Like Tree7Likes
Old 06-14-2009, 12:21 AM   #4186
Check this video out of the Xray Nt1 laying the smackdown at the local track.
http://www.youtube.com/watch?v=1JnNimuBins
robzzz is offline   Reply With Quote
Old 06-14-2009, 05:26 PM   #4187
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
Was this taken in KY or IN?
Am I going back racing?...Hmmm.. Not anytime soon... But soon enough.
rcfoolz is offline   Reply With Quote
Old 06-15-2009, 10:17 AM   #4188
Originally Posted by meronr View Post
gianni beautiful driving at the Cap see you at the GLC right?
thanks my friend....very good weekend... and yes maybe see you there at GLC
take care
ciao
gianni
gianni.giorgio is offline   Reply With Quote
Old 06-17-2009, 10:31 AM   #4189
Default x ray gears
Hey there guys I have been running the nt1 for a couple of years now, and I feel that it is a great handling car, however I am becomming ever so frustrated with stripping 2nd gear during a main. This has happened almost everytime in the last year. I run a red dot motor and I like it a lot for the price, my friend also runs an nt1 and he says that it is the peco motor. I just find it hard to believe that the motor can be the problem because when i install the spur gears the mesh is perfect so i just don't get it. I am to the point where i am ready to get rid of the car for something else. Maybe the new velox.
mrod is offline   Reply With Quote
Old 06-17-2009, 10:40 AM   #4190
ToysRUsKid's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to ToysRUsKid
I would say check for tweak in the car and make sure all your screws are tightened. I haven't heard of many stripping gears with this car, especially those running the picco motors. Have you ever crashed? Check to make sure your rear bulkheads are not cracked or cracking. Also, check the mesh of the gears with the bigger gear off. Make sure the second gear is mesh correctly, then put on the first gear and make sure that's meshed correctly, then pop on the e-clip.
Dorian Tisdale - Professional RC Driver Wannabe
ToysRUsKid is offline   Reply With Quote
Old 06-17-2009, 11:25 AM   #4191
Mr. MR4's Avatar
Mrod, check the following link regarding 2 speed rear shaft wear.
http://www.teamxray.com/teamxray/new...2f71ab5d42f5a1
Xray T4'16 HobbyWing Xerun 120A V3.1
Xray X1'16 HobbyWing Justock
Yokomo R12C3 HobbyWing Xerun V3.1
Mr. MR4 is offline   Reply With Quote
Old 06-17-2009, 11:30 AM   #4192
GK
Suspended
GK is offline   Reply With Quote
Old 06-17-2009, 11:34 AM   #4193
MackanG's Avatar
I had the same problem last weekend. I changed the 1st gear drive flange (#335530), problem solved.
MackanG is offline   Reply With Quote
Old 06-17-2009, 11:55 AM   #4194
thanks guys, however I have tried all of these things, i replaced the whole rear end of the car with new parts, the bulkheads, bearings shaft and even the one way and I am still stripping 2nd gear. I think the time has come to just give up on the car, it is sad because it is a great handling car but i am spending a fortune on gears and it is just becoming to frustrating.
Old 06-17-2009, 01:42 PM   #4195
grub's Avatar
check your servo travel if you have to much travel it will pull on the carby causing the engine to move just enough to stuff the gears ,also what gear split are you running this cause me plenty of head aches
This is my xray nt1!
There are many other xray nt1's like it, but this one is mine!
Without my xray nt1,I am nothing!
Without me, my xray nt1 is nothing!
pop corn anyone or maybe some fairy floss
grub is offline   Reply With Quote
Old 06-17-2009, 02:55 PM   #4196
Mr. MR4's Avatar
Have you checked that the chassis is not bent?
Old 06-17-2009, 03:57 PM   #4197
aizenbelle's Avatar
Make sure your mesh is good and add threadlock to your engine mount screws. After I had my engine for a while it starter shaking more than usual and that cause the engine to move just enough to strip my gear. Once I started using the threadlock my problem was solved. You must let the threadlock dry completely.
Don't Blame it on the car when you know you cant drive
X_ray Nt_1 08
RRR WC (For sale!!)
G4+EVO
G4RS 09' (IT'S FINALLY HERE!!!!!) Serpent 733 put on hold!!
aizenbelle is offline   Reply With Quote
Old 06-17-2009, 10:56 PM   #4198
Osiris 75's Avatar
Trader Rating: 17 (100%+)
Believe me, it's th Picco engine!!
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 06-18-2009, 03:28 AM   #4199
freestyles's Avatar
Trader Rating: 14 (100%+)
I agree. I remember reading something about this earlier in the thread. I think the problem was the collet if i remebmer correctly.
This public service announcement was brought to you by the letter "B" and the number "9". Thanks for watching.
freestyles is offline   Reply With Quote
Old 06-18-2009, 07:43 AM   #4200
aussies1129's Avatar
Trader Rating: 74 (100%+)
I have experienced on a few occasions with the picco engines which includes the evo3 and edo tune that the bearings fail which creates a small wobble in the shaft which caused me endless dramas with stripping gears.
change your bearings and see how that goes.
cheers
Proudly supported by......
Premier Model Supplies Pty Ltd
H.E.I AUSTRALIA
XRAY*****PRO-LINE*****HUDY*****
-----FUTABA-----NOVAROSSI-----
aussies1129 is offline   Reply With Quote
