Like Tree6Likes
Old 07-28-2008, 09:43 PM   #3316
bvoltz's Avatar
Trader Rating: 44 (100%+)
Originally Posted by TeamCarnage View Post
Barry- I went thru my racer yesterday. I would sacrifice the plastic gear and dremel a slot in the screw and back it out.. Hope this helps!
My problem is the head of the screw is gone... I tried to drill it, but this did no work.... and the screw is to small to cut a slot in it....
Wheeling an Xray T4 and T4 14 using a Ko Propo, powered by EA motors and Speed Passion Speedo, paid for by my wife.
Digi3Dworks - 3D printing for the medical Field.
bvoltz is offline   Reply With Quote
Old 07-31-2008, 07:05 PM   #3317
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
Lowered the weight by 1.1grams........30% weight reduction..
Am I going back racing?...Hmmm.. Not anytime soon... But soon enough.
rcfoolz is offline   Reply With Quote
Old 07-31-2008, 09:38 PM   #3318
how did you drill the holes so acurately? and what drill bit size did you use for the internal and external holes?
TomB is offline   Reply With Quote
Old 08-01-2008, 12:44 AM   #3319
asw7576's Avatar
WOW.... handmade ??
I rather go for titanium screws and lipo batt
Old 08-01-2008, 02:55 AM   #3320
rcfoolz's Avatar
The outter holes are 1mm and the inner are 3mm. Did with a dremel by hand.
Originally Posted by asw7576 View Post
WOW.... handmade ??
Yea, I thought about that too. Just got bored and started tinkering. Should see the shaft spacers Wanted to work on removing rotating mass. Every little bit helps, right?
Going to test them on a high bite track this weekend for durability.
Old 08-01-2008, 03:38 AM   #3321
asw7576's Avatar
Good luck friend.
Take your time,
Old 08-01-2008, 05:38 AM   #3322
Trader Rating: 24 (100%+)
if you need help with your car this is the man to talk to, keep up the good work james. see you sunday
RANDY SMOOTH is offline   Reply With Quote
Old 08-01-2008, 09:56 PM   #3323
And he is extremely helpful too!
air jordan is offline   Reply With Quote
Old 08-01-2008, 11:04 PM   #3324
I'm running the Nt1 and have a question. I run the 26T side pulley and running my front tires 1mm smaller then the rears is that the right split to run with the 26T Pulley ? Also if I keep my 1mm split and use the 25T Pulley will that give me more or less steering? Is there somewhere on the xray site that tells you want spilt to run I have seen people run no split and have seen people run a 2mm split I kind of lostů
John Q is offline   Reply With Quote
Old 08-02-2008, 04:06 AM   #3325
rcfoolz's Avatar
PM sent..
Old 08-02-2008, 05:13 PM   #3326
One technique is to make your own sticker with the drill pattern on it.
You need
1) A computer with some sort of drawing software. e.g. Adobe Illustrator
2) Clear sticker paper
3) A printer
Stick sticker on part and start drilling. This idea would also work on a brake disc as well but you need a very hard tipped drill to cut steel.
going4#1 is offline   Reply With Quote
Old 08-03-2008, 03:17 AM   #3327
grub's Avatar
rc foolz ygpm
This is my xray nt1!
There are many other xray nt1's like it, but this one is mine!
Without my xray nt1,I am nothing!
Without me, my xray nt1 is nothing!
pop corn anyone or maybe some fairy floss
grub is offline   Reply With Quote
Old 08-03-2008, 03:53 AM   #3328
rcfoolz's Avatar
Originally Posted by grub View Post
rc foolz ygpm
Pm'd you back. Thanks for the update!
Old 08-07-2008, 12:38 AM   #3329
what kind of gear combo was everyone running at the Great lakes challenge
infernoman2008 is offline   Reply With Quote
Old 08-07-2008, 05:41 AM   #3330
meronr's Avatar
17/23 55/60
Meron Rubinowitsch
meronr is offline   Reply With Quote
