Like Tree7Likes
Old 08-21-2007, 06:12 PM   #1786
Send a message via AIM to goop
Originally Posted by asw7576 View Post
That's right.
I keep using stock dogbones and haven't lost a thing because I use +.75mm wheel hex with 198mm front track width.
My friend was using 0mm wheel hex with 198mm track width. He missed his heat #1. I believe he switched to CVD before heat #2. Ditto story with my another friend with NT1, .... he lost his front dogbones in practice day.
I believe nitroorgasm had economical idea to use Mugen Seiki parts : front CVD ( must check which cvd has the same length like original nt1 cvd ), front uprights, front bearings and pivot balls.
if you go this route and change the entire front end to run the mugen cvd's you are also changing the geometry of the car which will change the way the car drives and handles.
Hurricane Motorsports
Team Trinity
TOP Racing - Gravity Rc - Contact tires - KO Propo - Competition Electronics
goop is offline   Reply With Quote
Old 08-21-2007, 07:28 PM   #1787
Xray prince's Avatar
Default Xray/Mugen upper arms
Actually Nitrogasm is one of my fellow club members,,,,,and he use to run Mugen B4 the NT1 and he claims tht he measured it all out..and the uppers hav the same geometry.......I dnt kno!
Xray prince is offline   Reply With Quote
Old 08-21-2007, 08:31 PM   #1788
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
I thought the same thing, that everything was the same. It actualy IS NOT. The pivot balls are closer together with the Mugen parts, changing roll center. The length of the pivot points are also different. They look the same, but they are not. If running the mugen parts (I know, I tested before the CVD's were available) causes the car to push a little more going in and is not as fast through the middle of the corner. Also, camber gain is different when compressing suspension and during turning. It may be close, but close is not the same. To most racers, I guess this wouldn't be a major issue, but I could feel the difference in driving the car. It is faster going into the corners and in the middle.
This is my oppinion.
Am I going back racing?...Hmmm.. Not anytime soon... But soon enough.
rcfoolz is offline   Reply With Quote
Old 08-21-2007, 08:49 PM   #1789
mtveten's Avatar
Trader Rating: 27 (100%+)
Even if the mugen knuckle setup retains the proper geometry of the car I fail to see the benifit. The only issue people seem to have with the NT1 front end is the cost of the CVDs but I find it hard to believe that a set of mugen CVDs, knuckles and pillow balls would be any cheaper.
mtveten is offline   Reply With Quote
Old 08-21-2007, 08:51 PM   #1790
thamjk's Avatar
Originally Posted by mtveten View Post
I stand corrected, the proposal I ready was amended to electric classes only in the final ruling.
The AAA pack is still the way to go, its cheaper, and still reduces the weight and allows you to drop the tank the same 4mm.
One other advantage of the AAA pack is that the 2 cells positioned on the left side of the chassis help correct the left/right weight balance reducing the amount of weights needed.
Mark
How would you organised the AAA battries to fit in NT1.
Serpent 710
Nova MAX
3PK
thamjk is offline   Reply With Quote
Old 08-21-2007, 10:31 PM   #1791
asw7576's Avatar
I have spare uprights for mtx4 and nt1. Let me measure the distance between the two openings from mtx4's pivot ball and nt1's pivot ball.
I think nitroorgasm has left over mugen spareparts..... perhaps he was utilising what he has instead of buying xray's cvd and uprights.
I don't have any objection with his idea....... he was having problem with broken cvd and broken upright after some side wall crashes.
Old 08-22-2007, 01:47 AM   #1792
rcfoolz's Avatar
When you measure them OFF the car, they will look the same. Put them on and you will see what I am refering too. A broken CVD...Man that must be some sidewall crash I tagged the back wall all the way down at WOT at Kissimmee this past weekend and slammed into the wall at the end of the straigh a way., the only thiing that happened was I bent a rim so bad that the tire wouldn't even roll.
Old 08-22-2007, 06:27 AM   #1793
Ryan41's Avatar
Send a message via MSN to Ryan41
Well, I finished building my car..all ready to rock and roll..cant wait to drive her I love the brown hudy steel...! Was gonna run a LLT3 motor in her..but decided to open to JP box instead..so I will be running the JP FX T-03M...should I be swapping this any time soon, or will it do me fine?
Car rolls so free! Got the track width at 198 at the front..and the dog bones look scary..can see them coming out..might put some more rubber o-rings in behind.. Anyone know any places who have CVD's in stock? woulda love to swap for these..and also, alloy shock bodies..I can find fronts..but not rears..
Cheers, Ryan
P,S, XRAY...BRING OUT A 1/8 !!!!!! Is this on the horizon?
Capricorn Tourer
AE TC5R- Drifter
Revo to annoy the dog
Yokomo DRB drifter for the missus.
Ryan41 is offline   Reply With Quote
Old 08-22-2007, 07:04 AM   #1794
Trader Rating: 45 (100%+)
Cheers, Ryan
Nice...Link to CVD's below.
http://nexusracing.net/product_info....3f0bba68c29463
Apex is offline   Reply With Quote
Old 08-22-2007, 07:12 AM   #1795
Cheers, Ryan
Hey, why does your car say Chris?
brianhatesnitro is offline   Reply With Quote
Old 08-22-2007, 09:56 AM   #1796
mtveten's Avatar
you build it in a 5 cell side pack configuration. Mount the pack in the middle of the tray with 3 cells in the tray and the other 3 hanging over the side towards your pipe.
If you need a pic to see how its done, I can snap one for you when I get home tonight.
Mark
Old 08-22-2007, 10:26 AM   #1797
asw7576's Avatar
I alrady measure the height of NT1 and MTX4 front uprights.
Total heights : NT1 ( 4.15mm ) ---- MTX4 ( 4.19mm )
Distance between two holes for pivot balls : NT1 ( 3.01mm ) ---- MTX4 ( 3.05mm )
Old 08-22-2007, 11:12 AM   #1798
RC MARKET's Avatar
Cheers, Ryan
this is which brand name body ?
Thanks !
RC MARKET is offline   Reply With Quote
Old 08-22-2007, 02:37 PM   #1799
Sow&Steady's Avatar
Looks like Titan brand.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 08-22-2007, 04:14 PM   #1800
wallyedmonds's Avatar
i 2nd that.
wallyedmonds is offline   Reply With Quote
