Like Tree7Likes
Old 03-09-2011, 05:51 AM   #5866
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Originally Posted by roger999 View Post
hi, just wanted to know how you guys check tweak of your car? Just got setup wheels and when i check tweak on that wheels car is not tweaked, but when i put foam wheels car is tweaked... My all foam wheels are same sizes 59/60.
I would trust your setup wheels over your foam wheels...
They may be the same sizes... but the 0.3+/- is where the difference lies. Specially if you trued them with an angle.
Remember also that the width of the foam wheel makes it difficult to notice when the tire actually lifted from the ground. The setup wheels is more precise.
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 03-09-2011, 07:16 PM   #5867
Want to know what is the different of the NT1 2011 then the previous version? I can't tell from their web? The chassis looks the same.
ioxqq is offline   Reply With Quote
Old 03-09-2011, 07:29 PM   #5868
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
The chassis is actually different. It has spaces for brass or carbon stiffeners front and rear.
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 03-09-2011, 08:07 PM   #5869
thanks Can the 2011 chassis works in 2010?
Old 03-09-2011, 08:08 PM   #5870
Osiris 75's Avatar
Trader Rating: 17 (100%+)
Yes
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 03-09-2011, 11:39 PM   #5871
roger999's Avatar
Thanks Riketsu, you suggest to use tweak station as well? Or use traditional method like lift up a car by hand?
facebook.com/rogergrafix
roger999 is offline   Reply With Quote
Old 03-10-2011, 05:36 AM   #5872
Riketsu's Avatar
You can also check by using the tweak station... But I believe that lifting it with the setup wheels is more accurate, just my opinion.
After tweaking it with the setup wheels, sometimes i double check it against the tweak station and its dead on.
Old 03-10-2011, 08:05 AM   #5873
roger999's Avatar
Riketsu, one more, can i balance my chassis in NT1? I mean should i check the balance and does it need to put some balancing weights on that?
Old 03-10-2011, 10:43 AM   #5874
Riketsu's Avatar
Yes you can.
I am currently using a two low profiles servos, a low-profile heat sink, the 30gram C below the C, the heavy motor mount, micro receiver, new PT and the receiver box and the car came pretty much balanced.
In stock form, you probably need to add 15-20 gram in the pipe side (where the 3 holes are) because of the weight of the box. If you remove the box and use the EC mount, the car will pretty much balanced...
In order to balance it perfectly, I suggest using two identical scales and to substitute the shocks with linkages of equal length (as DS has recommended). It is by far the best way to balance the car and get a very accurate reading which does not change with the shock movement.
The front of the car is mounted in a Hudy Balancing Pin on top of a 3rd scale.
These scales are very cheap in eBay and I got em at around $6 a piece.
Old 03-11-2011, 12:17 AM   #5875
roger999's Avatar
thanks for that, tomorrow ill borrow 2 scales for now. Just thinking that mayby would be better to just block the pistons and leave a car with standard shocks for balancing....?
Old 03-11-2011, 01:40 AM   #5876
Riketsu's Avatar
You can probably do that with the shocks... The point is that the shock does not change its length and that both lengths of each side are identical.
Old 03-11-2011, 04:00 AM   #5877
roger999's Avatar
thanks a million for your help Riketsu!
Old 03-11-2011, 09:33 PM   #5878
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
If your using the kitchen scale method its really easy to balance the car. Get 4 of the ebay scales. Place the car on the scale pads with the setup adapters bolted on. Then adjust the diagonal weights till the sum of the LF AND RR is = to RF and LR. That point you have 0 tweak (or wedge), and then simply add weight where you need it to get to min and or balanced weight. Recheck ride height and chassis level (left to right) then your all set.
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 03-12-2011, 01:42 AM   #5879
Joe Chaplow is offline   Reply With Quote
Old 03-12-2011, 11:47 AM   #5880
CanyonCarverR1's Avatar
I'm just finishing my new NT1WC and have a question; how is gear mesh adjusted? Just with gear sizes? There is a little wiggle room in the motor mount and engine mount screws but it doesn't seem like enough to make gear changes without changing both pinion and spur.
CanyonCarverR1 is offline   Reply With Quote
