Yokomo GT-4???
Old 02-21-2002, 07:30 AM
  #181
Regional Moderator
Darkseid's Avatar
acs: man, now thats one serious racing facility! It looks as though it also has elevation changes as well. Amazing!
Darkseid is offline
Old 02-25-2002, 10:12 AM
  #182
Default side ex. roundport
anybody know if there is a manifold to put a side ex. roundport in the GT4 like Baker did?
rcspeed is offline
Old 02-25-2002, 10:30 AM
  #183
jaydee's Avatar
I don't understand why??? If the Engine has a Standard Slot Port for the Side Exhaust, what benefit would one get running a Round Port?
I could understand if the Engine has a Round Port on the Side.
I haven't seen anything that would be a direct fit, but with some ingenuity, one could Adapt a Rear Round Port to the Side, but the Header would probably require some Welding, grafting the Side Port pipe to the Rear Port Flange.
jaydee is offline
Old 02-25-2002, 05:33 PM
  #184
contact's Avatar
Originally posted by acs
The track is in Brisbane, Australia. You'll notice that about 3/4 down the straight there is join in the track. This is where the touring cars turn as they don't run the long track, therefore there is a lot of braking leading into the corner. Thats the only corner where hard braking is necessary and maybe a little difficult to control with a one-way. I will see if I can try a friends one-way this weekend, which he just bought.
As for the springs Brown (#ys-1750) front Grey (#ys-1755) rear.
is that london park (or is that england park- i always get confused! )
we took our gt4 to morebank for a club day the other week - traction roll city!!
but we will have that sortd by the meca challenge!
acs have you got the solid rear end? we have one (from HH) and are debating wether to put it in or not.
contact is offline
Old 02-26-2002, 10:15 AM
  #185
Mad Max's Avatar
wasn't the round port side exhaust a picco job?
Mad Max is offline
Old 02-27-2002, 02:34 AM
  #186
acs
acs's Avatar
Yes its named England Park Raceway (a whole 3 minutes from my home) I'm only running gear diffs at the moment but I would like to try the oneway-gear diff and oneway-solid axle combinations.
I'm going to Adelaide for the Clipsal 500 in March so I will also call in to HH to buy some gear. High on my list is a new engine.
Re: Traction Roll
I read in a Mag that Chris T recomends putting the front shocks in the outside (higher) hole if it tends to traction roll.
acs is offline
Old 02-27-2002, 11:01 AM
  #187
Default Picco side ex. round port
Jaydee, yes the motor is a round port side ex. I know Baker ran this setup in Tx. and won. The graftin and welding seems like what I'll be doing, infact all I have left is the welding, just thought if there was a unit made it might be the way to go.
Mad Max yes the Picco is the one!
rcspeed is offline
Old 02-27-2002, 06:13 PM
  #188
contact's Avatar
Re: Traction Roll
if you have seen current racing lines thats the car im on about, the solid rear end arrived the other day, and im going to try different springs and oil (i was running the full stock set up) and a front sway bar.
will have to try the different shock positions.
its good to know that you can make it traction roll, as i find it easier to loose traction than try to find it!
what sort of engine, a mate of mine has just started to bring in the collari engines
contact is offline
Old 02-28-2002, 03:58 AM
  #189
acs
acs's Avatar
I've got my eyes on the new Rossi .12. Importer is in Adelaide and HH will probably sell them as well. I have heard they wont be cheap though.
stock springs and traction rolling wow! my car pushed like crazy in stock config.
acs is offline
Old 02-28-2002, 04:09 AM
  #190
contact's Avatar
is anything from the big N ever cheap!? ... im surprised HH will be going that way, but hey MMI is in adelaide too so it makes sence.
traction roll - yes, at the local track - push with stock setup, went to morebank and changed to 'sprint' 45/40's (one of the gandini 'brands') and traction roll city! through the inside hair pin 2 wheels nearly every time!
have since played more with suspension travel settings - i think it may have had too much!
contact is offline
Old 02-28-2002, 04:47 AM
  #191
acs
acs's Avatar
contact - I dont mean Novarossi. Rossi is a different brand and I dont think there is any conection. sorry if I confused you.
im using FAST or BEST gandini's 40f and 42r i would still like a little more turn in.
another racer tried my car and said I had way to much steering for him but i've always liked to have alot of steering
acs is offline
Old 02-28-2002, 01:03 PM
  #192
contact's Avatar
does it come out of the nova.. factory? and are HH bringing them in?
contact is offline
Old 03-01-2002, 01:02 AM
  #193
acs
acs's Avatar
I dont think there is any connection between Novarossi and Rossi. HH will sell them but another guy is importing them.
Rossi Engines Factory
acs is offline
Old 03-01-2002, 01:38 AM
  #194
Manticore's Avatar
Yes they are brothers.
Rossi focus on marine while Novarossi focus on land.
Manticore is offline
Old 03-01-2002, 05:04 AM
  #195
contact's Avatar
with names like novarossi and rossi they have to be related - or surely they would be going hammer and tong over naming right and infringements there of..
so are the land bassed rossi's the same as the novarossi's? (given the different heatsink colour?)
contact is offline
