Like Tree7Likes
Old 09-14-2008, 10:46 PM   #3406
asw7576's Avatar
Originally Posted by rystang View Post
Hello Gents,
I don't own a NT1 but have been doing a little research lately on 2 speeds and the available gears......which is how I stumbled onto the NT1. I have a RC Drag car that uses a Mugen centax clutch and a Mugen two speed(MTX3). The two speed hubs or carriers ride on a 6mm shaft. My queston is does anyone know if the X-Ray gears will bolt to the Mugen carriers...they look simular online but its hard to tell from just looking at pictures. The other queston is what size is the X-Ray mid-shaft that the two speed rides on, if its 6mm then I could possibly use the X-Ray carriers if the gears are not adaptable to the Mugen carriers. Last Queston is....on the X-Ray clutch bell, do the Mugen(MTX3) gears interchange?
Thanks in advance for any and all help.
Rey
I think you better stick with what you have now ( mtx3 ).
You have to buy complete set of NT1 2speed assembly ( gear, housing, clutch, etc ) to make it work.
They are not interchangeable.
Old 09-14-2008, 10:58 PM   #3407
Thanks guy's, I appreciate your input. By the way if its possible could some one please give me a dia. measurement on the 2 speed shaft anyway.
rystang is offline   Reply With Quote
Old 09-15-2008, 03:47 AM   #3408
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
The dia. is the same.
Am I going back racing?...Hmmm.. Not anytime soon... But soon enough.
rcfoolz is offline   Reply With Quote
Old 09-15-2008, 07:48 AM   #3409
So its 6mm .....right?
Old 09-15-2008, 12:03 PM   #3410
Xray prince's Avatar
not sure the size.......but i once used a mugen 1st gear housing on my Nt1.....just had to dremel the 3raised portions on the xray gear.....most of those parts on the Mugen/xray are close enough to make work,,,,,,ur dealin with almost a mugen copy!!!
pilot for Kyosho's RRR Evo WC
Ko 2413's....DX3R...JPfx3
Subaru IGT,C5 rody mod onroad,M8
Xray prince is offline   Reply With Quote
Old 09-15-2008, 12:19 PM   #3411
jk1152's Avatar
NT1 doesn't strip gears like the Mugen, unless you have a Picco based engine then you might have a melting gear problems.
jk1152 is offline   Reply With Quote
Old 09-15-2008, 08:20 PM   #3412
Thanks again guy's for the quick resonses. I'm going to order a couple of the NT-1 spurs and check the fit on the Mugen carriers...if they don't work out I'l probably order the NT1 carriers since they also ride on a 6mm shaft.
Do any of you gents have a extra set of carriers you don't need??? Drop me a PM if you do.
Old 09-15-2008, 08:28 PM   #3413
Trader Rating: 24 (100%+)
the spurs will not fit on the mugen
RANDY SMOOTH is offline   Reply With Quote
Old 09-15-2008, 10:27 PM   #3414
Gseventeen's Avatar
Originally Posted by meronr View Post
what about the graphite parts do they go in the oven as well
Geez yeah, stick the whole lot in. We often put a new car in with a roasting chook on Sundays , but a couple of times now it has worked so well we ate the car and raced the chook!!!!!!:l ol::lo
NEW CAR (watch this space) POWER:NOVA 353 TUNED, JP BLACK MODDED,OS SPEC11
SPONSOR= EDV ELECTRICAL!! 9699-9961
'' THE LAD COMING BACK SOON!!!!
Gseventeen is offline   Reply With Quote
Old 09-16-2008, 03:02 PM   #3415
Strange... I've run a picco on my NT1 for over 6 months and never experienced a melted gear. Where did you hear this from?
Lycan is offline   Reply With Quote
Old 09-17-2008, 11:41 AM   #3416
rwhit's Avatar
Send a message via Yahoo to rwhit
Default Set up tips for Nor-cal
Hey Guys, I'm a proud new owner of a NT1 and I was wonder if any one had a set up for a med size technical parking lot track. thats sometimes has med to high traction.
And what kind of tires works well on this car I have Exceed but I herd Nitro Shoes work good.
R.W
rwhit is offline   Reply With Quote
Old 09-17-2008, 01:49 PM   #3417
grub's Avatar
i run kawahara
try kawahara tyres on a low tractions track will stick like glue
iv tryed nitro shoes but the kawahara were the better tyre on low traction parking lot tracks
This is my xray nt1!
There are many other xray nt1's like it, but this one is mine!
Without my xray nt1,I am nothing!
Without me, my xray nt1 is nothing!
pop corn anyone or maybe some fairy floss
grub is offline   Reply With Quote
Old 09-18-2008, 05:34 PM   #3418
RC MARKET's Avatar
Originally Posted by grub View Post
i run kawahara
Yes Kawahara Tire had more grip !
RC MARKET is offline   Reply With Quote
Old 09-18-2008, 07:39 PM   #3419
jk1152's Avatar
Not to get into who makes the rubber and all. But Exceed has Jaco name on the back of the box and Nitro Shoes have Jaco's name on the back of the box also.
Exceed still uses the old "Serpent" style. Nitro Shoes have updated to a "Prism" style rim that is supposed to be better performing then the traditional "Serpent" style.
I think either are good. It comes down to having a few different flavors available to you as track conditions change or if it's a new track you haven't been too.
I try to keep 38,40, 42 shores fronts with me. 40 and 42 for the rear. I even have some 45's for messing around but don't think I would race with 45's. It's also fun to get the "rear" of the car dialed in as close as you can on 45's then switch to 42's it makes a big difference. I will mess with the front shore to get more "turn in" the softer I go as a setup change.
Old 09-18-2008, 07:40 PM   #3420
jk1152's Avatar
In this thread.
