Like Tree10Likes
Xray NT1
Old 02-23-2008, 09:25 PM
  #2701
D-nicest's Avatar
Originally Posted by Serpent-Dan View Post
good just waiting on my delivery of some extra power this coming week..
Did you order the one that I hope you ordered
D-nicest is offline
Old 02-23-2008, 09:26 PM
  #2702
Serpent-Dan's Avatar
Trader Rating: 18 (100%+)
got last years package
Serpent-Dan is offline
Old 02-23-2008, 09:30 PM
  #2703
D-nicest's Avatar
Which is still a ballistic motor, trust me you won't be disappointed. The Max Powers are no joke
D-nicest is offline
Old 02-23-2008, 09:45 PM
  #2704
got 2 pics coming up in a sec.
Old 02-23-2008, 10:19 PM
  #2705
Originally Posted by dj apolaro View Post
That is a common problem for that car. I have heard that most people use the kyosho spings in the 2 speed shoe. That will fix it.
thanks dj. by the way, where were you today???
Joe Chaplow is offline
Old 02-23-2008, 10:20 PM
  #2706
Xray NT1-docs-pics-452.jpg My NT-1 with Ralph's body from the WNats thanks Ralph.
Old 02-23-2008, 10:23 PM
  #2707
Xray NT1-docs-pics-454.jpgmy NT-1
Old 02-23-2008, 10:45 PM
  #2708
Can I use a Mugen or Serpent Centax III spring instead?
Rob
going4#1 is offline
Old 02-23-2008, 10:47 PM
  #2709
yes you can two best choices are serpent 1.8 spring or the orion spring.
Old 02-24-2008, 12:24 AM
  #2710
Originally Posted by rocca30 View Post
actually rc America has the news 2 speed spring in stock, that and the clutch spring are to soft that comes with the kit. most guys are running the msr or orion clutch spring. thats about the only little issue on the car . the is super tuff, very little extra parts needed to run this car.
true, i found the mugen super hard spring has an internal diameter slightly too small, the orion crf spring fits better.
TomB is offline
Old 02-24-2008, 03:57 AM
  #2711
Default Body choices
Is there particularly good body for the NT1? Stratus 3 maybe? I was running the Kawahara Accord with the MTX4 and it was a great fit for small tracks. The Kawahara IS250 was a nice stable body for bigger runs.
going4#1 is offline
Old 02-24-2008, 04:09 AM
  #2712
Originally Posted by badKarma View Post
what do yall think about twin BLS451's for steering and throttle in the NT1?
A good servo. Brushless so it will last and it takes less juice which means longer run time. The bad thing is the BLS451 is a heavier servo than the 9451 or 9452. If you've lightened the car up somewhere else though you may still be okay on weight.
going4#1 is offline
Old 02-24-2008, 05:41 AM
  #2713
Default 2 speed spring
hi,
just so i understand a little better, what does the two speed spring have to do with the clutch problem? i.e. how does it effect the engaging, slipping then engaging problem?
thanks in advace
Old 02-24-2008, 07:29 AM
  #2714
D-nicest's Avatar
Originally Posted by Joe Chaplow View Post
hi,
thanks in advace
It doesn't, I think some people were confused on exactly what clutch you were having your problem with. The kit centax clutch spring will do just fine, but if you wan't more snap then yeah I would recommend the MSR, or the JP spring. For now just take like half of a turn of tension off of the adj nut. The thing with the stock spring is that some people try to put so much tension on that it begins to bind itself and become inconsistent. Also what endplay are you running? Make sure that the endbell screw is not coming loose.
D-nicest is offline
Old 02-24-2008, 07:40 AM
  #2715
teamgp's Avatar
The Stratus 3.1 is absolutely the best. However, for larger flowing tracks, the IS250 is a really good body if you like the car to steer more like an 1/8 scale.
Like Diatta, I also prefer the JP hard spring. Fits perfect and has a consistent and linear (hard or soft) engagement, depending on how much tension you put on it. Lasts a long time to.
teamgp is offline
