Old 03-13-2002, 01:30 PM   #211
contact's Avatar
Originally posted by BallPy
Has any one seen the new Collari?
the collari's are quick- we put one in the GT4 and it was fast in company with JP's etc..
Veni, Vidi, Veci
contact is offline   Reply With Quote
Old 03-13-2002, 01:32 PM   #212
My question is will take a JP.
BallPy is offline   Reply With Quote
Old 03-13-2002, 02:13 PM   #213
Mad Max's Avatar
ballply fantom is working on converting their dyno to do nitro. I don't see the need. unless your playing who has more hp.
Mad Max is offline   Reply With Quote
Old 03-13-2002, 02:19 PM   #214
Mad Max's Avatar
Hey I know its nice to have the hottest motor on the planet, but if you cant handle a std MT12 you are making a mistake. I know it took half a season get use to my upgrade from that to the RB 5port turbo. The difference in power made suspension and drivetrain changes necessary. I think foams would make that a little easier to handle.
Old 03-13-2002, 03:50 PM   #215
contact's Avatar
the engine was fresh (the car was only 1 race meeting old too)
so i think it has potential, probably a better question is can you drive as well as the bloke with the JP? that will probably make more difference than the 0.0?hp difference.
one thing we noted was the engine had heaps of bottom end at the start of the final, but after the 2nd pit stop it lost a little - not sure why - still quick though and i think you will find they are a bit cheaper than a JP
Veni, Vidi, Veci
Old 03-14-2002, 01:56 AM   #216
acs
acs's Avatar
bottom end power is everything - as long as you can put it to the ground.
acs is offline   Reply With Quote
Old 03-14-2002, 08:17 AM   #217
Mad Max I agree. But there are alot of uses for a dyno. For example you can find where your peak power range is and you can use that to adjust your gearing. You can even tell if the plug you are using is good for the Nitro that you are using. If you are a rookie yes the only reason most would have a dyno is to see how as the most hp, but for a serious racer it can be a very useful tool for tuning your car. I can wait to see if Fantom comes out with one because I will own it.
Old 03-14-2002, 09:37 AM   #218
Mad Max's Avatar
I have had dynos in the past (for electric) and in all honesty the were best at matching motors more than any thing else. Each time you run them you got different information. Now don't get me wrong you could plan some gear ratios with them but the primary benefit (in stock class) was finding out which of the motors may be the strongest or if you mis-setup a motor.
As for dynoing a gas motor It takes more time to yank the motor out than electric. Most sportsman or even experts come to the track with one motor and a spare(if your primary blows up), if you have the money for a spare.
If I need to dyno a nitro motor, I would rather go out and pick up a new one, modified or unmodifed, first. The numbers relationship on tune, plug etc. has to be done at the time of the race given the atmospheric conditions. A dyno will run as much as two of those hot JP jobs.
I'd put my money on a tire truer and a ton of foam.
Old 03-14-2002, 09:54 AM   #219
Opinions vary. I have found more uses than that. But for nitro I think that it would be a beny for the guys who mod there own engines.
Old 03-14-2002, 10:03 AM   #220
Mad Max's Avatar
I don't admit to modifying my motors, but I'm not saying I don't. If anything, I find more out at the track with extra plugs and gears than I would at home with a dyno.
Besides if you are moding your own motors you need to be really sure about what you can or should modify. plus the need for extra parts if you screw up. I can take a box stock mt 12 re and be one of the leaders all day without having to mess with the motor. fresh plugs good tune and clutch tweak and gears, I think that is all you need.
Old 03-14-2002, 10:06 AM   #221
I am not disagreeing with you. Time at the track can be the best tuning devise out there, but I still think in would be cool to at least use one just to see if what the manufacturer is saying is true.
Old 03-14-2002, 10:08 AM   #222
Mad Max's Avatar
You believe a manufacturer? LOL
Old 03-14-2002, 10:13 AM   #223
Not really. That would be like trusting a car salesman.
Old 03-14-2002, 10:15 AM   #224
Mad Max's Avatar
HEY! I'm a computer saleman! You definitely can trust me!
Old 03-14-2002, 10:17 AM   #225
Computers are a whole different ballpark. I used to be a car salesman. It was the crappiest job I ever had.
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
