Like Tree7Likes
Old 06-09-2009, 10:56 PM   #4171
asw7576's Avatar
Originally Posted by ah_DaN View Post
Can the fuel tank be too low?
I lowered my fuel tank and the bottom is 1mm sticking out of the bottom chassis.
When the car is bottoming out, the lowest base of tank will be at risk of damage. Not worth it..... xray tank is quite expensive. I guess you can raise the tank around 2mm higher from the lowest point ( bottom of chassis ). Don't forget to take some inspirational photos for us.
Old 06-09-2009, 11:02 PM   #4172
Trader Rating: 13 (93%+)
Default nt1 clean sweep!!
Xray NT1 clean sweep last weekend
Tq, 1 2 3 at Bumod GP Turkey
Tq, 1 2 3 at 301 capital classic
Good work Team Xray!
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 06-10-2009, 08:47 AM   #4173
Scott Rister , finished 6th, with his Xray in Turkey.
He was 1 of only 2 Americans to go.I also heard he got some great pit work from DJ from serpent.
WARDO is offline   Reply With Quote
Old 06-10-2009, 08:30 PM   #4174
aizenbelle's Avatar
Nice!!!!
Don't Blame it on the car when you know you cant drive
X_ray Nt_1 08
RRR WC (For sale!!)
G4+EVO
G4RS 09' (IT'S FINALLY HERE!!!!!) Serpent 733 put on hold!!
aizenbelle is offline   Reply With Quote
Old 06-11-2009, 08:00 AM   #4175
Osiris 75's Avatar
Trader Rating: 17 (100%+)
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 06-12-2009, 11:38 AM   #4176
fastrcracer's Avatar
I have another question about the aluminum wheel hexes !
In an earlier post I was told to use the -.75 hexes. Most of the team driver setups show the -.75 hexes.
What is the benefit with using these over the 0 or +.75 hexes besides altering the track width without changing the pillow balls.
Also with standard 0 offset tires and the -.75 hexes, the inner side of the tire rubs on the hub carrier where the upright attaches.
Any setup advice would be helpful.
Associated FT SC10
Futaba 3PK
AKA Tires
Maxamps Batteries
SRI Raceway, Louisville KY
fastrcracer is offline   Reply With Quote
Old 06-12-2009, 12:58 PM   #4177
asw7576's Avatar
People use 0 or +.75 front wheel hexes because they still use dog bones. Even 0 wheel hex still can make front dog bone to fly out upon side impact ( mine did ). With 0 : Use 3mm thin foam, coin type , or soft silicone O ring, and put it inside front outdrive cup to lessen dog bone lateral movement. With +.75 : no need foam.
+.75 on the rear is suitable for extra wide eg. 202mm track width, or u want to use 32mm width tires ( eg. kawahara 32mm width tires )
Old 06-12-2009, 01:35 PM   #4178
musti72's Avatar
But he has a different problem... He says that with -0.75 hubs, tire rubs to upright. I dont have any optional hubs yet but Im planning to have some, so anyone have some knowledge about this?
Mustafa Alp
http://www.aytemizhobi.com
Turkish shop for: Serpent, Xceed, Sweep Racing, MyLaps
musti72 is offline   Reply With Quote
Old 06-13-2009, 05:06 PM   #4179
when used +.75 or 0 you less stering or rear traccion , on capitol classic 301 we used -.75 and the car was works great .
ciao
gianni
gianni.giorgio is offline   Reply With Quote
Old 06-13-2009, 09:30 PM   #4180
meronr's Avatar
ciao
gianni
gianni beautiful driving at the Cap see you at the GLC right?
Meron Rubinowitsch
meronr is offline   Reply With Quote
Old 06-13-2009, 09:38 PM   #4181
Default Rear Gear Diff Leak
can someone please give me an idea why...
the rear gear diff leaks oil through one of the screw holes...even when screw is done right up, and flush with the plastic.
should i undo completely and re-fill up to the advised level of instructions??
Glenn is offline   Reply With Quote
Old 06-13-2009, 09:40 PM   #4182
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
Meronr I heard your car was a rocket at the Cap, which engine were you running.
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 06-13-2009, 09:54 PM   #4183
Team Kamikaze's Avatar
That explains why he kept on swallowing FIRE
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 06-13-2009, 11:21 PM   #4184
freestyles's Avatar
Trader Rating: 14 (100%+)
Definatley fill your diff to where it says in the book, any more and it will probably leak. When you do up the screws on the diff are you tightening them in the "criss cross" pattern that they suggest? If not maybe there is a bit to much pressure on one side causing it to leak out the other. Something to keep in mind anyways
This public service announcement was brought to you by the letter "B" and the number "9". Thanks for watching.
freestyles is offline   Reply With Quote
Old 06-13-2009, 11:21 PM   #4185
meronr's Avatar
I was running a RB MODS 353 '09 engine.....And yes I swallow fire....just bring me a book of matches and I'll show anyone, just bring me a book of matches
Meron Rubinowitsch
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
