Old 10-28-2006, 10:01 PM   #1
TPB
Engine Break-In Stand
Do any of you use a engine break in stand as a engine test bench?
I want to use one as a engine test bench to get tune etc before putting on the track, what do you think?
TPB is offline   Reply With Quote
Old 10-28-2006, 10:16 PM   #2
richey's Avatar
Send a message via MSN to richey
The break in stand is not designed to tune a motor before you run it on the track it is designed to put load on a motor while you run it. This will not be anywhere close to the tune you will need when you run the car on the track
Silver Bowl Raceway Operator
www.TeamTaylorRacing.net
Byron's Fuel, Airtronics
JoshStevensFoundation.org
richey is offline   Reply With Quote
Old 10-29-2006, 01:35 AM   #3
Erm.. not feasible. Like wat richey has said. U better put onto your car and tune it to suit your kit n race
Black_Widow is offline   Reply With Quote
Old 10-29-2006, 01:54 AM   #4
TPB
All I want to use it for is to test to see if engines run and get a basic tune on them, also to try and replicate some run-on issues. What do you think?
Old 10-29-2006, 11:19 AM   #5
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
You can get a very basic tune on the bench.. Put it in your car to do the actual tuning. The load factor, the heat etc... If you want to tune your engine put it on the track.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 10-29-2006, 12:30 PM   #6
Evil's Avatar
If you want a basic tune bolt a prop on it as the load,it also offers some cooling as well.
Evil is offline   Reply With Quote
Old 10-29-2006, 02:44 PM   #7
I already use a prop on the break in stand.. I tune my engine enough to run on the bench, but I still have to tune the engine in the car.
Old 10-30-2006, 10:38 PM   #8
Lil Paul's Avatar
Default TEMP
I used the bench on many engines, and I did not like it because the prop did not allow the engine temps to raise to what I think is a good break-in temp much more a tuning temp. Not getting the temps up, and trying to tune a motor will yield nothing but headaches. I tried wrapping the head with Foil paper, but like the other guys said, just do it in the car. A good compromise, is in the car on the starter box. I do this sometimes just to get into the range of where the engine needs to be for that day, but in the end I still tune on the track.
Lil Paul is offline   Reply With Quote
Old 10-30-2006, 11:03 PM   #9
richey's Avatar
Wrap a shop towel around the head in a manner that you can get your temp gun in to the top to temp the motor. I have been using a break in stand for years and have had great luck breaking in motors this way.It is a major time and headache saver.
WTB Engine break in stand stimcon R/C Items: Wanted to Buy 1 08-30-2006 08:51 PM
WTB: Engine break-in stand FastEddy R/C Items: Wanted to Buy 0 07-27-2006 12:49 PM
engine break in stand sand geek R/C Items: Wanted to Buy 1 05-18-2006 07:26 AM
Nanda Engine Break In Stand click, dublin Onroad Nitro Engine Zone 17 12-30-2005 10:44 AM
Nitro Engine Break-in stand rodneybarrett R/C Items: Wanted to Buy 0 01-21-2004 09:48 PM
