Like Tree6Likes
Old 09-01-2010, 10:45 AM   #5656
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Originally Posted by LiL_JaSoN View Post
very similar to the design i made in the dax thread,
Yup. That is where I got the idea from.
The design is very sensitive to the length of arms and what not. I made many iterations inorder to find the perfect length and how it works.
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 09-01-2010, 06:13 PM   #5657
Scott B's Avatar
Trader Rating: 43 (100%+)
Hey Drew, I have a couple questions about Ralphs Worlds setup.
-It shows 3 hole pistons front and 2 hole rear is that correct??
-The front springs are labeled as Red 33lb, the reds I found are 38.5lb. So is the color correct or the LB's??
-Did you use the stock engine mounts or the mono block??
Oh ya, are you or Paully coming out to Speedworld for the Mugen race next week??
Thanks,
Mugen Racing USA, Sweep Racing Tires, R1 Wurks, Protoform, Speedworld Raceway...
"On-road is racing.. off-road is 50% competitive jumping and 50% crash avoidance"...
Scott B is offline   Reply With Quote
Old 09-02-2010, 12:10 PM   #5658
Drew Ellis's Avatar
Originally Posted by jelayne View Post
Drew does the WCE car come with Capricorn / Xray Comp. diffs and is the new kit coming with more options than he used in Houston ?
Just found out the car will be a limited car. The name is the Worlds Edtion {WE}. The kit will not come with the plastic diff gears. Yes the car will come with the same and more options.
Thanks Drew
RCAMERICA-Xray-Hudy-GravityRC-Kopropo-PROLEVELRC-Team EAM-ORCA-P1Brand-AVID-ProlevelRC Raceway-MOTIV-Max Power America-SRC America
Drew Ellis is offline   Reply With Quote
Old 09-02-2010, 12:38 PM   #5659
Drew Ellis's Avatar
Thanks,
Yes the shock pistons are right. The front springs color is right but the lb. is wrong. Sorry was going to quick when I filled it out.
We used a mono block style engine mount.
Paul and I can't make it this year due to the fact of the IIC. Wish I could Billy's a great guy.
Thanks Drew
Old 09-02-2010, 07:01 PM   #5660
Scott B's Avatar
Thanks Drew
Thanks Drew,
Is the Worlds kit going to include the new red clutch shoe??
Old 09-03-2010, 08:07 PM   #5661
Drew Ellis's Avatar
Thanks Drew,
Yes it will come with the kit. The shoe is very good. Bobby Flack and Andy Power ran it also at the GLC and they were very happy with it.
Thanks Drew
Old 09-06-2010, 10:39 AM   #5662
NikoRacing's Avatar
Does anyone know if xray is thinking about a bearing rear antiroll-bar??
NICOLA PEZZOTTI - italian F1 cat. driver - Serpent 747 - HIPEX exhaust system - HOTRACE tyres - SANWA M11X
NikoRacing is offline   Reply With Quote
Old 09-10-2010, 12:36 PM   #5663
Drew can you tell me how do you set your ride right, with blank tires or racing tires ?
jelayne is offline   Reply With Quote
Old 09-12-2010, 08:33 AM   #5664
RC MARKET's Avatar
Thanks Drew
What part no. ?
RC MARKET is offline   Reply With Quote
Old 09-12-2010, 10:07 AM   #5665
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
Can't speak for Drew, but I'm pretty sure Paulie uses worn tires (or he does the math and compensates) that are the minimum diameter he expects to run (like at the end of the main) and sets his minimum ride height and droop settings with them. Then whatever the ride height is with fresh cut tires is what it is. For example:
using fresh cut tires and compensating
min tire size- 57mm fr/rr
he wants 5mm fr/rr RH at end of race
he's starting with 59.5 and 60.5 (fr/rr) tires
difference of 2.5/3.5
divide by 2= 1.25/1.75
so 5 + 1.25 = 6.25mm front and 5 + 1.75 = 6.75 rear
Keep in mind depending on tire wear, you might end up with smaller rear tires. So your math would look like this-
min tire dia- 58fr/57rr
min RH 5mm
beginning tire dia- 59.5/60.5
difference- 1.5/3.5
/2= .75/1.75
beginning RH= 5.75/6.75
Always set RH first, then droop.
His goal in using this method is not to have to reset RH or droop after every run- set it for optimum settings at the smallest dia, then let it be what it beez at any other diameter...lol
BigDogRacing is offline   Reply With Quote
Old 09-12-2010, 01:15 PM   #5666
very interesting, I will have to give that a try
Old 09-14-2010, 03:58 AM   #5667
Doug M's Avatar
Default Novarossi Challenge @ Homestead Super Raceway
Doug M is offline   Reply With Quote
Old 09-14-2010, 10:33 AM   #5668
FF25510's Avatar
Default NT1 World Champion Limited Edition
That is
http://www.teamxray.com/teamxray/new...9d67931e62cee7
FF25510 is offline   Reply With Quote
Old 09-14-2010, 10:39 AM   #5669
JLock's Avatar
Originally Posted by FF25510 View Post
Does the kit include Ralph Burch for driving purposes?!?!
Texas 5
It's not what you know; it's what you can prove.
The only thing that is for sure is that nothing is for sure!!!
The needs of the many outweigh the needs of the few, or the one.
There are 2 things in life that are infinite: the universe and stupidity.
JLock is offline   Reply With Quote
Old 09-14-2010, 11:25 AM   #5670
Where can u purchase one from?
younghovaa is offline   Reply With Quote
