Like Tree7Likes
Old 07-19-2007, 06:37 AM   #1576
Sal Amato's Avatar
R/C Tech Charter Subscriber
Trader Rating: 26 (100%+)
for pinion removal you can use serpent 802515 and to hold the clutch bell 802514. I just got these tools and they work perfect .
360 RC SPEEDWAY 2.0
AWESOMATIX USA-SANWA--BSR--TEAM SCREAM --SWEEP RACING USA--TQ WIRE--ROCHE USA--LRP
Sal Amato is offline   Reply With Quote
Old 07-19-2007, 06:40 AM   #1577
Default Flywheel and pinion tools
Thanks sns820, what about the flywheel? Serpent as well?
ldp787 is offline   Reply With Quote
Old 07-19-2007, 06:49 AM   #1578
Sal Amato's Avatar
I have the JP universal ,I am pretty sure any universal wrench will work .The serpent wrench will work
360 RC SPEEDWAY 2.0
Old 07-19-2007, 07:28 AM   #1579
Default Clutch tools
Much thanks!
Old 07-19-2007, 07:24 PM   #1580
I finally bought a gram scale and weighed some of the lightweight parts in case any of you are interested.
Stock flywheel 10g
The lightened flywheel is 9g ($21)
The first gear adapter, 8g stock
Lightened, 7g ($27)
The blade swaybar is 11g ($44)
vs 2.4mm sway bar at 5g plus the small aluminum pieces at the ends (2-3g)
Brake disk adapter 9g stock
Lightened 7g ($17)
Total savings, 4 grams off the drivetrain, -3 more by ditching the blade swaybar
Total cost, $109.
The next time I rebuild my car I'll also get the weights of the multidrive and one piece vs two piece engine mounts. Does anybody have the weights of a stock diff (spool and diff?) or the lightened two speed adapter?
brianhatesnitro is offline   Reply With Quote
Old 07-20-2007, 07:55 AM   #1581
Mini Toink's Avatar
Trader Rating: 30 (97%+)
Send a message via MSN to Mini Toink Send a message via Yahoo to Mini Toink Send a message via Skype™ to Mini Toink
Hey Guys,
I broke my shock body on my NT1 yesterday and would just like to ask if the shock body for the NT1 and the T2(EP Kit from Xray) are the same and can be use on the NT1?
Also, is the alum. shock body from an FK04 or is it FK05 compatible with the NT1?
Thanks in advance for the help!
Toink
Xray T2'008 EU 6Cell
Hudy Pro Tools
AE 12R5
LRP : Orion : Sanwa (Airtronics) : Ko Propo : Spektrum
Mini Toink is offline   Reply With Quote
Old 07-20-2007, 08:16 AM   #1582
GK
Suspended
Originally Posted by Mini Toink View Post
Hey Guys,
Toink
Yes, T2 and NT1 shock bodies are the same (part # 308330) Not sure about alu. bodies, they were discontinued...
GK is offline   Reply With Quote
Old 07-20-2007, 08:22 AM   #1583
teamgp's Avatar
Stock flywheel 10g
Lightened, 7g ($27)
Lightened 7g ($17)
Total cost, $109.
Keep in mind that the seemingly small weight savings of the flywheel, 1st/2nd gear holders and brake disk holder are not so insignificant when it comes to rotational mass.
I changed all of these at the same time at the track a few weeks ago and I definitely noticed an increase in acceleration on the track.
As far as overall static weight is concerned, the car is pretty much light out of the box, depending on electronics of course. Therefore, the most important weight savings still points to rotational mass.
teamgp is offline   Reply With Quote
Old 07-20-2007, 08:38 AM   #1584
Mini Toink's Avatar
Thanks GK! Appreciated!
Toink
Hudy Pro Tools
AE 12R5
Old 07-20-2007, 11:04 AM   #1585
Send a message via AIM to goop
i have put my fk04 shocks on my nt1 just to see how it would drive and they worked just fine.
Hurricane Motorsports
Team Trinity
TOP Racing - Gravity Rc - Contact tires - KO Propo - Competition Electronics
goop is offline   Reply With Quote
Old 07-20-2007, 11:41 AM   #1586
Mini Toink's Avatar
Is that the aluminum shock body you're saying?
Also, are the springs for T2 also same as the springs for NT1? I'm guessing its a "Yes" as they both have same shock body, want to be sure though.
Thanks in advance!
Toink
Hudy Pro Tools
AE 12R5
Old 07-20-2007, 04:34 PM   #1587
SlamMan's Avatar
The front springs are shorter. The back springs are the same as the T2.
SlamMan is offline   Reply With Quote
Old 07-21-2007, 11:46 AM   #1588
asw7576's Avatar
I think I'm ready to race on 4th and 5th of August 2007. It's a DTM race..... Serpent ( the host ) is kindly let other car makers to compete.
( pardon the tamiya stickers..... I'm eccentric )
Old 07-21-2007, 06:57 PM   #1589
[QUOTE=Mini Toink;3503854]Is that the aluminum shock body you're saying?
Thanks in advance!
yes they are the aluminium shock bodies. i ended up going with the stock plastic shock bodies so i can work closer to the factory guys like, paul lemieux, chris doesek, tom esposito, i felt that if i was running different stuff than they were that the setups might not work the same.
Team Trinity
Old 07-21-2007, 11:11 PM   #1590
has anyone tried the new 4mm chassis yet? I saw it available on nexus.
http://nexusracing.net/product_info....02b9261046c6ac
when did it come out?
thanks guys!
onroaddude is offline   Reply With Quote
