Like Tree7Likes
Old 01-20-2008, 03:40 PM   #2491
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
BTW, use sensor safe silicone... Permatex is easily available at most local automotive shops like napa, checker, shucks, kragen, etc... I also use it for sealing engines.. shhhh.. ppl wonder why I rarely have inconsistent tuning... lol.. its all in the prep ladies.. its all in the prep
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 01-20-2008, 03:45 PM   #2492
meronr's Avatar
Originally Posted by rx7ttlm View Post
Well I solved that before I ever had a problem. I use black RTV coating the sealing surfices of the diff... they dont leak a drop that way...
how you putting the rtv coating on, in other words you do still use the o-ring and than apply rtv and than close the case or just rtv on the inside or you putting a bead around where the two sides of the case meet
Meron Rubinowitsch
meronr is offline   Reply With Quote
Old 01-20-2008, 03:48 PM   #2493
rx7ttlm's Avatar
Put on the oring dry around the diff case position it where i want it.. and use a dab of rtv at a time to keep it on.. then apply a thin layer of rtv around the whole case where the two parts meet keeping in mind you need to build up enough sealant to fill the gaps.. Works great.. I built my first diff the xray way once.. and Then I went back to how I built my serpent diffs.. no more 100k/ 60k oil flung on the inside of my bodies lol
Old 01-20-2008, 03:54 PM   #2494
meronr's Avatar
just want to make sure just apply a little say with a q-tip on the inside of the diff case just to hold the o-ring in position and than when i put the two case together i should run a bead around that little crack
Meron Rubinowitsch
Old 01-20-2008, 03:55 PM   #2495
rx7ttlm's Avatar
Stop being a wussie, use your finger.. it works better...
Old 01-20-2008, 03:58 PM   #2496
meronr's Avatar
ok finger but other than that i have your instructions correct
Meron Rubinowitsch
Old 01-20-2008, 04:01 PM   #2497
rx7ttlm's Avatar
Do you need a picture brother? lmao
Old 01-20-2008, 04:12 PM   #2498
rx7ttlm's Avatar
ok, on page 4 step 5 of the manual.. you have the picture of the diff housing.. where you put the gears and cross shaft.. put the oring on the outside where the lil step is.. .. put silicone on top of that.. to keep it there.. and to seal it all up.. not a lotta need to put it in the other side.. just make sure you have enough on the diff housing..
Old 01-20-2008, 04:32 PM   #2499
meronr's Avatar
got it now just want to make sure no q-tip use finger right (just kidding)
Meron Rubinowitsch
Old 01-20-2008, 04:36 PM   #2500
rx7ttlm's Avatar
Thats it, the next time I work on your car I am going to remove the c clip from the two speed shaft on the right side...and not tell you
Old 01-20-2008, 04:38 PM   #2501
meronr's Avatar
you mean i just cant put some black rtv to hold the pulleys on too. lol
Meron Rubinowitsch
Old 01-20-2008, 05:09 PM   #2502
rx7ttlm's Avatar
well if you clean it first. you just might be able to .. but the bearings wouldnt last long with RTV lol
Old 01-20-2008, 09:11 PM   #2503
royfan33's Avatar
Any of you guys using the new Xray metal shocks? When I bought my NT1 I got a pair of Serpent RCC shocks with it for free. I like the bottom load design they have, and I was thinking of ordering two more so I could run a matched set of four. Then I ran across the new Xray shocks and they look pretty good too. Any input?
Gary
Xray NT1
RB Concepts R3
Nomadio React
CORRC
royfan33 is offline   Reply With Quote
Old 01-20-2008, 09:25 PM   #2504
meronr's Avatar
I have a question about the hard bumper. I have one of the hard bumpers and realized that it is significantly heavier than the stock bumper, just wondering if anyone who's using this bumper can tell me if this added weight in front of the car has affected the way the car handles in regards to steering or anything else i should consider
Meron Rubinowitsch
Old 01-20-2008, 09:28 PM   #2505
rx7ttlm's Avatar
Personally, I don't care for the work required of the RCC shocks.. snap ring pliers on rc shocks? I have rrc shocks, I have mugen shocks, tamiya shocks, and xray shocks.. stick with the ray man.. the tamiya shocks are smoother.. but the double seals on the new socks are better than the RRC shocks..
cheers
