Like Tree7Likes
Old 05-12-2011, 09:19 PM   #5986
Remy's Avatar
Default Is the Manual wrong?
Below is a picture of the arm that attaches to the steering servo. The manual states that it should be 36mm. I measure it to be around 41mm. The part numbers are all correct so I was wondering if I will have any issues installing this or is this just an issue with the manual?
Sponsored by Platinum Visa.
Remy is offline   Reply With Quote
Old 05-12-2011, 10:52 PM   #5987
jds5150's Avatar
There should be a pair of shorter ball cups in BAG 07.
jds5150 is offline   Reply With Quote
Old 05-12-2011, 11:15 PM   #5988
Remy's Avatar
Don't know man. Part numbers are all the same.
Anybody know where I can get bag 7 as a whole??
Old 05-13-2011, 05:10 AM   #5989
nitrobeast's Avatar
Trader Rating: 41 (100%+)
Dont remember how mine was but never noticed a problem. Take a dremel out and trim 2-3mm off each one.
Rui Goncalves
Team CRC|Awesomatix USA|TQ Wire|
Jackson curbs, ready for lift off!
nitrobeast is offline   Reply With Quote
Old 05-13-2011, 05:30 AM   #5990
Remy's Avatar
That is exactly what I plan to do thanks
Old 05-13-2011, 08:41 AM   #5991
RC MARKET's Avatar
CSO 3.5mm Graphite Chassis 2011Spec
RC MARKET is offline   Reply With Quote
Old 05-17-2011, 10:22 AM   #5992
roger999's Avatar
Default solid axle
hi, just wanted to buy 3Racing Alum Front Solid Axle but can i use for that standard diff outdrive adapters 335071?
facebook.com/rogergrafix
roger999 is offline   Reply With Quote
Old 05-17-2011, 03:53 PM   #5993
Osiris 75's Avatar
Trader Rating: 17 (100%+)
Just don't get the 3Racing part!! In my experience you will need to replace it after 2 races anyway. Just buy the Xray part.
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 05-22-2011, 02:41 PM   #5994
R.Dalnogare's Avatar
Send a message via AIM to R.Dalnogare
I'm having trouble with the high dynamic clutch that came in the WC kit. I built it so it has 0.7mm clutch gap, and very little end play. When I went to break in the car I could not get the clutch to engage, I built the clutch with the 10.00mm gap between the clutch nut and end of the shaft, and even tried loosening the clutch nut to get an earlier engagement but nothing worked. Anybody have a solution this is pretty frustrating.
R.Dalnogare is offline   Reply With Quote
Old 05-22-2011, 03:40 PM   #5995
ira
ira's Avatar
Trader Rating: 18 (100%+)
Try starting with .7mm of thread from the clutch nut and the flywheel nut. Shim the clutch bell just off of the shoe so that the bell dose not rub on the shoe and then remove the bell and add .3mm of shimming. Now you want to start with .2mm of end play, then adjust your clutch from there.
ira is offline   Reply With Quote
Old 05-22-2011, 04:02 PM   #5996
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
I run less gap than that. About .4-.5mm.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 05-22-2011, 04:36 PM   #5997
I got a hold of a friend that told me how to set it right, so its figured out now, thanks for the help.
Old 05-24-2011, 07:59 AM   #5998
nitrobeast's Avatar
I have a xray solid axle 4sale. PM if still looking to buy one.
Rui Goncalves
Old 05-24-2011, 04:54 PM   #5999
Default materials
has hudy/xray changed their materials recently? the spring steel parts seem more black in colour now where it used to be a more of a brown colour????
aaron w is offline   Reply With Quote
Old 05-27-2011, 05:24 AM   #6000
J.Gonzalez's Avatar
Trader Rating: 16 (100%+)
I am looking for longer ball joints for bottom of shock.
I am trying to fit 4way xray shocks on another vehicle.
The spring sit really low on shock and only leaves a few threads to spin collar down for ride height. I rather not fabricate a new rear shock tower.
Are the balljoints for rear way bar the same diameter as shock balljoints? Hard to tell on xray site but they look a bit longer and accept 5.8mm ball.
Jamie
J.Gonzalez is offline   Reply With Quote
