Old 02-19-2003, 01:12 PM   #16
Barry, congratulation for the race,
I would like to know why last year you used the setups(ntc3) close to the manual (yellow front laydown, red rear) and acctualy you are using the set up like the worlds, shocks stand up on front , maybe this set up is better ?
2- i would like to know why you do not use solid axle on rear ?
3- i would like to know why sometimes you use solid axle on front and sometimes oneway ?
4- could you post the winternats set up here on forum , or just tell us the springs shock location etc...
ps: by the way I am a distributor from Team Associated in Brazil
and i made a very good set up for rubber tires, if you want to know i send you .
Thank you very much,
Fabian Kaloustian
fabian is offline   Reply With Quote
Old 02-19-2003, 02:08 PM   #17
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
Barry, You know you'll be bombarded with questions the first week or so since you came to this forum. We're glad to have you though- it'll calm down.
I wanted to congratulate you on those couple of good runs you had in Orlando. That one ruin in 19turn was practically flawless.
I also wanted to let you know that you gained a lot of respect from my point of view, and I'm sure from many others when you checked up after touching Dumas. It looked like you really got hurt because 3 others cars got by you, but you ended up winning anyway. I guess that just goes to show what good sportsmanship will do. That probably ties in with the old saying "what comes around...". You certainly didn't live up to your reputation that week. Keep up the good PR work. I'll make a point to shoot the crap with ya next time I can afford to make a big race.
BTW- good job on the mic, too!
BigDogRacing is offline   Reply With Quote
Old 02-19-2003, 02:13 PM   #18
trackdesigner71's Avatar
Send a message via AIM to trackdesigner71 Send a message via Yahoo to trackdesigner71
Barry, I dont know what experience you have with 12th scale but I am contemplating getting the 12L3. Any setup suggestions?
trackdesigner71 is offline   Reply With Quote
Old 02-19-2003, 02:45 PM   #19
Trader Rating: 16 (100%+)
Barry............congrat on the Winter National. If you remembered the Hong Kong open international race, can you tell us what was wrong on your gear box....? The reason I asked is because I realized that the light weight 2-speed housing (spur gears) from AE just discontinued.............does that have to do with the gear stripping problem.........?
I personally didn't have one single gear stripped, and I use the OEM stock housing.........but I heard so many ppl have gear stripping problem, that is the solution?
Last, I realized some of the team driver modified the pressure line input on the dual chamber pipe (by adding a pressure nipple and relocated to the front top part of the pipe......)......Why is that? And what are the PROS nad CONS on that move...?
Thanks..........Rookie Solara
Old 02-19-2003, 02:57 PM   #20
Brian McGreevy's Avatar
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Barry, can you tell us any information regarding the new KR motor. I know my motor sponsor wont' have them for quite some time after they come out...but i'm curious as to what i can look to expect
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 02-19-2003, 03:54 PM   #21
hi Barry , have you ever tried using rubber tires in your NTC-3 if so , how did you fell the diference against other cars ,couse i really know that the tc3 with foam tires is really fast but here in brazil we only use rubbers... and the history is very different!!! if you´ve tested could you please post your set-up... and congratulations again!!!!!
Fura Fura is offline   Reply With Quote
Old 02-19-2003, 03:56 PM   #22
mike_Webb's Avatar
Send a message via AIM to mike_Webb
Barry is probably thinking "Why did I ever create a account on here"
AE should pay him overtime with all the questions he is getting.
mike_Webb is offline   Reply With Quote
Old 02-19-2003, 04:27 PM   #23
Default Hey Barry!
You got PM! really need your help!
dragtek is offline   Reply With Quote
Old 02-19-2003, 05:18 PM   #24
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
Originally posted by mike_Webb
Barry- I know this is probably a tough question to answer but what is the best way you go about freeing up your drivetrain on your TC3? At the Snowbirds there was a TC3 on display and that thing was really really free and would spin for a long time.
Also do you run 48 pitch Spur and Pinions on your TC3? A friend was looking at your car and noticed it and asked me later if you were but I never really looked closly. I figured it was 64 pitch.
Did you guys make a running change on the new Gears for the TC3/NTC3 or is there a New Part number?
Thanks Barry
Mike Webb
Mike...maybe I can help here and give barry one less question...
all the gears are a running change....and right now,they are the only ones on asssociated's shelves..
thhe ball diff ring gear has the same #...(2329)..they will now be packaged 1 to a bag for 2.50$ each
teh pinions are still 2 to a pack and are 4 bucks...
the solid axle and OLD one way gear have the same #...3939...they are 6 bucks because they are hand drilled....
the NEW one way gear for the HD one way is also the same #1732...and they are 4 bucks....
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 02-19-2003, 05:59 PM   #25
NTC3NUT's Avatar
Barry, Congrats on your latest win! I had the chance to meet you & the rest of the "A Team" at the Worlds in Cinnci last summer. You guys had no problem letting me hang out in the pits, you answered all my questions, signed autographs, and let me take a ton of photos that helped out alot of us on this board. That 200mm final was awesome to watch, nail biting to the very end. I am glad I have the chance to thank you personally for that here. I have to be honest, with only one NTC3 at the Winter Nats, I didn't hold out too much hope for a repeat, but as usual you pulled it off. I know alot of us where cheering you on, and where very excited with your win. Keep up the good work, Go Associated.
NTC3NUT is offline   Reply With Quote
Old 02-19-2003, 05:59 PM   #26
If they are using the same old number, how can I tell those are OLD or NEW when I recevied them from mail order or from local hobby shop.............
Please advise..........thanks
Old 02-19-2003, 06:01 PM   #27
Francis M.'s Avatar
just specify you want the new material rookie solara
it is a yelowish clear color. So you will be able to tell
if you got the new gears.
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 02-19-2003, 06:02 PM   #28
NTC3NUT's Avatar
The new gears are all white(ish), the original gears are black.
Old 02-19-2003, 06:26 PM   #29
Big Daddy Boomer's Avatar
Send a message via Yahoo to Big Daddy Boomer
Originally posted by lucyinthesky
When are you coming back to visit us at Trackside? It's probably too cold for you here anyway...
Barry
I want to thank you for presenting the picture for me at the Novak race here at Trackside. As you saw, it meant alot to Scotty.
And on a side note... Next year, I DO want a piece of the Golden Tee action considering I have also made Paul my
B!tch
Thanks again
Jeff (Boomer)
Big Daddy Boomer is offline   Reply With Quote
Old 02-19-2003, 06:47 PM   #30
Company Representative
ammdrew's Avatar
Trader Rating: 25 (100%+)
barry you are going to be up all night answering questions
andrew
ammdrew is offline   Reply With Quote
Is it true about Barry Baker microcrazy24 Electric On-Road 27 09-19-2007 09:10 AM
barry baker video better than you Nitro On-Road 1 05-15-2005 09:17 PM
Talkin' with Barry Baker NR Electric On-Road 393 04-11-2005 12:40 PM
Barry Baker MR4-TC edition Danpatinod R/C Items: For Sale/Trade 10 04-21-2004 10:25 PM
Barry Baker Going to Hawaii Steve Weiss Electric On-Road 24 12-07-2003 10:26 AM
