Like Tree7Likes
Old 07-17-2008, 03:52 PM   #3256
deviltires's Avatar
im having problems with my side belts after a full race day my side belt has about 5 to 10 teeth missing and that is after every race i have changed pulleys front and backand it still end up missing teeth does anyone has an idea of what that could be
DARNELL WASHINGTON-- TEAM MUGEN----FUTABA 4PK--HOT RACE TIRES
deviltires is offline   Reply With Quote
Old 07-17-2008, 05:34 PM   #3257
Trader Rating: 13 (93%+)
I had the same problem and found that by setting the belt tension to almost the tightest setting its been fine and my belts have lasted longer
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 07-18-2008, 02:14 PM   #3258
You could try adding a 2nd belt tensioner:
Lycan is offline   Reply With Quote
Old 07-18-2008, 02:53 PM   #3259
deviltires's Avatar
how did you make the second belt tensioner
Old 07-18-2008, 02:58 PM   #3260
TeamCarnage's Avatar
Trader Rating: 23 (100%+)
Default belts
Thats a great idea! I just had to elongate the adjusting slot on the mounting plate a little to take up more slack. I wonder how consistant the length of the belts are. I haven't had a problem....prolly will now.
TeamCarnage is offline   Reply With Quote
Old 07-18-2008, 08:51 PM   #3261
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
are you running a spool? or a locked one way?
Am I going back racing?...Hmmm.. Not anytime soon... But soon enough.
rcfoolz is offline   Reply With Quote
Old 07-19-2008, 02:40 AM   #3262
Small piece of plastic. Hole in the top, hole in the side. one screw to hold the plastic to the radio tray and another to hold the bearings then I just spaced out the bearings with washers to align with the belt.
I can take a closer pic of it if you wish.
Old 07-19-2008, 06:02 AM   #3263
youngie's Avatar
maybe you could do the same as lycan except use the new belt tensioner for the T2 008
you might just have to elongate the hole a little if it's to tight
youngie is offline   Reply With Quote
Old 07-19-2008, 06:17 AM   #3264
Does anyone know what spacing i should use for my Sanwa ERG-VX Servos for both the steering and throttle on the NT1?
Also am i right to lower the fuel tank with the VXR LiPo pack?
RB_Racer
RB_Racer is offline   Reply With Quote
Old 07-19-2008, 01:47 PM   #3265
deviltires's Avatar
the spool
Old 07-19-2008, 02:00 PM   #3266
rcfoolz's Avatar
If you are running the spool, you are probably missing teeth on the front belt too. If you hit anything, and the tires stop turning, the weakest link is going to give. The teeth on the side belt, or front belt are going to strip off if hit hard enough. I would try going to the front diff with 100,000 fluid and see if that helps from stripping the belt before looking into different pullies or anything else.
Old 07-20-2008, 03:46 PM   #3267
RB_Racer
Can anyone help me? I would like to finish the radio tray so i can run my car
Old 07-20-2008, 05:14 PM   #3268
rcfoolz's Avatar
As for the Lipo, I don't use one, don't see the need for one. Your taking the weight from the best place of the car. As for the spacing...you have to judge the spacing from the servo horn to the front belt pully shaft. 1mm is the correct spacing.
Old 07-20-2008, 06:26 PM   #3269
Trader Rating: 80 (100%+)
Send a message via AIM to cpatel529 Send a message via Yahoo to cpatel529
Anyone selling a XRay NT1 package? Looking to get a nitro touring car for this upcoming weekend. We have the XRay Challenge in Portland, OR and I decided that I would like to run nitro. Any help would be much appreciated. I need everything except receiver and transponder.
Chirag
Chirag Patel (San Diego, CA)
1/10 2WD Buggy: TLR 22 4.0 SR 17.5
1/10 4WD Buggy: TBD
cpatel529 is offline   Reply With Quote
Old 07-22-2008, 01:51 AM   #3270
ToysRUsKid's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to ToysRUsKid
Default Success with NT1
Took 5th place in the A-Main at my first trophy race with the NT1 this past weekend. Check out the standings...
http://www.rctech.net/forum/attachme...8&d=1216603643
http://www.rctech.net/forum/showthre...=228780&page=6
Still learning a lot and the guys there all helped out, but hey, 5th is better than nothing. Not to mention I was bumped in by taking 1st in the B-Main.
Dorian Tisdale - Professional RC Driver Wannabe
ToysRUsKid is offline   Reply With Quote
