Like Tree6Likes
Old 08-16-2007, 01:07 PM   #1711
rmdhawaii's Avatar
Originally Posted by Apex View Post
I'm in the process of installing the electronics...Do you guys use a switch to control current flow or do you just plug\unplug the battery into the receiver to control the current flow?
I always install a switch on all my cars, but that's just me. I would do the direct connect to the receiver, but it's such a pain to pull the connector out all the time - and a real problem if you're using a receiver cover.
I wish there was a smarter connector or tool that made it easier to remove the connector from the receiver. I'm always worried that I'm going to break something - like a wire or a pin.
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 08-16-2007, 01:13 PM   #1712
Trader Rating: 45 (100%+)
Originally Posted by royfan33 View Post
I bought a 6" male/female extension that I have plugged in the the RX. Then just plug/unplug on the outside. Only cost couple of dollars, and I think it's more reliable than a switch.
Thanks guys...I'm thinking I'll do the harness with the male\female extension.
Apex is offline   Reply With Quote
Old 08-16-2007, 01:25 PM   #1713
royfan33's Avatar
If you have the male/female extension it stays connected to the RX. You unplug it outside of the RX box ala G4S. It's something thats been around before the G4S, but TM made the little mount for the female connector. You can do the same with double sided tape or shoe goo.
Gary
Xray NT1
RB Concepts R3
Nomadio React
CORRC
royfan33 is offline   Reply With Quote
Old 08-16-2007, 01:54 PM   #1714
rmdhawaii's Avatar
Thanks Gary, that clarifies things a bit. Attaching one side to something didn't really cross my mind. It is certainly an excellent idea.
I'm using these Parson's Safety clips when I need to join connectors. I'm just so paranoid that something will vibrate itself loose and I'll have a runaway.
Old 08-16-2007, 03:29 PM   #1715
royfan33's Avatar
Wow, I've never seen the safety clips. I've been using the pigtail method for along time, back to 1/8th buggies, and have never had a problem. If it seems loose, or maybe looks frayed just buy another pigtail for $2. I know there are other guys at the track doing the same, especially with the Xray beings it requires the tiny little switch.
Gary
Xray NT1
RB Concepts R3
Nomadio React
CORRC
Old 08-16-2007, 11:38 PM   #1716
asil's Avatar
Send a message via MSN to asil
Team Magic's plug is a smart design for switch on/off.. I glued a small zip tie end into the empty slot in the plug and it's easier to remove the plug..
couldn't find a photo in my computer to show you
Asil
asil is offline   Reply With Quote
Old 08-16-2007, 11:42 PM   #1717
asil's Avatar
yep, I found a photo in Kodak's blog;
Old 08-17-2007, 06:20 AM   #1718
kitracer's Avatar
nice tip thanks
kitracer is offline   Reply With Quote
Old 08-17-2007, 07:09 AM   #1719
teamgp's Avatar
Are you using lipo? If so, I recommend the Novak Nitro Servo Regulator. It comes with a small but very sturdy switch. Das whatum runnin...
Guy Hood
Sponsored by: Team XRAY / Team RC America / RB Products USA
/ Twister Tires USA / Maxy's Mods & Fuel / Parma PSE / Zubaks
Un-sponsored Shoutout: NexusRacing.com
*** 301 Raceway is my home away from Home ***
teamgp is offline   Reply With Quote
Old 08-17-2007, 07:19 AM   #1720
I want to use LiPo. Do you know if this will work ok with Spektrum 2.4ghz?
Old 08-17-2007, 10:26 AM   #1721
teamgp's Avatar
Works great for me.
Guy Hood
Old 08-17-2007, 10:30 AM   #1722
rmdhawaii's Avatar
Old 08-17-2007, 10:39 AM   #1723
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
I ended up using the switch that is on the NT18. It was a perfect fit.l
rcfoolz is offline   Reply With Quote
Old 08-17-2007, 11:20 AM   #1724
rmdhawaii's Avatar
This might work as well: XRAY part #356050
Checkout the photos here: http://www.teamxray.com/teamxray/pro...p?prod_id=1193
Old 08-17-2007, 02:32 PM   #1725
rcfoolz's Avatar
thats the same switch. I didn't have the part number for it though.
I need to get another for my backup car. thanks
