Integy tire truer..........
http://integy.automated-shops.com/cg...21106442530.fe -Is this unit any good?, or do i go for the Hudy...............
here's my recommendation.......
find a used Integy here on the FS forum for about $110- $120 (average going rate for a used one). Then buy the Hudy motor for $85 and a bit if you want for about $30.... maybe the used Integy will already have it- mine did!! You can mod the Integy to fit that Hudy motor. You need to do some soldering on the PCB board to remove the Deans connectors installed in it and then hard wire the Hudy motor. The Hudy is a bit larger in diameter and will not clear the deans connectors on the stock PCB set-up. You will also have to turn the On/Off switch upside down to clear the motor. You can use the stock fuse holder, but it will require just stuffing it inside the case as it will not clear the motor either. I bought a 30 amp RV circuit breaker for mine.... it is made by Borg Warner... and it's small. I epoxied to the top inside back of the case. It has an automatic reset after about 30 seconds if you happen to trip it... I've never tripped it cutting 5mm off a 1/8th rear tire. I have $220 invested in my truer!! And it's sweet!! |
i had this truer and it works good. first thing to do when you get one is toss the saw cutter blade. get yourself a carbide bit and it will cut just like the $500 truer. the motor that comes with it works just fine.
Go for the OFNA Automatic tire truer the motor is as strong as the Hudy Automatic tire truer for merely half the price.
find a used Integy here on the FS forum for about $110- $120 (average going rate for a used one). Then buy the Hudy motor for $85 and a bit if you want for about $30.... maybe the used Integy will already have it- mine did!! You can mod the Integy to fit that Hudy motor. You need to do some soldering on the PCB board to remove the Deans connectors installed in it and then hard wire the Hudy motor. The Hudy is a bit larger in diameter and will not clear the deans connectors on the stock PCB set-up. You will also have to turn the On/Off switch upside down to clear the motor. You can use the stock fuse holder, but it will require just stuffing it inside the case as it will not clear the motor either. I bought a 30 amp RV circuit breaker for mine.... it is made by Borg Warner... and it's small. I epoxied to the top inside back of the case. It has an automatic reset after about 30 seconds if you happen to trip it... I've never tripped it cutting 5mm off a 1/8th rear tire. I have $220 invested in my truer!! And it's sweet!! For the price, you can't beat this truer. You just have to have a little patience but it works great. |
I'm not 100% he has the motor in stock, but I got mine at
www.ashfordhobby.com , (800)380-6517- you'll get some of the best customer service from an online retailer you've ever had!! Give him a call and tell him Corey referred you. If he does not have it, it will take about a week to get in. It's well worth the $85 or so that the motor costs. I'll take some pics later today and post them here. |
4 Attachment(s)
Here's the modded pics:
#1) There's no way the dinky Integy motor compares to the Hudy :confused: #2). Here's the PCB work I had to do.... the Integy motor and main power originally used deans connectors, of which the female half was soldered to the PCB board and the male half plugged into them. The Dean's connectors would not clear the Hudy motor. I hard wired the motor and main power coming in directly to the PCB board instead of using the Dean's connectors. I recommend tinning the wires at a 90 degree angle before hard wiring them to the PCB.... it's that tight!! #3). Here's the Borg warner 30 amp circuit breaker. The original fuse connector can be tucked behind the motor, but it will have to be inside the case. I used this circuit breaker because it is self resetting after 30 seconds, so there is no need to open the c ase to change the fuse. It is epoxied to the upper case above the motor. #4). Here's the back of the case. On/Off switch had to be turned upside down to clear the motor. I aslo put an undercoating plug in the hole where the original fuse was to keep the clean look. |
i have this truer,i only do 1/12 and 1/10 tires on it for 1/8 it will not work good,yes the motor sucks but the thing was cheap. the hudy bit is not better than the hack saw blade, i get better tires from the hack saw,just go to the store and get a good hack saw blade and to cut it to size just use pliers and bend it and it breaks real easy,change the blade often, or you can go buy a H.A.R.D truer, you can get a car for one of these babys but i hear they work good. oh and they use a blade too.
You think that a hack saw blade cuts better than the Hudy Carbide blade. |
but for the money? it will do. the best truer is not going to win you races but a good motor, servos, quality tires/ right compound will do wonders for you. think about it. |
Originally Posted by RCRjuanabbe
Taylorm, you did not mention about the money issue, this has always been a sore subject to me. go for the best that money can buy that is if you have a disposable money. you see I have this truer and I do not see anything wrong with it. motor not strong enough..... I give you that.. but whatever happened to "preparation"? I hope you prepare before you go to the races. I true my tires way before the races so that i am not in a hurry. cutting the tires in 1mm increment on this truer is not true. I can cut up to 3mm in one pass . hacksaw blade does not cut as fine as a carbide tip however if you keep it new it will do the job. a hacksaw blade will give you plenty of blade for mere $2 bucks. no doubt Kamikaze and Richey will not steer you wrong.
