Like Tree7Likes
Old 10-07-2010, 09:04 PM   #5731
Originally Posted by ToysRUsKid View Post
Try it wit the longer screws and springs in between. It works, I use one very similar to that.
Thanks, i'm going to give it a shot.
Jean L.
sponsored by my paycheck.
Maxx is offline   Reply With Quote
Old 10-07-2010, 09:37 PM   #5732
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
Jean you coming out Sunday?
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 10-09-2010, 05:31 PM   #5733
I'm sitting this one out bro, i'm waiting on some parts to come in. I plan on going to Blue Diamond next weekend though. You?
Jean L.
Old 10-12-2010, 04:18 PM   #5734
Originally Posted by DS Motorsport View Post
-Never liked the XCA clutch, with very high powered engine it lacked punch and started to fade in long mains. Maybe the new shoe will improve it.
I like the original clutch with the alu bell and lightweight flywheel a lot better.
Doesn't come close to a Capricorn WCE clutch though.
DS,
Some said alu xray bell have durability issues, developing some weird tracks due to material softness...Did you noticed that ?
CSO have different flywheels, 4.8 and 6.8 grams. Which one have you been using ?
Thanks.
Cobra zz
Cobra zz is offline   Reply With Quote
Old 10-28-2010, 09:58 AM   #5735
Cobra zz
Old 10-28-2010, 10:21 AM   #5736
DS Motorsport's Avatar
Originally Posted by Cobra zz View Post
DS,
Thanks.
Sorry, saw you're question but forgot to answer it.
I've heard this as well, however I've had the same alu bell in the car for over a year.
It think it comes down to maintenance and how dirty your track is, if you're running on a very dirty track the sand and small stones can cause these tracks.
I clean my clutch after every practice day and roughen up the bell with Scotch brite, this keeps the clutch assembly in good condition.
I don't know which flywheel I had, when I ordered it there was only one flywheel. Can't measure mine as I already sold one NT1.
But I would go for the lightest one off course.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 10-28-2010, 10:44 AM   #5737
Default Capricorn Magnesium Radiotray mounts
It's possible to fit the recently released Capricorn magnesium radiotray mounts to your NT1.
http://www.capricornrc.com/os_capric...oducts_id=1326
http://www.capricornrc.com/os_capric...oducts_id=1070
However you need to modify the carbon bracket which holds the side belt tensioner as you can see in the pics.
Changing the bolt in the engine mount to a button head and slightly modifying the carbon bracket should make it work.
Also I would recommend changing the composite brace to a tierod as you can see in the pics.
The plastic brace causes tweak (also with the stock setup) and with the tierod combined with aluminum/magnesium radiotray mounts will give more overall mid corner grip.
P1-RC.com
Old 10-28-2010, 12:15 PM   #5738
Thanks for the info DS.
BTW, How did you manage to do the holes in the pulleys' cover ? It's a pieceof fine art !!! LOL
Cobra zz
Old 10-30-2010, 01:36 AM   #5739
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
DS has a lot of free time... Probably a pin vise and a numbered drill bit.
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 10-31-2010, 11:34 PM   #5740
asw7576's Avatar
That's sweet idea bro
Old 11-02-2010, 08:32 PM   #5741
Q-B0R0 B0MBER's Avatar
Default STRIPED GEARS!!!!!!!!!!!!!!
OK GUYS I HAVE A QUESTION ? HAS ANYONE BEEN STRIPPING GEARS?I CANT SEEM TO GET THE GEAR MESH RIGHT ON MY NT1,I KEEP STRIPING 2ND GEAR..ANY TRICKS OR ADVICE WOULD BE HELPFULL ..
THX
Q-B0R0 B0MBER is offline   Reply With Quote
Old 11-02-2010, 08:43 PM   #5742
NITTO550's Avatar
I would check the bearings in the main shaft as well as the bearing in the 2 speed carrier.
There are only two ways to do things. The wrong way or my way!
Rich D..
~Mugen Seiki Racing MTX-6 ~,
Novarossi racing Engines ~Ko Propo, ~Avid Bearings..
VBC Racing Wildfire D07 ~LRP Electronics ~ Fantom Racing
NITTO550 is offline   Reply With Quote
Old 11-02-2010, 10:05 PM   #5743
rx7ttlm's Avatar
Check bearings in the two speed, check the place where the two speed shaft and the one way bearing touch on the shaft. ALSO make sure your not running a split over 5 for the pinions. If you start trying to run an 18 tooth pinion with a 21 tooth second gear you will strip them every time. I check gear mesh of second with first gear not installed. then slide on first (spur) and check first separately. They should be as tight as possible while still spinning free. Hope that makes sense. also make sure your tightening the engine mount screws and using blue loctite. After all that check to make sure your chassis is straight. If its bent that will change gear mesh max/min.
I can say I have never stripped an NT1 spur gear.
Old 11-03-2010, 06:12 AM   #5744
+1
Never stripped after using this technique
jelayne is offline   Reply With Quote
Old 11-03-2010, 06:29 PM   #5745
RC MARKET's Avatar
THX
Yes check your 2 speed shaft bearing & if pinion gear is new ,
maybe Engine front bearing/Clutch bearing !
last change rear bulkhead !
RC MARKET is offline   Reply With Quote
