Like Tree7Likes
Old 01-20-2008, 05:19 AM   #2476
Originally Posted by Gseventeen View Post
Didnt take you long to get that win posted ,Darth!! lol lol tommy i couldnt find
that mount you need, sorry.
i was very impressed especially considering the NT1 driver is probably not as fast with the tourer as the other kyosho drivers due to the fact that he does not race tourer as often, although he does have a vast amount of experience.
TomB is offline   Reply With Quote
Old 01-20-2008, 01:47 PM   #2477
DS Motorsport's Avatar
Originally Posted by rx7ttlm View Post
So I have a plan guys... I am going to go test tomorrow at speed world.. and try for the track record in cold weather
What kind of 1:1 racecars do you run?.
i'm an engineer on formule renault 2.0 and in the 08 season we are going to start with formula master. Really cool cars, paddle shift gearbox and everything.
I really like to use 1:1 racing techniques on these little cars.
Ive build a complete corner weights station, which can be tweaked to be perfectly leveled.
DS Motorsport is offline   Reply With Quote
Old 01-20-2008, 02:02 PM   #2478
asw7576's Avatar
Is it okay to put direct lipo connection to receiver & servo ? I mean 7.4V directly into receiver & servo ?
Old 01-20-2008, 02:04 PM   #2479
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
Pro Formula Mazda / Mazda Atlantics... I have calibrated scales and a scaled down version of my MK setup pad lol. I have found it hard at times, since a lot of things aren't the same with the lil cars. And my feedback with the lil cars sucks compared to driving real cars lol, theres no feel... .
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 01-20-2008, 02:21 PM   #2480
rx7ttlm's Avatar
Well I suck, Didn't make it to the track today. I guess I will true tires, build shocks and have everything dialed for next weekends race...
Review- Airtronics Hi Speed/ Hi Torque servos don't work that well on the throttle for the safety side. IE throttle return spring doesn't have a chance. Fitted a Ko Propo Servo.. like butter with less slop.. only time will tell..
with the new Micro switch from Xray. Its tough to fit a 3000 series Spektrum RX in the rx case with all the wires and what not. Just pony up and get the micro RX. There is a lot more room to work with..
getting ready for the three hour torture test. Last time we found belts, and the rest of the car last fine... The shocks, some bearings needed overhaul and clutch did need to be rebuilt however.. Clutch bearings- the 5x8= fried, the 5x10 was maybe reusable with oiling, but I changed anyhow. Clutch endplay needs to be adjusted to much, I will try some things to see if they work out better.. (like ko flywheel nut etc)
I have yet to have an on track failure that was xrays fault. I pulled the pivot ball through the front knuckle ONCE.. in MANY hours of racing/ testing. First time out with my mugen I ended up breaking the front knuckle.... and it didn't stop there...
Get the car to rotate a bit better on low bite, and make these clutch bearings last for ever.. and you have a car that you don't HAVE to teardown all the time. With my previous cars, I felt I always had to look for broken things.. not anymore lol. This time after the three hour race, I had a binding servo link and some bearings i wanted to change because they had like 6 hours on them.. But nothing I couldn't run again at a club race..
Old 01-20-2008, 02:33 PM   #2481
meronr's Avatar
You can do it but the problem is that there is no telling how long your servos will last i dont reccomend that you do it just put the regulator. The problem is that when you charge a lipo pack it doent charge to 7.4v it charges up to as high as 8.6 volts
Meron Rubinowitsch
meronr is offline   Reply With Quote
Old 01-20-2008, 02:55 PM   #2482
rx7ttlm's Avatar
Amen, brother.. you doing winternats?
Old 01-20-2008, 02:59 PM   #2483
meronr's Avatar
no i cant get the time off from work to make it why you going (Mom wont let me go is she letting you go )
Meron Rubinowitsch
Old 01-20-2008, 03:04 PM   #2484
rx7ttlm's Avatar
Nah, Didn't plan far enough out.. so mom won't let me go.. That and I am working on a new deal for 08. More money, More weekends off.. so more nitro races (smiles)
Old 01-20-2008, 03:05 PM   #2485
meronr's Avatar
thanks for the shock info i too built with adjustable i most likely wont get to officially race the car with clock and qualifiers till end of march or begining of April (its driving me crazzzzzzzzzy ) whenever 301 does its opening day race
Meron Rubinowitsch
Old 01-20-2008, 03:06 PM   #2486
meronr's Avatar
well do me a favor and get me the same deal
Meron Rubinowitsch
Old 01-20-2008, 03:08 PM   #2487
rx7ttlm's Avatar
weak, I was just up late last night going through the car.. New engine bearings, con rod, all the driveline bearings are new, and some updates so I can change things faster.. Built up a lot of spares... 2 cars worth of stuff lol.. Aligned the car with three diffrent geometries(track/ roll centers) so I could test stuff fast without putting it on the setupboard 50 times.. Just put it on the scales...
Old 01-20-2008, 03:10 PM   #2488
rx7ttlm's Avatar
Since I didn't wake up till 11, I am just going to do some shock modifications and set them up. I will go test at another place tomorrow I guess... Just have a hard on for that track since its permanent and we do 3 hour races there...
Old 01-20-2008, 03:22 PM   #2489
meronr's Avatar
on a different subject i really think Xray has to come up with some better O-rings for sealing the diffs the o-rings are weak and definately prone to leaking
Meron Rubinowitsch
Old 01-20-2008, 03:35 PM   #2490
rx7ttlm's Avatar
Well I solved that before I ever had a problem. I use black RTV coating the sealing surfices of the diff... they dont leak a drop that way...
