Like Tree7Likes
Old 03-06-2008, 09:18 AM   #2806
D-nicest's Avatar
Originally Posted by E.Rocha View Post
anybody have problem on belt mine keep breaking belt
Make sure that you have the right amount of tension on it and that you're running the correct tire split between front and rear. Also make sure that you're running on a smooth clean surface with little or no rocks etc. I have never had a belt break on me but I have found teeth missing on the middle belt before which is usually do to a rock or something getting in there.
Diatta Collymore [email protected]([email protected])(www.fordhamhobbies.com) (Wallacemotorsports.net) Fordham Hobbies, Wallace Motorsports, WRC Racing, Hot Race Tyres, Ielasi Tuned Engines, VP Power Master fuel, KO Propo America, Paint By Mikey Mike
D-nicest is offline   Reply With Quote
Old 03-06-2008, 09:40 AM   #2807
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
You might also want to check if your eccentric hubs are in the same position left and right be sure they didn't move on installation of the diffs.
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 03-06-2008, 07:23 PM   #2808
MAXX_BASHER's Avatar
can anybody tell me whether a 720 locker will fit in an nt1. just trying to save buying an xray if i dont need to.
MAXX_BASHER is offline   Reply With Quote
Old 03-06-2008, 07:36 PM   #2809
try different tension. eccentric is even. our track have a little bumpy section
E.Rocha is offline   Reply With Quote
Old 03-06-2008, 08:20 PM   #2810
No different size
Old 03-06-2008, 08:36 PM   #2811
does anyone know if they are going to be fixing the problem of the pivot balls coming loose? imo, that is a pretty serious fault.
Joe Chaplow is offline   Reply With Quote
Old 03-06-2008, 09:37 PM   #2812
the current kits don't have this problem.
TomB is offline   Reply With Quote
Old 03-06-2008, 09:40 PM   #2813
rocca30's Avatar
just put a little blue lock tight on each pivot ball and the problem will be fixed. i have about 3 gallons on my car with no issues.
RC AMERICA / / HUDY // SRC / / JC JEWELERS/ / GOT GOLD // MAXX POWER // EXTREME RACING FUEL //
rocca30 is offline   Reply With Quote
Old 03-06-2008, 09:44 PM   #2814
A few post back someone suggested that loctite eat at the plastic so just as Rocc said put it on the threads of the pivot ball and let it dry then install them.
Old 03-06-2008, 10:54 PM   #2815
No different size
thanks for the response, no harm in asking
Old 03-07-2008, 01:12 AM   #2816
Nexus Racing's Avatar
The blue threadlock did not work well for me.
I ended up putting CA inside the holes of the arm and letting it dry before threading in the pivot ball...this worked much better .
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
Old 03-07-2008, 10:01 AM   #2817
Team Kamikaze's Avatar
Any Threadlock will never work on plastic, it is invented/made for metel to metal.
You did right by using CA inside the holes of the arm, and by letting it dry you are actually building more material on the plastic, that way when you thread in the pivot ball it will be really tight, and that is the best way to do it.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 03-07-2008, 03:12 PM   #2818
just out of curiousity, how did you get the ca into the holes?
Old 03-07-2008, 03:16 PM   #2819
Just take the pillow balls out and he filled the threads inside the arms with the ca and let it dry before reinstalling.
Old 03-08-2008, 07:43 AM   #2820
just a quick question, i've found the xray clutch does not engage as aggresive as my mtx4r clutch. it does not rev free, then snap on like the mugen, except it engages pritty much straight away.
i've installed a crf spring and kyosho fluwheights which have been drilled out. i also wound down the spring to the point that any more and the clutch does not engage well, yet it still engages too early.
does this mean i need to increase the internal clutch gap between the shoe and the bell?
i have also been getting some pritty bad clutch burn on the shoe
i found that if the current thrust bearing is loaded up too much, it pushes the balls out, and elongates the holes of the balls. This causes the sides of the thrust bearing on the edges that are closest to the balls to hit the inside edges of the clutch bell where the thrust bearing sits in. This then causes inconsistent clutch engagement. also one of the balls now falls out, meaning the thrust has been exposed to too much force. ( i grease it up each race day).
all these are signs of the clutch not being set up right but i've tried many things (no end play, alot of end play, no clutch shoe gap, heaps of gap, tight spring, loose spring, lgiht weight shoes) yet nothing fixes it.
i am currently running 1.2mm of shims behind the internal bearing
help me out here i've recently changed the thrus bearing to the mugen one, as i have a feeling that the compressed xray thrust bearing that is hitting the sides of the inside of the clutch bell where the thrust sits is causing issues
i started up the car today, and couldn't get it to keep a consistent idle, and i think this is due to the clutch issues (and the dodgy thrust bearing i was using)
