Like Tree6Likes
Old 03-20-2011, 12:47 PM   #5926
Scott B's Avatar
Trader Rating: 43 (100%+)
Originally Posted by Ghett0 View Post
How long did you make the links?? I got one from rcmarket and there were no instructions on how to assembly and install it.
Mugen Racing USA, Sweep Racing Tires, R1 Wurks, Protoform, Speedworld Raceway...
"On-road is racing.. off-road is 50% competitive jumping and 50% crash avoidance"...
Scott B is offline   Reply With Quote
Old 03-20-2011, 02:28 PM   #5927
Not exact numbers as to my setup but this is good start point. Depending on track you adjust. spacers aswell
Hope this helps... Enjoy
Ghett0 is offline   Reply With Quote
Old 03-21-2011, 05:00 PM   #5928
RC MARKET's Avatar
Originally Posted by NikoRacing View Post
Anyone knows when the new 2011 chassis and brass/carbon plates will be available as spare parts?
later !
RC MARKET is offline   Reply With Quote
Old 03-21-2011, 05:01 PM   #5929
RC MARKET's Avatar
Good !
Old 03-21-2011, 05:37 PM   #5930
Originally Posted by RC MARKET View Post
later !
When is later? April, may june?
BTW fix you website so people can use it without crashing every minute...
chovden is offline   Reply With Quote
Old 03-31-2011, 12:02 PM   #5931
+10000000!!!!
panayos is offline   Reply With Quote
Old 04-01-2011, 09:25 PM   #5932
Tag
Tag's Avatar
Trader Rating: 31 (100%+)
hi guys, has any of you have 2 speed problem, i mean my 2 speed seems to shift way too early, i have tried tighten it to the point it cant be tighten but the problem persists. i also tried the new harder 2 speed springs and new 2 speed drums but the problem still there ...i have heard using kyosho springs will this do the trick ?
* Serpent 966 TE Novarossi 35+21, Airtronics M12 *
Tag is offline   Reply With Quote
Old 04-01-2011, 09:32 PM   #5933
D-nicest's Avatar
The only time I've heard of people having this issue is when the screws were un evenly adjusted on the shoes. I use the the xray hard springs and haven't had any issue with getting it to engage late enough. Try double checking to make sure everything is even. Look at the spacing between the shoes and the adapter as well.
Diatta Collymore [email protected]([email protected])(www.fordhamhobbies.com) (Wallacemotorsports.net) Fordham Hobbies, Wallace Motorsports, WRC Racing, Hot Race Tyres, Ielasi Tuned Engines, VP Power Master fuel, KO Propo America, Paint By Mikey Mike
D-nicest is offline   Reply With Quote
Old 04-01-2011, 09:38 PM   #5934
Tag
Tag's Avatar
i have checked everything but cant seem to solve the issue ...
Old 04-01-2011, 10:04 PM   #5935
D-nicest's Avatar
Posting a pic of your 2 speed clutch might help out. The only other things i can think of that would cause this are possibly having a lack in forward bite, brake adapter not fully tightened to the shaft, a damaged/worn 1st gear oneway bearing, or damaged belts. Pics are def helpful in this case though...
Old 04-02-2011, 08:15 AM   #5936
Tag
Tag's Avatar
i have checked belt and other transmission components and couldnt find fault. but you are right , it could be the problem with the one way bearing, i just ordered both first and 2nd gear adaptors see if it helps !
thanks bud
Old 04-02-2011, 08:34 AM   #5937
dragont's Avatar
wow! unique setup. im assuming it should handle better on chicanes and cornerings... other than that, whats the advantages the way its set up?
HOY BAKLA!!!! U DA BU LA'IA!!!!!!
dragont is offline   Reply With Quote
Old 04-03-2011, 08:30 AM   #5938
The Direct Link system is activated during cornering mainly, whereby the outer suspension forces are transfered partially to the inner wheel too, with a pivot-link system. The results is more rubber on the track, more traction and more even tyre wear, resulting in significantly faster and easier cornering and possible better laptimes.
Old 04-03-2011, 09:15 AM   #5939
Default DLS
Where can you buy it for the NT1?
jonrg is offline   Reply With Quote
Old 04-04-2011, 02:29 AM   #5940
has anyone tried installing the direct link system to the front also?
TomB is offline   Reply With Quote
