Old 11-07-2006, 07:41 PM   #1
uniquexme's Avatar
Send a message via MSN to uniquexme Send a message via Yahoo to uniquexme Send a message via Skype™ to uniquexme
Default Ceramic Ball Bearings
guys, i was thinking about changing all my G4S ball bearings to ceramic ball bearings, is it advisable to get them changed as they are not cheap at all.
- how better would the car perform?
- what brand of ceramic bearings is good?
- how much estimate it cost to change it for the whole G4S?
- how long would ceramic bearing last, compared to ball bearings?
- is it advisable to change?
i have revied Boca Ceramic ball bearings, and have a hard time finding the right series, they have 3 types of Ceramic :
- Si3N4 (temp 2552oF)
- AL203 (3180oF)
- Zr02 (1800oF)
then they have different series :
- Ceramic Premium
- Ceramic Lightning Econo
- Ceramic Lightning Ultra Seal
- Ceramic Lightning Yellow Seal
wah, really dun know which one to buy. any idea?
uniquexme is offline   Reply With Quote
Old 11-07-2006, 08:25 PM   #2
rcabj's Avatar
for normal amateur drivers like me i think not worth it...better improve our driving and car setups ... just my 2cents
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 11-07-2006, 09:00 PM   #3
lil-bump's Avatar
Trader Rating: 83 (100%+)
For me. I'm would put them in the clutch bell only; just for the heat build-up. My skills don't warrant these anywhere else.
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 11-07-2006, 09:19 PM   #4
uniquexme's Avatar
hmm, true also, but last time i tried to roll my frenz MTX4 on the track, wow, its so smooth. but i really wonder would it make a difference in high speed rotation. wat u think? i would also consider only changing the rear engine ceramic to see the difference 1st.
Old 11-07-2006, 10:58 PM   #5
Registered User
Ceramic bearing set will cost more than your G4
COREX is offline   Reply With Quote
Old 11-08-2006, 02:25 AM   #6
team novarossi's Avatar
Send a message via MSN to team novarossi
3 years ago i replaced the original serpent steel ball bearings for ceramic's from boca.
just all the bearings except the 2 for the clutch, thos are stand still for the most of the time
By that time i was driving the 950(and R) and nowadays i have the same bearings in my 966.
after using them 3 years they get better and better!
I managed to ruin only 2 of them, from the 2 speed axle.
After using them more than 3 years without problems I think there certainly worth there money!!
team novarossi is offline   Reply With Quote
Old 11-08-2006, 02:54 AM   #7
hav_lova's Avatar
If you want better bearings take care of your stock ones.
Clean the grease oil and if you want run something through them to free them up then oil. Do it after every couple race meets and you'll never have any problems.
Just playing with bigger toys now...
serpentrc.com.au
hav_lova is offline   Reply With Quote
Old 11-10-2006, 07:44 AM   #8
three50zx's Avatar
I definitely agree with hav_lova. This year I started breaking down my car after every 2 to 3 weekend runs to check for worn/ damaged parts and cleaning my (stock) bearings rigorously and just that made me a more consistent driver week to week. Also, the transmission was just as smoothe as my friends car who went out and bought Ceramic bearings. Don't waste your money unless you make money racing these cars.
good luck
three50zx is offline   Reply With Quote
Old 11-10-2006, 05:25 PM   #9
uniquexme's Avatar
guys, how do u clean the bearing? last time i place them in a small plastic container, fill it half with engine oil and shake it, with the plastic seal removed, but then after cleaning some bearings were damaged. so from that onwards, i dare not remove the seals, just rubbed with cloth, then put a few drops of bearing oils on the seal and spin it.
Old 11-10-2006, 05:46 PM   #10
Car Breaker's Avatar
I want to know too, I used to remove rubber seal and clean the bearing but this will eventually destroy the seal.
how do people clean their bearings, will sonic shaker helps ?
Xray X12 2015
ARC R10 ATS
Car Breaker is offline   Reply With Quote
Old 11-10-2006, 07:00 PM   #11
hav_lova's Avatar
I remove the seals on both sides of my bearings, and either spray them out with brake cleaner or soak them over night in shellite. just dont have any flames etc near the shellite oil, make sure the rubber covers are straight and put them back on.
serpentrc.com.au
Old 11-10-2006, 10:50 PM   #12
razzor's Avatar
I use a RPM bearing blaster.
http://www2.towerhobbies.com/cgi-bin...?&I=LXEV92&P=7
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 11-11-2006, 02:01 AM   #13
Orfeous's Avatar
Send a message via ICQ to Orfeous Send a message via AIM to Orfeous Send a message via MSN to Orfeous Send a message via Yahoo to Orfeous
i bought 12 ceramic hybrid bearings for my S960
they run veeeery smooth
Orfeous is offline   Reply With Quote
Old 11-11-2006, 11:17 AM   #14
How do you clean your ceramic bearings?
Acid
Acid is offline   Reply With Quote
Old 11-11-2006, 11:35 AM   #15
Orfeous's Avatar
Denaturated alcohol and then reoil with bearingoil..
Benefit of ceramic ball bearings and diff balls RCSteve93 Electric On-Road 23 09-02-2008 03:34 PM
3x8 Ceramic Thrust Ball Assy with Ceramic Balls dgullickson Commercial Marketplace 0 01-04-2008 10:22 PM
Ceramic Ball Bearings? LOSI123 Electric On-Road 11 02-20-2007 07:41 AM
Full Titanium Ceramic Ball Bearings J Smith Nitro On-Road 8 09-09-2004 07:05 PM
Ceramic bearings/ball ABEC Grade Aku-Man Electric On-Road 10 05-31-2004 12:20 PM
