Like Tree7Likes
Old 06-07-2009, 04:30 AM   #4156
freestyles's Avatar
Trader Rating: 14 (100%+)
Originally Posted by 1995_corvette View Post
I am looking at getting a NT1 09 and was wondering 2 things...
1) What servos ya'll using?
2) What motor ya'll using?
I am been racing electric the lat 2 or so years and have not been in the nitro motor loop for a bit..
Thanks..
I'm using hitec servos and the RB speedline with an ATS pipe.
Originally Posted by RC MARKET View Post
I really like the looks of those allum. top plate stands with extra side belt tensioning and the one piece engine mount. Might have to order some
I have a quick question. Is there a way to stop the fuel from spitting out when refueling? When my car is running and you try to refuel it when it get's 3/4 full it starts spitting fuel out everywhere. I'm using the standard Nimh RX pack.
This public service announcement was brought to you by the letter "B" and the number "9". Thanks for watching.
freestyles is offline   Reply With Quote
Old 06-07-2009, 05:39 AM   #4157
fastrcracer's Avatar
Just bought a new Spec 2008 NT1. Does the rear tires need to be the 1 degree offset type ?
I put 0 degree offset on and they rub the hub carriers.
Associated FT SC10
Futaba 3PK
AKA Tires
Maxamps Batteries
SRI Raceway, Louisville KY
fastrcracer is offline   Reply With Quote
Old 06-07-2009, 12:19 PM   #4158
asw7576's Avatar
Use allumunium wheel hex adapter +75 at rear and 0 at front.
Old 06-08-2009, 10:36 AM   #4159
Nitro-Racer*'s Avatar
i have a question about how to set up my clutch. first of all what does clutch end play do and what are the advantages and dissadvantages. my main question is:
should the clutch bell rub on the clutch when pushed backwards? till now it was like that set up. thank you
Xray Nt1-Novarossi 3sct-KoPropo-GRP-Altis 2.3-RB Fuels
Xray 808 09-RB Killer 9-Hitec-KoPropo-RB Fuels
Nitro-Racer* is offline   Reply With Quote
Old 06-08-2009, 04:27 PM   #4160
grub's Avatar
no your cluch should not touch the shoe and the end play is inportant to big a end play you will destroy your thrust bearing and to small a gap it will cause the clutch too drag when the clutch heats up,try for .01 end play
This is my xray nt1!
There are many other xray nt1's like it, but this one is mine!
Without my xray nt1,I am nothing!
Without me, my xray nt1 is nothing!
pop corn anyone or maybe some fairy floss
grub is offline   Reply With Quote
Old 06-09-2009, 04:58 AM   #4161
sorry but i still can not understand. the only thing that i understood is that the clutch bell should not touch the clutch shoe....
Old 06-09-2009, 05:13 AM   #4162
grub's Avatar
sorry my engrish not very good
if you have to big an end play you are more likely to kill your thrust bearing
to small an end play your cluch will not engage properly after the clutch bell heats up
try for a 0.1 end gap
Old 06-09-2009, 05:49 AM   #4163
ok i now undrestand better but arent you talking about the clutch gap, when it is more you will kill your thrust bearing??
Old 06-09-2009, 06:58 AM   #4164
grub's Avatar
no to big a clutch gap you will loose the fly weights..
your gap is set first with the inner bearing taking out
the shims are placed in frount of the thrust bearing.... i use .5 gap
then the end play is set last with the bearing put back in
and the shims placed in frount off the inner bearing on the crank shaft ...
hope this helps
Old 06-09-2009, 07:51 AM   #4165
ok we are getting somewhere!!! i think i understand fully now
Old 06-09-2009, 07:57 AM   #4166
Pattojnr's Avatar
Trader Rating: 19 (100%+)
so your not confused again, Grub says
in order.... clutch nut- shims (for endplay) inner bearing- outer bearing-thrust bearing- shims (clutch gap) then retainer.
clutch gap set first with no inner bearing nor shims on the retainer.
push the bell onto the shoe, measure distance to retainer to first pinion = 1.2mm . pull bell to thrust bearing, then measure the same = 0.2 this equals a clutch gap of 1mm (these measurements are a made up figure to help explain)
so 1mm clutch gap you have. now put 0.4mm of shims on the retainer to have a desired 0.6 clutch gap. refit inner bearing, then reassemble the clutch. now keep adding shims inside before the inner bearing to achieve the 0.1mm endplay
hope this helps
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 06-09-2009, 02:10 PM   #4167
ok thanks a lot for the help
Old 06-09-2009, 03:00 PM   #4168
ah_DaN's Avatar
Can the fuel tank be too low?
I lowered my fuel tank and the bottom is 1mm sticking out of the bottom chassis.
ah_DaN is offline   Reply With Quote
Old 06-09-2009, 04:31 PM   #4169
DS Motorsport's Avatar
How much did you lower it?.
But no you don't want it to be sticking out, as is will damage it.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 06-09-2009, 09:36 PM   #4170
ah_DaN's Avatar
I ll raise it up. Its lowered 6mm, but still have some space between my xceed lipo and the tank.
