Like Tree7Likes
Old 08-10-2007, 11:40 AM   #1696
teamgp's Avatar
Originally Posted by slide_228 View Post
How is the improvement. Will it be initial of the turn, mid or exit? I am having a problem as my car is pushing on fast corners, heavier roll bar helped a bit but I still want more on power steering.
Steering improved overall. However, if you could post your entire setup in the XRAY Forum Setup Sheets, we could provide you with better advice on improving your setup once we've taken a look.
Also, tell us what works great about the cars handling so we can try to give advice that won't upset those areas.
Guy Hood
Sponsored by: Team XRAY / Team RC America / RB Products USA
/ Twister Tires USA / Maxy's Mods & Fuel / Parma PSE / Zubaks
Un-sponsored Shoutout: NexusRacing.com
*** 301 Raceway is my home away from Home ***
teamgp is offline   Reply With Quote
Old 08-10-2007, 12:02 PM   #1697
RC MARKET's Avatar
Originally Posted by Ryan41 View Post
OK, so my NT1 should arrive soon...and i've already spent a couple of hundred in hop ups
Heres the list:
Rear adjustable anti roll bar
carbon bumper mount
rear cvds (fronts were out of stock on rc-mushy)
light weight gear housings
light weight brake holder
carbon battery tray
does anyone know where I would be able to buy alloy shock body's from? and also front cvd's.
thanks guys
Ryan
Don't need alum. shock body !
or 3 Racing !
RC MARKET is offline   Reply With Quote
Old 08-10-2007, 07:36 PM   #1698
Default Problem
I ahve rechecked the car again and may be I found what the problem was. The 2 pivot balls on rear a arm backed out and my track width is now 202 instead of 199-200 Will re-adjust and see. Your observation seems correct but I think I want to get the car set up right with stock configeration first.
slide_228 is offline   Reply With Quote
Old 08-11-2007, 02:20 PM   #1699
Nexus Racing's Avatar
Xray suggests putting thread lock on the pivot ball threads before screwing them in, but I think that even that is not enough (I still had some back out).
The next time I dismantle my car, I am going to put a small amount of CA in the arms, let it fully dry, and then thread the pivot balls in. My guess is that this will make the holes much tighter.
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
Old 08-11-2007, 06:09 PM   #1700
teamgp's Avatar
I've also had a nagging issue with the aluminum nuts backing out and allowing the hubs to move in and out as the pivot balls became loose.
I decided to put a small dab of shoo goo on the threads and side of the pivotball aluminum nut to keep it from backing out. Of couse I was careful not to block the hex hole so I can adjust the pivot balls if need be.
A pair of needle nose pliers can pluck it out if I need to.
Guy Hood
Old 08-12-2007, 09:40 AM   #1701
As much as you probably play with that car, I'm not surprised .
NEXUSRACING.com
Old 08-12-2007, 03:09 PM   #1702
rmdhawaii's Avatar
I found a great deal on a NIB NT1. It won't be here in time for me to give it a test run next weekend, so I probably will not get a chance to run it until late September. I'm not going to be buying the recommended upgrades initially, so I can get the full "NIB experience" - but I will seal the diff's with Permatex. Engine wise, I'm going to start it off with a standard 3-port TZ.
I'm really looking forward to comparing it against the RRR WCE and MTX-4.
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 08-12-2007, 03:59 PM   #1703
jarnotrulli's Avatar
i had a v one rrr evo wce before i got my nt1, there is not so much difference in driving only the back of the car is better. and the lay out of the car is better thougt about everything.
jarnotrulli is offline   Reply With Quote
Old 08-12-2007, 04:05 PM   #1704
Why would Permatex the diff's?? They don't leak!
MBlackketter is offline   Reply With Quote
Old 08-12-2007, 04:14 PM   #1705
rmdhawaii's Avatar
O-ring diff seals and me just don't get along - plus, a few people have said they leak. If you've got some trick to preventing them from leaking, I'm more than willing to give it a try.
MTX-4 gasket diff seals don't leak. I like those.
Old 08-12-2007, 06:43 PM   #1706
These don't leak either if you just take your time to make sure the seal does not slip out when your putting them together.
Old 08-12-2007, 10:42 PM   #1707
royfan33's Avatar
My diffs don't leak either, but the o-ring type gasket can be a pain. As said above you have to take your time to make sure it doesn't get in the wrong place and get pinched. And even though sometimes the gasket may look reusable I replace mine to be sure. Just order a pack of gaskets so you have no worries.
Personally I would prefer a traditional diff flat diff gasket. The o-ring seems to do the job, but if in a hurry trying to change between quali's it can be a PITA....
Gary
Xray NT1
RB Concepts R3
Nomadio React
CORRC
royfan33 is offline   Reply With Quote
Old 08-13-2007, 01:10 AM   #1708
Sow&Steady's Avatar
Ah! You're getting there Rainer ... NIB experience is a good idea too.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 08-16-2007, 11:10 AM   #1709
Trader Rating: 45 (100%+)
I'm in the process of installing the electronics...Do you guys use a switch to control current flow or do you just plug\unplug the battery into the receiver to control the current flow?
Apex is offline   Reply With Quote
Old 08-16-2007, 12:03 PM   #1710
royfan33's Avatar
I bought a 6" male/female extension that I have plugged in the the RX. Then just plug/unplug on the outside. Only cost couple of dollars, and I think it's more reliable than a switch.
Gary
Xray NT1
RB Concepts R3
Nomadio React
CORRC
