Old 11-26-2006, 09:25 PM   #16
Gambelli's Avatar
Originally Posted by theBUZZ
Ok, I tried restarting just before. I reconfigured the starterbox to run earlier, which worked extremely well, the flywheel was moving very fast and cranked over about 4 times (hard to count). This was after heating the engine with new heat gun to about 120 degrees. But, it got stuck at TDC after goign past it 4 times. This is the problem I think: the flywheel is rotating but the piston isnt? Something very wrong here. I have to take the engine out, and rotate the gears which turn the piston, because the flywheel doesn't. Is their a problem with the stock instructions on the flywheel for the Kyosho V One RRR?
Thanks very much for your help guys, it almost got it
Hi There,
I just broke in my OS TZ on a RRR this wekeend. I found it was quite easy although yes, the flywheel got stuck dozens of times during the process. And as everyone else has said, you just need to turn it over with a screwdriver and then rotate it back so it's got the most amount of play ready for another go...its alot of effort but you'll get there...
In regards to heating it up, I did a little bit but nothing major.
But, if your flywheel is slipping then thats a different issue altogether, you need to check your flywheel install and check whether or not you are using a washer on the engine before putting on the flywheel collet, this may or may not help/hinder the tightening of the flywheel.
Also what breaking in method are you using, the OS one or your own?
I'm using the much talked about Josh Cyrul method and once I got into the swing of it this worked a treat, I got 11 tanks through my car in 2 days....
Good luck with it
Steve
Gambelli is offline   Reply With Quote
Old 11-26-2006, 11:02 PM   #17
I need serious help, the flywheel is the problem certainly, but because it is screwed up I can't physically undo the nut to reassemble the flywheel.
theBUZZ is offline   Reply With Quote
Old 11-26-2006, 11:33 PM   #18
If someone out there knows, on page 42, peice 141, On the Kyosho V One RRR manual, it Peice 141 meant to go all the way in? It just doesnt seem to work for me
Old 11-26-2006, 11:39 PM   #19
hav_lova's Avatar
Having a look at dad's V1RRR WCE manual i assume you mean the little collet.
I'm assuming that the engine is turning over and you cant undo the nut?
You have a couple options
Get a really tough cable tie and put it in the exhaust port so the piston cant move and you can undo the nut
Take of carby and put the cable tie in the hole in the crank
Buy a piston locking tool (im not sure where or how much though)
If the flywheel is off spread the little collet with a screwdriver to get it all the way on the crank, it shouldn't need to go all the way into the flywheel as long as its tight.
Just playing with bigger toys now...
serpentrc.com.au
hav_lova is offline   Reply With Quote
Old 11-26-2006, 11:56 PM   #20
Serpentd's Avatar
Wow, I know this can be a pain in the ass, your lock tite is holding the nut. If you can avoid putting anything in the engine to lock it up though, I would. A few things to try. Get a larger flat screw driver like a #2 or #1 and sort of wedge it between the back of the flywheel and the front of the motor. Keep in mind to not over wedge it, just go by feel and then try and undo the nut.
A lot of the times if you stick something in the exhaust it will cut it in half because of the sharp edges. A piston lock tool is better...but don't over CRANK on the nut as you can bend or distort the rod, rod bearing. However, if you apply a SLOW steady pressure on the crank nut you will probably be ok. Slow and easy.
The thing I use is a crank/rod stopping tool made out of strong plastic that is inserted through the back plate. This works best and suggest buying one. However if your impatient, try the other things first being careful to not over torque that nut that can create internal damage. Just be careful! I will search online to try and send you a photo of what I mean. Or I might take a photo of mine and post it. Good luck. Follow what hav_lova said avter you get it off.
Blessed are the SIC
Serpentd is offline   Reply With Quote
Old 11-27-2006, 12:01 AM   #21
Serpentd's Avatar
Go here...this is what I was talking about...http://www.acehardwarehobbies.com/2....oducts_id=9583
Blessed are the SIC
Old 11-27-2006, 12:32 AM   #22
hav_lova's Avatar
Yea, i stop the cable tie being broken by using the head which is the strongest part i've only ever had one break... Just take your time
serpentrc.com.au
Old 11-27-2006, 02:40 AM   #23
I jsut got it out, had to lock the gears with a hand, which is now bleeding. But more to the point there is this little collet? that is meant to go in the flywheel to lock the flywheel on the rod. Is this supposed to submerge fully into the flywheel, as it is a very, very tight fit.
it is peice 141 on page 42
It is refferred to as the tappered cone on Ace hobbies. http://www.acehardwarehobbies.com/2....oducts_id=2494.
