Like Tree6Likes
Old 03-10-2010, 09:15 AM   #5011
ToysRUsKid's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to ToysRUsKid
Originally Posted by Riketsu View Post
#1 - Dont have his phone #
#2 - Forum = Information Super Highway
True, everyone is not privileged enough to have direct access to D-Nicest
I still say change the the thread to "Ask Diatta Collymore (RC America)"
Dorian Tisdale - Professional RC Driver Wannabe
ToysRUsKid is offline   Reply With Quote
Old 03-10-2010, 10:38 AM   #5012
ttso's Avatar
So.. back on NT1 topic...
Anyone got 2010spec car already? mind to take a comparison photo with 2009spec?
ttso is offline   Reply With Quote
Old 03-10-2010, 11:00 AM   #5013
RC MARKET's Avatar
updated 4 items !
RC MARKET is offline   Reply With Quote
Old 03-10-2010, 11:19 AM   #5014
ttso's Avatar
Originally Posted by RC MARKET View Post
updated 4 items !
Damn I type too fast before explain clearly...
To take photo comparison of 2F carbon fiber deck to show difference between 2009spec and 2010spec.
Old 03-10-2010, 01:16 PM   #5015
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
I don't know exactly what changed from V1 to V2, but V2 to V3 the pipe side of the top deck got narrower to better match the flex of the topdeck on the servo side.
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 03-10-2010, 02:20 PM   #5016
DS Motorsport's Avatar
They also removed some material on top of the steering servo.
I already cut one of my tray's to the 2010 spec, always interesting to test.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 03-10-2010, 02:23 PM   #5017
rx7ttlm's Avatar
top of the steering servo? pictures please..
Old 03-10-2010, 02:30 PM   #5018
Look at the distance from the outer edge to the big holes which the steering servo bracket secures into, and now check your 2008-2009 radioplate.
P1-RC.com
Last edited by DS Motorsport; 03-10-2010 at 02:32 PM. Reason: Xray doesn't allow to hotlink
Old 03-10-2010, 05:11 PM   #5019
Trader Rating: 13 (93%+)
I just built my nt1 2010 spec and its awesome
i built itw ith the fornt lightweight spool and front lightweight shaft, im just waiting till the parts come in stock to buy the lightweight 2 speed shaft and brake adapter
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 03-10-2010, 05:13 PM   #5020
when using the short wheelbase i notice you lose some caster..so i guess just put all the caster clips to the front and the caster angel should still be in the neutral position
any one have some tech advice on this?
Old 03-10-2010, 05:23 PM   #5021
Yes if you shorten the wheelbase you should move the upper arm the amount as the lower arm i.e. if you shorten the wheelbase by 2mm and you normally run 2mm of casterclips behind the upper arm you end up putting all the clips in front of the upperarm
P1-RC.com
Old 03-10-2010, 06:24 PM   #5022
Osiris 75's Avatar
Trader Rating: 17 (100%+)
I also cut my upper arms by 2mm's, and place a 2mm shim to allow the upper arms to be moved back as well as the lower arms.
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 03-10-2010, 08:07 PM   #5023
rx7ttlm's Avatar
change the caster shims the same amount as you change the wheelbase.
Old 03-10-2010, 08:14 PM   #5024
yeh i dont think i need to go to the extremes of cutting the top arm mount 2mm back..
Old 03-10-2010, 08:28 PM   #5025
cheROK1212's Avatar
cut the arm, not the mount
...hold my 'stones.
cheROK1212 is offline   Reply With Quote
