Like Tree6Likes
Old 12-16-2008, 01:12 AM   #3586
RC MARKET's Avatar
Originally Posted by rx7ttlm View Post
la la la engine cleaning time, So remember kids. Even if MF himself plays with your engine, TAKE IT APART AND CLEAN IT! lol. Found a buncha crap in my new engine tonight. Al chips, a piece of sand in the carb, brass shavings in the HSN body. Super bad engine tho.
getting ready for winternats
how many L oil to rebuild your engine ?
RC MARKET is offline   Reply With Quote
Old 12-16-2008, 01:40 AM   #3587
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
Originally Posted by asw7576 View Post
How is front bearing's seal ?
seals good, why?
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 12-16-2008, 01:41 AM   #3588
rx7ttlm's Avatar
Originally Posted by FF25510 View Post
sure!! i found my MF with a "click" in front bearingthe engine was brand new. also 3 piece of al chips was found inside my OS tz5. so YOU MUST CLEAN IT....
I never run an engine without checking it myself...
Old 12-16-2008, 01:44 AM   #3589
rx7ttlm's Avatar
how many what? How many Liters? Haven't had to rebuild one yet (piston / sleeve that is) . I usually replace O rings every gallon or so. Thats it. I tear down the engines after I run them, Clean them and inspect parts.. Just got my XXL3 last night so I will let you guys know..
Old 12-16-2008, 02:07 AM   #3590
rx7ttlm's Avatar
next step is modifying carb venturi
Old 12-16-2008, 02:12 AM   #3591
asw7576's Avatar
seals good, why?
I'm just reminding you while you have dismantle the engine that much, then why not to check or replace it.
Old 12-16-2008, 02:14 AM   #3592
FF25510's Avatar
me too, because engine cost too much.
FF25510 is offline   Reply With Quote
Old 12-16-2008, 02:32 AM   #3593
asw7576's Avatar
R u going to enlarge the hole ?
Back to 1993, I have two Kyosho GP10 kit. The kit comes with GSX-11 kyosho engine with barrel type carburator. I drilled the carburator air intake. The carburator barrel is made from soft metal, so I can press drill quite easy. I also enlarge the hole in carburator intake opening. So all together, the air intake holes are noticeably bigger than standard kit engine.
I fired up the engine, and TADA !!! I notice significant improvement in acceleration and top speed. The idling noise and acceleration are louder.
Old 12-16-2008, 02:33 AM   #3594
rx7ttlm's Avatar
probably because that's a brand new engine.............
Old 12-16-2008, 02:35 AM   #3595
rx7ttlm's Avatar
Back to 1993, I have two Kyosho GP10 kit. The kit comes with GSX-11 kyosho engine with barrel type carburator. I drilled the carburator hole. The carburator barrel is made from soft metal, so I can press drill quite easy. I also enlarge the hole in carburator intake opening. So all together, the air intake holes are noticeably bigger than standard kit engine.
not going to make the hole bigger, will still be 5.4mm. We have found that when you make the venturi larger, you lose flow velocity.... ie lose bottom end and a bit of torque. if you notice, the novarossi based carbs have a step where the 5.4 is printed. that is getting radiused. or maybe replaced with OS 5.4 they already have it all setup.
Old 12-16-2008, 12:27 PM   #3596
AddictedToRacin's Avatar
I'm only once, as Adrien Bertin assembled it for me
But even at my other engines I didn't have any problems with that.
I'm looking forward to hear how your engine runs. Max-engines were always good.
AddictedToRacin is offline   Reply With Quote
Old 12-16-2008, 07:33 PM   #3597
rx7ttlm's Avatar
well I have run the XL3's and they kick ass.. I have an XXL3 that I got yesterday and I am going to get that ready aswell.. should be good.. I have arranged to have it dyno'd as well
Old 12-17-2008, 03:58 AM   #3598
GEO
GEO's Avatar
Send a message via MSN to GEO
My first test with NT1 was very good. The car on the track was very stable with almost stock setup. My car was pretty smooth at the corners in low or high speeds. I intend to try the Ankerman A-D to get more steering and both the exit of turn and at the entrance. I also want to try and yellow clutch shoe except the white. I think that the white clutch shoe made my car more smooth. In my first race, the track hadn't enough grip. Then my car was bad. I tried to use 35f and 37r foam tires and it was enough to pass at the the A-main final. Almost with stock setup. I'm really happy from the performance of my car
Xray NT1 | RB modified NDS TECH | Hot Race | ORCAN | FUTABA
FANATIX MODELS - TEAM XRAY GREECE - RB PRODUCTS
GEO is offline   Reply With Quote
Old 12-18-2008, 04:37 AM   #3599
RC MARKET's Avatar
in small track with hairpin turn,
use which Shock oil & Spring ?
Thankyou !
Old 12-18-2008, 04:47 AM   #3600
rx7ttlm's Avatar
Thankyou !
grip? with decent grip I usually start in the pink range(light purple as xray calls it), 600/1 F and 600/2 R, front arm at top roll center position(one up from stock), rear roll center inner arm pivot one up from stock(raising rear roll center), rear diff 80k (I run as thick of oil as I can without snap oversteer), spool front. maybe try violet all around if the grip is low, and also drop the weight of the rear diff oil, and play with shock oil, another combo that works well sometimes is 600/2 and 500/1 or 2. the heavier diff oil and roll center changes seem to be the biggest changes.front bar flat if stock, about 45 degrees if you have the .7 bar. cheers.