Old 11-27-2006, 02:41 AM   #24
hav_lova's Avatar
From memory it doesn't have to go ALL the way in the only requirement is that the nut holding the flywheel down is very tight
serpentrc.com.au
Old 11-27-2006, 03:28 AM   #25
Bundy_Bear's Avatar
I had this problem with my Mega ZX12 on the G4S. I do not recommend putting anything up the exhaust port as i learnt the hard way
Solution i found was to remove the sleeve and piston (conrod still attached) and sold onto the crank pin with your fingers and try and stop the crank from turing over... Not easy to do i know, but i haven't found a piston locking tool for a turbo button as yet, nor do i believe it is wise to apply that much pressure to the conrod etc.
My 2 cents worth
BB
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 11-27-2006, 03:28 AM   #26
Serpentd's Avatar
Dude, you are right. The "cone" will never fit 100% into the flywheel. Your only concern is to make sure the cone is all the way on the crank and against the engine bearing. Then slide your flywheel on and crank that nut down with loc tite. Use enough loc tite, just don't get carried away. You can crank it down good with the suggestions used to remove the nut. It needs to be tight. This is the reason for the conical shape of the "cone". Cones and flywheels come in different sizes, this is why you will not see the cone go totally into the flywheel. It's not necessary. However a tigh nut is VERY necessary. They also make "flywheel" holders to help on this. http://www.serpent-usa.com/es12801024/index.htm
This is a cool tool because it holds the flywheel to tighten and loosen, plus you can check your end play. With these type of holders though, you don't want to over crank and bend your flywheel pins. Very easy to use. Good luck!
Blessed are the SIC
Old 11-27-2006, 03:43 AM   #27
hav_lova's Avatar
I've never had a problem with putting a cable tie in my exhaust port, i've done it so many times i strip my engines right down after each race meet
serpentrc.com.au
Old 11-27-2006, 04:37 AM   #28
Originally Posted by Serpentd
take out the glow plug and put about 4-5 drops of afterrun oil in the cylinder, placed a rag over the top of the engine and just turned it over about three times in 30 second intervals. This helped to loosen it up some.
This is a great way of cutting the engine's life expectancy by more than half. If your turning it over whilst it's cold, your wearing the piston and the liner "or breaking them in" at that temperature. When you start the engine and run it, the liner taper expands, you lose compression and you have "blow by"
I always use a hair dryer or a heat gun to get the liner to expand, and then crank it over on the box. This puts much less stress and strain on the conrod and bearings.
Rody is offline   Reply With Quote
Old 11-27-2006, 10:06 AM   #29
rmdhawaii's Avatar
Try this:
http://www.nitrokb.com/vonerrr/faq.html#engine
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 11-27-2006, 10:10 AM   #30
Serpentd's Avatar
Really? I guess that makes sence. I have only tried that once. However I don't think I spun the motor over that long. Maybe 10-15 sec. But either way, I do see your point. Thank you very much for the insight. I will be sure to NOT do that again. I just haven't raced for a few years and when I got this TZ, wow...SUPER tight! I use to run all the modifiied Callari, Rody etc, never had it feel that tight. Then again maybe I lost a few paitence. Thanks again for setting me straight.
Blessed are the SIC
stuck pinion? streetracer745 Electric Off-Road 13 11-10-2007 04:46 PM
Piston Stuck Cheeny23 Nitro Off-Road 8 10-24-2007 06:12 PM
Stuck in Second gear Blaze1 Nitro On-Road 2 05-26-2004 09:16 AM
Okay, Now I'm Stuck finny Australian Racing 8 04-18-2004 07:37 PM
OS .12 tr came stuck in TDC AE Racer Nitro On-Road 19 08-15-2003 11:22 PM
