Xray NT1
#6092
#6093
I ran the same spur and pinion gears all season without any problems until the weekend of our annual big race. All of a sudden I'm stripping the 2nd gear spur left and right. I went through a total of 3 spur gears in two days. I qualed in P2 and in the Mains I stripped out another one. I was so frustrated that I haven't touched the car since. Before I go through the car, do you guys have any idea what's causing this? Thanks in advance.
#6094
Hard to say, depends on the track. I have rear diffs built in 40k, 50k, 60k, 70k, and 80k. Fronts in 100k, 120k, 150 and 200. If the track is large and high grip I unload with 150/70 now. Tight and technical with no grip 100k/40. You really have to just try it and figure out what works unless someone at your track runs the car, even then it's really preference.
#6096
http://www.teamxray.com/teamxray/sho...6ed1d42c0fde2f
and the serpent one
FRONT SPRINGS
New Spring ratings
N/mm lb/inch
White 2,3 13,0
Yellow 2,8 16,0
Orange 3,4 19,5
Red 4,1 23,5
Pink 4,9 28,0
Blue 5,8 33,0
Purple 6,8 39,0
Green 8,0 45,5
Grey 9,0 51,5
Black 10,0 57,0
Old spring ratings
REAR N/mm FRONT N/mm
Orange 2,1 Orange 2,7
White 3,0 White 3,0
Yellow 3,8 Yellow 4,0
Red 4,6 Red 5,0
Blue 5,2 Blue 6,1
Purple 6,2 Purple 6,5
Grey 10,9 Grey 10,3
REAR SPRINGS
New Spring ratings
N/mm lb/inch
White 2,3 13,0
Yellow 2,8 16,0
Orange 3,4 19,5
Red 4,1 23,5
Pink 4,9 28,0
Blue 5,8 33,0
Purple 6,8 39,0
Green 8,0 45,5
Grey 9,0 51,5
Black 10,0 57,0
Old spring ratings
White 3,0 White 3,0
Red 4,6 Red 5,0
Blue 5,2 Blue 6,1
Grey 10,9 Grey 10,3
and see if something is similar..
#6099
there isn't really a direct conversion, we tried to use the lb rating to compare the xray springs to the new serpent springs and the serpent springs were a fair bit stiffer with the same lb rating.
#6100
What battery do you guys run? I have an older hump pack but looking to go LiPo or LiFe. Which do you prefer and why? I also am trying to possibly do either or without a regulator...is this possible?
#6103
#6105
18Likes
