Need Help! THS HEADERS
Does the THS Racing Off-Road One-Piece Tuned Pipe 1/8(JUST HEADER) Fit the THS Racing Tuned Pipe Set HPI RTR-3( PIPE )
NEED HELP AS SOON AS POSSIBLE.. THX
Re: Need Help! THS HEADERS
ok thanx for you help
THS sells a header and pipe combo for the RS4 3 RTR. They do not sell the header separately. Check this out.
http://www2.towerhobbies.com/cgi-bin...?&I=LXCPX4&P=7
This system definitely fits your RTR 3. Check out my SS with this pipe installed.
http://www.rcpics.net/view_single.php?medid=5
-Jeff
-Jeff
slide valve
hey jeff,
just wondering what did you use for your slide carb. I was looking for a conversion kit for it but had no luck.
Also what do you think about the THS pipe on your car? I heard a lot of people talking about it at my LHS. What do you think? worth the money?
The slide carb is an O.S. 10A carb. Fits right up, although I bought the car that way.
The THS pipe seems good, top end power, decent low end. Looks purty too!
-Jeff
-Jeff
Location: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
for all you guys looking to fit a slide carb on the rtr3 ..HPI maks a slide carb horn set that came in the SS only..it is real easy to do the slide carbs with the rtr3,N MT,and super nitro rally....the part # is 85039....and youll need to laook at the SS manual on HPI's site....you also might need the throttle linkage set...you can compare #'s in the manuals on the site...
