the way the Manual is the best ive ever seen. Its so detailed and easy to understand. PERFECT
defencex is offline   Reply With Quote
Old 04-19-2007, 01:49 PM   #605
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Originally Posted by stefan
That's a shame to hear about SoCal. Where are all the pro's going to practice then?
When you are in that area,why not buy at the chinese gang over at Mall of Orange, Ultimate Hobbies.
Just don"t ask too many questions
Stefan - the folks at Ultimate are Japanese not Chinese. And they don't carry XRay.
YR4Dude is offline   Reply With Quote
Old 04-19-2007, 01:54 PM   #606
rmdhawaii's Avatar
You downloaded the manual? Where is it?
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 04-19-2007, 01:55 PM   #607
CIMRI's Avatar
I cant find the mauel. do you have the link? are sure
Old 04-19-2007, 01:56 PM   #608
http://www.teamxray.com/teamxray/pro...ame=XRAY%20NT1
Letīs rock!
Old 04-19-2007, 01:59 PM   #609
rmdhawaii's Avatar
Yup! Thanks!
They need to update the NT1 Flash product download section...
Old 04-19-2007, 02:01 PM   #610
CIMRI's Avatar
thnx dude
Old 04-19-2007, 02:09 PM   #611
GK
Suspended
How about that set up book, eh?
http://www.teamxray.com/teamxray/sho...p?file_id=3577
GK is offline   Reply With Quote
Old 04-19-2007, 03:38 PM   #612
rmdhawaii's Avatar
Comments about the car and instruction manual:
- Uses o-rings as a seal between the two diff halves.
- Outer washer between the diff housing and the outdrive.
- Two holes on the top of the rear upright.
- Don't have to remove one of the rear bulkheads to replace the rear belt.
- Side belt tensioner fastens into plastic?
- Turn buckles adjust with wrenches.
- Pre-drilled transponder holes in the upper deck.
- Optional flywheel collets for the Novarossi (7mm) and Picco (6mm). Does a collect come with the kit?
- Very clear about difference in inner/outer diameter of thrust bearing washers.
- Excellent instructions for setting clutch gap and endplay.
- Setting gear mesh instructions - passing grade.
- Adjustable/non-adjustable shock pistons out-of-the-box.
- Rebound adjustment. Interesting option.
Setup book:
- Setup book has some great info - but it doesn't seem to mention anything about front/rear tire split or running small tires for qualifiers. Is that covered somewhere else?? Also, did not see anything about the two holes on the top of the rear upright. Did anybody come across that yet?
Looks really good so far.
Old 04-19-2007, 03:47 PM   #613
bvoltz's Avatar
I'm the only one that can not print these documents out? If you have figure out how, please share with me...
Wheeling an Xray T4 and T4 14 using a Ko Propo, powered by EA motors and Speed Passion Speedo, paid for by my wife.
Digi3Dworks - 3D printing for the medical Field.
bvoltz is offline   Reply With Quote
Old 04-19-2007, 03:57 PM   #614
rmdhawaii's Avatar
If you have the latest version of Acrobat reader and click on the "lock" icon on the top left it will tell you the following:
"You cannot edit, print or copy this document".
There is a way around this, but even I'm not willing to do it.
Old 04-19-2007, 05:08 PM   #615
RoNTC3's Avatar
Send a message via AIM to RoNTC3 Send a message via Yahoo to RoNTC3
Is it just me or is this thing Identical to the RRR? I'm not looking to start S#!t as I have been waiting just as long as everyone else here for it to come out. I just built my RRR a month and a half ago and I must say I think I could have built my RRR with these Instructions....They look that close to me
Now fire away at me........
eXpress Motorsports * FOLLETT Motorsports * Final Thoughts Racing
Remember, half the people you know are below average.
RoNTC3 is offline   Reply With Quote
