Old 12-02-2006, 05:20 PM   #1
XNXIXTXRXOX's Avatar
Default Full Throttle Handling Issue
My T.A. Nitro TC3 Plus has quite a bit of power. when i give it full throttle, the car banks right uncontrolably forcing me to slowly increase speed. the steering is fine and the car runs straight. could it be the differential or the toe settings on the tires? also, when the car isnt running, i keep the car in one position making the wheels "skid" and manually turn the drive shaft. when i do this, the front left wheel slightly turns right while spinning. could this contribute to the problem? Any help would be appreciated. Thank you
XNXIXTXRXOX is offline   Reply With Quote
Old 12-02-2006, 07:12 PM   #2
rocca30's Avatar
the only adviise i can give is to get a Mugen.
RC AMERICA / / HUDY // SRC / / JC JEWELERS/ / GOT GOLD // MAXX POWER // EXTREME RACING FUEL //
rocca30 is offline   Reply With Quote
Old 12-02-2006, 07:26 PM   #3
check for glitching in the steering servo, check your diffs,and it's probably torque steer.shaft cars are known for that
Ahhh the smell of nitro in the morning!
Brooklyn Hobbies Team Driver
[url]www.brooklynhobbies.com[/url]
Team Trinity
[url]www.teamtrinity.com[/url]
Gary Figueroa
GFIGUEROA is offline   Reply With Quote
Old 12-02-2006, 08:04 PM   #4
lil-bump's Avatar
Trader Rating: 83 (100%+)
Check your CVD's make sure there are not binding. When a Cvd is not able to rotate freely it will cause the wheel to slightly turn.
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 12-02-2006, 10:19 PM   #5
Taylorm's Avatar
-or a bearing binding. not to insult, but are tires even diameter side to side/...............
Current stable... Team Associated SC8, Team Associated RC250 X 3
Tamiya F104X1...Tamiya F104W GP Edition...BMT/RC300 Frankenstein.....Edam Razor2
Checkers or Wreckers......................................................................................
Taylorm is offline   Reply With Quote
Old 12-03-2006, 06:40 AM   #6
yea they are. I adjuasted the toe on the front left tire and i checked the diff. im gonna give it a go this morning.
Old 12-03-2006, 12:26 PM   #7
Angry
still got the problem... any ideas? if its torque steer how do fix it? or could it be something else? also, how do i properly check the diff.?
Old 12-03-2006, 02:36 PM   #8
itchy b's Avatar
make sure that the rear toe is equall both sides as if it is different, this can cause the car to go sideways under acceleration also
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 12-03-2006, 04:37 PM   #9
Trader Rating: 18 (100%+)
Default Full throttle
I have had about 6 or 7 NTC3s, and for the most part, they were great starter cars with very little problems. One of the cars had the same problem you are having.
I checked the diffs,bearings,toe,tire diameter,servo binding,looked for bent shafts, everything I could think of.
After fighting the car for about 2 weeks, I finally found the problem.
The actuall size of the front hubs were not the same as far as width.
I installed new hubs,set the track width,and checked the toe again, and the car was fine.On one of my trips to Associated, I took the old hubs with me and showed them to one of the guys there. He actually measured the hubs with a caliber because he could not believe the difference in size from the old hubs to a set of new ones.
Anyway, some of the manufactured parts to vary somewhat.
Check your bearings, cvds,driveshaft,servo from binding. Take the car completly apart if you need to.
As one of the othe posts stated, shaft driven cars do have torque steer, but it should not be so bad as to where the car is uncontrolable.
brc358 is offline   Reply With Quote
XPS Issue. Slight stutter on full throttle pull Cain Micro and Mini Scales 0 10-18-2007 10:52 AM
Front Handling Issue XNXIXTXRXOX Nitro On-Road 10 02-09-2007 07:56 PM
Handling Issue XNXIXTXRXOX Rookie Zone 11 11-03-2006 05:11 PM
RS4 High speed handling issue NickRummy Nitro On-Road 26 04-19-2006 08:29 AM
Issue with my truck. I get no steering or throttle. Brand new. BONESTOCK Rookie Zone 7 12-11-2005 11:40 PM
