Old 12-16-2006, 09:05 PM   #1
Taylorm's Avatar
Default What charger?
-I'm looking to pick up a charger for my 960. I want something to charge Nimh packs but also maybe be able to charge Lipos in the future. What are you guys using? Orions advantage looks like a good charger, but i'm not to crazy about spending 180.00 to charge receiver packs. What else is out there comparable for maybe a little less money? Thanks, Matt...............
Current stable... Team Associated SC8, Team Associated RC250 X 3
Tamiya F104X1...Tamiya F104W GP Edition...BMT/RC300 Frankenstein.....Edam Razor2
Checkers or Wreckers......................................................................................
Taylorm is offline   Reply With Quote
Old 12-17-2006, 12:26 AM   #2
Hey man, your near toledo, ohio.
why dont you go to the oneeightracers site and email Ted Hammer, im sure he can point ya in the right direction.
you dont need anything special unless your racing electric.
AKSHUN is offline   Reply With Quote
Old 12-19-2006, 11:43 AM   #3
teammpp's Avatar
Have a look at the X-power 601AD or Bantam E-station BC5. Around $120 each.
X-power is mainly sold in Hong Kong or China at all the main model shops (rcmart, rcsmart, jns inc).
Bantam is sold at rcaccessory.com in Tampa Fl.
teammpp is offline   Reply With Quote
Old 12-19-2006, 04:59 PM   #4
mugendude's Avatar
duratrax intelli ice is awsome it charges lipos and reciever nicd and nimh not to mention it costs 100.00 and its really simple tio use
murnan modified rb xenon R ballistic missle i love the smell of nitro in the morning
www.rc-racing.org
mugendude is offline   Reply With Quote
Old 12-19-2006, 08:54 PM   #5
Taylorm's Avatar
-checked out ice charger at tower and looks like a good deal. will probably go for it ...thanx mugendude.....
Old 12-19-2006, 09:33 PM   #6
P2gee's Avatar
You might want to check out the Triton Jr. It charges and cycles Nicad, NiMh, LiPo, and Pb (lead acid batteries). Very small compact easy to carry, and easy to use. I have been using one of these for about 4 months and it charges everything I use for 1/8 scale on road......even my sealed cell starter box. Price: about 80 bucks.
P2gee is offline   Reply With Quote
Old 12-20-2006, 05:28 AM   #7
Trader Rating: 15 (100%+)
I am using the Hobbico field charger. It does Nicads, Nimh, and Lipo's but one of the good things is that it has two chargers in one. You can charge the Tx and RX at the same time. It has a dial on both sides to adjust the amps from a fraction of a amp to three amps. It is about $50
THE DOCTOR is offline   Reply With Quote
Old 12-20-2006, 06:33 AM   #8
Serpentd's Avatar
I would look at a charger that can also charge your batteries for your starter box. The Triton is good, not my favorite, but it does all the batteries you mentioned plus the amps can go high enough for stick packs or like P2gee mentioned, it also does lead acid. The only problem with those batteries in a starter box is they are heavy and can't really be fast charged.
I'm not 100% sure, but I think it was the ICE charger that seemed to appeal to me most. I personally carry two chargers, one is the field charger that The DOCTOR mentioned, then the Novak Millenium pro for all other batteries. This way you can charge EVERYTHING before the main with no worries to have everything peaked out. Lots of options, just take your time and veiw the pro's and con's. Most chargers will work fine for what you are needing them for. If you were doing electric racing, well then that's a totally different story. Good luck!!!!
Blessed are the SIC
Serpentd is offline   Reply With Quote
Old 12-20-2006, 08:04 AM   #9
P2gee's Avatar
If you have stick packs in your starter box, the Triton Jr will probably charge them ok. Going from memory here, the Jr only has a max charging amps of 1.5. If you need to charge stick packs in a hurry the standard Triton might be a better choice as I believe it's max charging amps is 7. I personally prefer lead acid bats in my starter box as the are better suited to the relatively long duty cycle current demands of starter box use.
Old 12-20-2006, 08:10 AM   #10
Rick Hohwart's Avatar
Check out Team Orion's Avionics Advanced flight charger.
Advantage Advanced Flight Charger
At under $80.00, it is a pretty good deal considering its abilities:
Features:
• Capable of charging and Discharging:
- NiCD/Ni-MH 1-14 cells
- Li-Io or Li-Po 1-5 cells
- lead acid (Pb) batteries 1-6 [2V per cell]
• Adjustable charge current (0.1A-5.0A)
• Adjustable discharge current (0.1A-1.0A)
• “Zero Delta V” peak detection for NiCd and Ni-MH batteries
• “Constant current/discharge voltage” charge method for lithium-Ion/Po and Pb batteries.
• Compact & portable size
• Cycling (Charge to Discharge / Discharge to Charge)
• 2 line, 16 character blue backlit LCD Screen
• Button control - “Surface panel type”
• Warning sytems prevents improper voltage
• Super durable aluminum case
Specs:
Input Voltage: 11.0-15.0V DC
Battery type & cells:
-NiCD/Ni-MH 1-14 cells
-Li-Po cells 1-5 (3.6 or 3.7V)
-Lead Acid cells 1-6 (2V per cell)
Charge current: 0.1A ~ 5A
Discharge curent: 0.1A ~ 1A
Trickle charge curr.: 0 ~ 250mA
Charge termination:
-“Zero Delta V” peak detection for NiCD & Ni-MH
-“Constant current/Constant voltage” for Li-Io and Li-Po batteries
Cycling: Charge>Discharge/Discharge>Charge
Display Type: 2 line, 16 character LCD backlit
Advantage at Stormer Hobbies
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 12-20-2006, 08:44 AM   #11
Seisick's Avatar
both the team orion avionics and the trition jr seem to be based on the
multiplex, which carries tower for about 70, been using it for about a year, so far so good, charges everything, compact and easy to use.
check the coming nitro charger from dynamite, e simultaneous charges up for 6 amps for the tx rx and glow starter, too bad is not ac dc powered
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
TD: RC18mt RTR, LRP Comp Charger, (2)GP4200 Matched for Lipo Charger/Battery...LOOK!! smarking1212 R/C Items: For Sale/Trade 7 10-08-2008 04:25 PM
FS: Duratrax ICE Charger, Great Planes Triton Charger, & MRC Power Supply wrxnfx R/C Items: For Sale/Trade 15 08-20-2008 11:33 AM
Mini-V, Lipo charger, Nimh/Nicd charger, Starter, AIRBOAT CustomTrendzInc R/C Items: For Sale/Trade 2 11-08-2007 03:08 PM
Duratrax IntelliPeak DC Only Mini Pulse Charger & Towerhobbies charger$25.00(Shipped) xsxracing R/C Items: For Sale/Trade 0 10-13-2007 03:51 PM
Integy 16x7v6 Charger (with 30 amp discharge), Tamiya F201, Astro Flight 109 Charger 403forbidden R/C Items: For Sale/Trade 4 05-07-2005 08:08 PM
