Yokomo GT-4???
Old 02-06-2002, 09:56 PM
  #166
it really depends on what kind of track your gonna run. ...for a fast track....I would get the Mielke pipe........for a short and technical track...I would get the Associated pipe.
TambokGT is offline
Old 02-07-2002, 12:10 AM
  #167
acs
acs's Avatar
Umm, did someone ask about pipes??
acs is offline
Old 02-07-2002, 12:55 AM
  #168
I've got this one mounted face down, but you may want to use a piece of strapping tape to secure the crystal. Wires are tie-wrapped and tucked away behind the receiver.
t285 is offline
Old 02-07-2002, 12:57 AM
  #169
This one is mounted on it's side, shoe-gooed to the radio plate. The receiver is smaller than a Futaba PCM, so it takes up slightly less space.
t285 is offline
Old 02-07-2002, 01:06 AM
  #170
acs
acs's Avatar
My car suffers from High-speed understeer.
Front Shocks:
Lenght) 61.5
Spring) Brown
Oil) 600#
Piston) 3#
Ride H) 4mm
Camber) -2 degres
Toe) out -1 degre
Castor) 2 large clips behind
Diff) 30'000#
Rear Shocks:
Lenght) 61.5
Spring) Grey
Oil) 500#
Piston) 3#
Ride H) 5mm
Camber) -3 degres
Toe) in -2.5 degres
Diff) 30'000#
No anti-roll bars
40 sh front foam
40 sh rear foam
Protoform Stratus
Any suggestion will be greatly appreciated.
acs is offline
Old 02-07-2002, 01:13 AM
  #171
Have you tried the front one-way?
t285 is offline
Old 02-07-2002, 01:20 AM
  #172
acs
acs's Avatar
No I haven't but it was what I was thinking as well.
I am a bit worried about the brakes. We have a hairpin turn at the end of the straight. I might be able to try a friends one-way next week some time.
acs is offline
Old 02-07-2002, 04:42 AM
  #173
CL
CL's Avatar
Trader Rating: 33 (100%+)
The Protoform Stratus has a lot of rear traction. Try the Andy/Yokomo 200mm Stratus. It has more steering.
Also softer springs in the rear give U more steering. Try running silver or yellow springs in the rear.
CL is offline
Old 02-07-2002, 07:17 PM
  #174
You can also try less toe-in in the rear.
t285 is offline
Old 02-07-2002, 07:29 PM
  #175
Chinuts: u're cars are powered by hamsters and u're powered by gerbles!! HAHAHAHAH j/k C-ya at Steve's..
Carl Feltro is offline
Old 02-09-2002, 02:56 AM
  #176
acs
acs's Avatar
I've solved my understeer problems. Here's what I changed.
40sh front 42sh rear tyres
#2 piston in front shocks
more caster -- one large clip behind arm
Seems to be a good set-up, can't wait till race day.
acs is offline
Old 02-09-2002, 03:52 AM
  #177
acs
acs's Avatar
Track just after resurfacing.
acs is offline
Old 02-12-2002, 08:31 PM
  #178
acs: Wow, that's some track! Where is this? Looks extremely fast. I think the one-way would work great for all those sweeping corners. Which springs are you using?
t285 is offline
Old 02-13-2002, 03:32 AM
  #179
acs
acs's Avatar
The track is in Brisbane, Australia. You'll notice that about 3/4 down the straight there is join in the track. This is where the touring cars turn as they don't run the long track, therefore there is a lot of braking leading into the corner. Thats the only corner where hard braking is necessary and maybe a little difficult to control with a one-way. I will see if I can try a friends one-way this weekend, which he just bought.
As for the springs Brown (#ys-1750) front Grey (#ys-1755) rear.
acs is offline
Old 02-13-2002, 11:00 PM
  #180
Yeah, that's a pretty tight hairpin after such a long straight. You might want to set your brakes fairly soft to avoid locking up the brakes when using a front oneway + rear gear diff. A front oneway + solid rear axle setup will allow you to apply harder brakes though.
The full layout looks really fun. I'm green with envy...wish we had a track like that in the US.
t285 is offline
