Like Tree10Likes
Xray NT1
Old 02-16-2008, 04:05 AM
  #2671
Originally Posted by rcfoolz View Post
YBSlow makes a brass battery tray that is 60 grams....I had to add 106grams to my car, and that was with a regular battery pack.
i'm thinking that if you use a VXR lipo like me, they are rather short, so if a machinist could make a brass tray with weight behind the battery and infront of it, that would be the perfect battery tray i wish i had a CNC machine
TomB is offline
Old 02-16-2008, 01:12 PM
  #2672
meronr's Avatar
Way to go Team Xray, taking 1st and 3rd in the A-main way to represent, not to mention all the other Xray drivers that made it to the A-main making it the most represented car in the A-main field...
meronr is offline
Old 02-17-2008, 12:05 AM
  #2673
Originally Posted by TomB View Post
i just built a set of alloy nt1 shocks, they are only 2 grams heavier than the plastic versions, so if you are using the plastic versions thinking they will be a sizable weight reduction you are wrong.
also i installed a lipo in my car and titanium pivot balls, it is some 100 grams under weight damn i didn't know they were this light!
does anyone make a 100gram battery tray? ...serious? anyone?
also the hard bumper is some 25 grams heavier than the stocky
Where did you get the titanium pivot balls?! Did they fit correctly? I've installed the Serpent onces but those are a little bigger...
_cyclops_ is offline
Old 02-17-2008, 03:22 AM
  #2674
got them from www.rcmarket.com.hk if memory serves correctly
TomB is offline
Old 02-17-2008, 05:24 AM
  #2675
DS Motorsport's Avatar
probably the 3 racing ones, so i wouldn't bother.
I also use the serpent ones with the nylon locknuts from serpent, heated the inside op the upright so they formed to the pivotball.
DS Motorsport is offline
Old 02-18-2008, 02:53 AM
  #2676
no they are the rcmarket brand the other one on their website. they seem fine to me.
TomB is offline
Old 02-18-2008, 10:56 PM
  #2677
kitracer's Avatar
hey guys, I have access to very good titanium pivot balls and T6 3mm Chassis. These are OEM in China ( but not GPM or 3 racing). The Chassis material from US. The Ti pivot ball weight 2.15g each.
Both the chassis and pivot ball was used at the weekend Big Race in China and TQ / finished A1
http://www.rctech.net/forum/showthread.php?t=206332
Anyone interested, please PM me.
kitracer is offline
Old 02-19-2008, 07:17 AM
  #2678
pm sent
Joe Chaplow is offline
Old 02-19-2008, 08:22 AM
  #2679
meronr's Avatar
pm sent
meronr is offline
Old 02-19-2008, 08:35 PM
  #2680
kitracer's Avatar
I can't get to my PM.
Please email me [email protected]
kitracer is offline
Old 02-21-2008, 06:41 PM
  #2681
Default Need Help In Picking Engine for NT1?
Hey Guys, Need your Expert advice in Picking the Hottest engine for my NT1?
If Price no concern...standard or modified? Which would you choose or have and why..
CrazyJoe is offline
Old 02-21-2008, 11:51 PM
  #2682
M7H
M7H's Avatar
Any engine will be very hot, if you lean it enough.....
M7H is offline
Old 02-22-2008, 08:15 AM
  #2683
pullstart's Avatar
Mate, Most engines working wells on NT1, most of us in Malaysia couple it with Sirio engines, some with IDM picco and Novas
pullstart is offline
Old 02-22-2008, 05:22 PM
  #2684
I was investigating the Nova 12+3 and the 353? Any comments on these? My friend Just picked upthe Picco Red dot and is sending to Murman to be worked on...
CrazyJoe is offline
Old 02-22-2008, 08:48 PM
  #2685
badKarma's Avatar
can anyone help me...with the JL .12 Evo 3 i was advised that you have to use a special NT1 flywheel collar for installing the engine on the NT1 is this true? can anyone explain this...and i was also told the Skyline V12 pipe is not compatible with the Xray and this engine, is this true? thanks
badKarma is offline
