Old 03-14-2002, 10:18 AM   #226
Mad Max's Avatar
Come on check out the wheels on this baby WOOHOO This will make you the coolest on the block, sign here! You don't have money NO PROBLEM , freakin finance it.
Mad Max is offline   Reply With Quote
Old 03-14-2002, 10:19 AM   #227
BallPy is offline   Reply With Quote
Old 03-14-2002, 10:21 AM   #228
Mad Max's Avatar
so how you like your GT 4? Which one do you have. how you set up for what type track.
Old 03-14-2002, 10:27 AM   #229
Well right now it is an RTR. But I have all the parts to make it a pro. I have about -1 degrees up front toe. 2 degrees camber which is a little much. In the rear I have 1 degree toe in. I am only running on a parking lot track that isnt very good. I wish someone around here had a decent track. It still has the stock RX .18 in it but I have a Collari on the way and I will be sending Richey some money for a MT 12 RTU.
Old 03-14-2002, 10:40 AM   #230
Mad Max's Avatar
I run the GT4 W with a host of options, aluminum shock mounts,braces, brake bracket, and shocks lowered motor mts. I have an RB 5 port turbo with 15/48 first gear (gotta change) and a stock 2nd gear setup. diffs front and rear. Lightened clutch to hit harder. my biggest challenge right now is powering out of the corners I have way too much wheelspin. rubber tires sorex (temperature driven on type)
I also have a Reflex NT I run on foams which is also blinding fast with a stock MT12.
Here in socal I have lots of sun to run every weekend.
Old 03-14-2002, 10:44 AM   #231
Must be nice. Out here it is crappy.
Old 03-14-2002, 11:18 AM   #232
Mad Max's Avatar
Sorry to here that but it costs a fortune to live here.
Old 03-14-2002, 11:19 AM   #233
I can imagine.
Old 03-22-2002, 03:57 PM   #234
wuld a GT4-Pro parts work on a GT4-w?
~Brandon
LiLRCLoUiE is offline   Reply With Quote
Old 03-22-2002, 04:29 PM   #235
Mad Max's Avatar
They will all work.
Old 03-29-2002, 02:04 PM   #236
Default set ups
hey all!
i've been away from my gt-4 for the past 8 months (been spending all my time in electric) and i'm burning to get back out at crystal park. i was hoping i could get some suggestions on set ups for a large flowing high bite track. i've got the lola body and the different diameter foam tires as well as the overdrive pulleys, one way up front, and a diff in the rear. thanks in advance for any help.
diesel31 is offline   Reply With Quote
Old 03-29-2002, 07:23 PM   #237
acs
acs's Avatar
I ran the car box stock when I first got it. And it was great. The only thing I can think of that is a must have item is the belt tensioner. All the other aluminium stuff is optional. Your best bet would be buy the Pro version and you will be set.
acs is offline   Reply With Quote
Old 03-30-2002, 03:06 AM   #238
Send a message via AIM to ZER01
Thumbs up
Onroad Electric and Nitro "State Championships" May 4th @ Small Cars Unlimited.
ZER01 is offline   Reply With Quote
Old 04-06-2002, 06:32 PM   #239
black-knight's Avatar
R/C Tech Charter Subscriber
which model GT4 is the best choice for serious racing?
GT4-R or GT4-Pro?
Anyone go any suggestions for High Grip surface setups?
Black-Knight - None shall pass!
www.nbhc.com.au - www.facebook.com/smaracing
black-knight is offline   Reply With Quote
Old 04-08-2002, 01:56 AM   #240
acs
acs's Avatar
GT4-R or GT4-Pro?
Both of those cars would be great for serious racing. Major difference between them is the R has a one-way/rigid rear axle setup and the Pro has gear diffs front and back. The other thing is the R has 32mm rear tyres and a narrow rear end(as in dogbones and pillow balls) to accomadate them. I dont think they are legal to race in Aus just yet.
My money would be on the Pro, it has a lot off the good stuff and all the aluminium comes is blue.
BTW i thought you were an NTC3er?
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
