Like Tree6Likes
Old 08-29-2008, 08:58 PM   #3361
grub's Avatar
Originally Posted by ToysRUsKid View Post
Before you flame me about search, I tried already and didn't get a good answer...Do any of you guys use a lipo pack and if so which one? I had a protek 1300mah pack that fit perfectly but the wire was torn and now they don't sell them anymore so I need another pack. I need something with a standard JR/Futaba style connector, any suggestions?
im been using this one for the last year with no problems
you can also get the 5500 regulator desinged for the spektrum users
Part No: VX-LRX-211300
VXR Racing Receiver Pack - Li-Po, 1300mAh, 2S1P, 7.4V
Capacity: 1300mAh Weight: 61 grams (including wire and connector) Li-Po cell arrangement: 2S1P Norminal voltage: 7.4 Volts Discharge capability: 10C Dimension(mm): 83 x 28 x 13 Connector: JST - RCY Polarized Recommended Application: 1/10th GP & 1/8th GP
heres the link
http://rcplanet.com.my/webshaper/sto....asp?catID=363
hope this helps
grub is offline   Reply With Quote
Old 08-29-2008, 10:38 PM   #3362
godzukihop's Avatar
Trader Rating: 31 (100%+)
Originally Posted by opposite lock View Post
Can anyone lend me some info on maintenance for the one way bearing on the 1 st gear?Seems to not engage some times.What to clean with and what to lube with?
I had the same problem, called Ashford Hobbies and he sold me Serpent one-way lube. Works perfect now. You do not want to put any grease or oil on the shaft or bearing, just the specific one-way lube.
godzukihop is offline   Reply With Quote
Old 08-29-2008, 11:03 PM   #3363
Only if you knew what that Serpent one-way lube really is...
Baedarlboo is offline   Reply With Quote
Old 08-29-2008, 11:21 PM   #3364
heres the link
hope this helps
use the novak regulator it's tiny
TomB is offline   Reply With Quote
Old 08-29-2008, 11:38 PM   #3365
blackyblackman's Avatar
Hello!
I use this one:
Regards, Michael
blackyblackman is offline   Reply With Quote
Old 08-29-2008, 11:54 PM   #3366
Hello!
Has someone find out which parts can be used on the NT1 from other manufacturers?
Example:
I can use the gears from my MTX4!
Also the clutch.
Are there other parts??
Regards, Michael
Old 08-30-2008, 01:18 AM   #3367
asw7576's Avatar
Originally Posted by blackyblackman View Post
Hello!
Example:
Also the clutch, the brake disk and the brake pads.
Regards, Michael
MTX4 Front Uprights ( but must use mtx4's pivot balls, bearings, CVD, hexagonal wheel hub )
MTX4 Suspension Dampers Complete Set.
MTX4 or MRX4 hexagonal metal ball connector holder and plastic connectors.
Old 08-30-2008, 01:31 PM   #3368
bboy's Avatar
I have a problem with my NT1. I have been running my OS 5 port the last couple weeks and it was running great. I switched to my regular 3 port today and unfortunately the first gear would not engage.
The engine would rev up, but the clutch/pinion does not spin/engage. It spins a little at idle, but it refuses to engage even at max RPM. I took apart the clutch and eveything seems fine and both the spur gears spin fine. I am using the yellow clutch shoe and the silver spring.
I am thinking this must be something stupid. Any body any ideas?
Serpent 960-08 + Max XL9
XRay NT1 + Max XXL3
bboy is offline   Reply With Quote
Old 08-30-2008, 04:25 PM   #3369
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
does anyone know how many teeth does the rear diff have?
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 08-30-2008, 05:18 PM   #3370
ToysRUsKid's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to ToysRUsKid
is the clutch nut too loose? Only thing I can think of other than the clutch bell being too tight but you said it spins a bit in idle.
Dorian Tisdale - Professional RC Driver Wannabe
ToysRUsKid is offline   Reply With Quote
Old 08-30-2008, 06:03 PM   #3371
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
The rear diff has 41 teeth. The front has 27. I took the time to figure out the overdrive of the front with different gears. You can have it at: 99.9 103.9 105.4 109.6 by changing the side pullies around.
Am I going back racing?...Hmmm.. Not anytime soon... But soon enough.
rcfoolz is offline   Reply With Quote
Old 08-30-2008, 06:05 PM   #3372
rcfoolz's Avatar
two thing to check. Look at the amount of end play/clutch gap. you could have too much gap and if the end play is way out there, you won't engage. Or the spring nut is too tight.
Old 08-30-2008, 10:58 PM   #3373
Riketsu's Avatar
Thanks Rcfoolz... NT1 instructions didnt say, nor anywhere on the internet...
Old 09-02-2008, 11:27 PM   #3374
Default 19T Side Pulley
Hi guys, has anyone actually tried the 19t/26t side pulley combination yet, and if so what was the out-come, thanks heaps.
warpspeed57 is offline   Reply With Quote
Old 09-04-2008, 12:25 AM   #3375
jk1152's Avatar
The MTX4 thrust bearing works also, it's the same size, but instead of ~18-20 it's only ~10 dollars.
Hello!
Example:
Also the clutch.
Regards, Michael
jk1152 is offline   Reply With Quote
