Old 12-15-2006, 07:45 PM   #1
Default cant get my tc3 nitro started
I cant the motor to turn over.
I hook it up to the starter box. I attatch to the glow plug (I shouldnt have to push down on the glowplug stick should i). I push down on the starter box....i get good air coming out the pipe....i try to prime it....no start....
here are some pics of the setup....are the fuel lines okay?
indy_rc is offline   Reply With Quote
Old 12-15-2006, 08:38 PM   #2
roadrage's Avatar
Trader Rating: 14 (100%+)
make sure fuel is getting to the lines. your starter box could be rolling the motor the wrong way. the starter box wheel needs to be turning counter clockwise for the motor to fire up.
Austin Wolfe
Serpent America-Trinity/Revtech-www.ActivRC.com
roadrage is offline   Reply With Quote
Old 12-15-2006, 08:48 PM   #3
thanks for your help....the starter box was going clockwise...should i just put the black clip on the red part of the battery and the red on the black? It also didnt look like the wheel was lined up with the starter wheel.....or should i change something in the starter box?
Old 12-16-2006, 06:09 AM   #4
Pattojnr's Avatar
Trader Rating: 19 (100%+)
just a tip as for the fuel lines, i can see in the pics that the fuel line to the carb is almost getting pinched at the angle it is going under the manifold. also the fuel tube is touching the manifold. this will preheat your fuel to a point where it gets too hot , and the angle can cause a blockage or difficult tuning. if you can pre heat the engine before you start then thats better again. if thats the AAC collari engine then it has an alloy liner not a brass one. extremely tight piston pinch till it gets hot. so do preheat with a hair drier or something, it will last longer
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 12-16-2006, 07:21 AM   #5
Nice motor, i have a couple of the .21 versions.
I know they can be difficult to start, i had some difficulty with mine when i first got them.
Another thing, those carbs suck, you may wanna replace it with a two needle carb, one without the spray bar.
AKSHUN is offline   Reply With Quote
Old 12-16-2006, 12:57 PM   #6
roadrage's Avatar
just reverse the red and black clips from where you had them. it should start right up inless the glow plugs no good
Austin Wolfe
Old 12-16-2006, 01:19 PM   #7
just got back from hobbytown..the guy really helped me out.the problem was simple..itneeded a couple more shims to allow the flywheel to turn freely....it wasnt...thanks to hobbytown usa! and you guys as well
dvd video for anybody that is getting started in nitro rc...(youtube) tancp81 Malaysian R/C Racers 0 01-03-2007 10:23 AM
OPS OP82101 .21 Nitro motor. NIB. Never started, Gold head vintagetamiya R/C Items: For Sale/Trade 2 01-02-2007 08:18 PM
How to get started in Nitro RoostAZ Electric Off-Road 9 07-27-2006 12:03 AM
Getting started in nitro SCwerTA Rookie Zone 15 01-12-2005 08:52 AM
Nitro racer trying to get started on Electrics revzalot Electric On-Road 6 11-08-2004 05:27 PM
