Setting up the Centax Clutch the righ way! >
Old 10-18-2006, 06:25 PM
Default Setting up the Centax Clutch the righ way!
Guys,
As the title says how do you set up the centax clutch the right way, is there a site or guide that you can show me. First time using the centax clutch.
BeBop is offline
Old 10-18-2006, 07:17 PM
fastharry™'s Avatar
Location: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
Originally Posted by BeBop
Guys,
which car,btw?..
http://www.mytsn.com/publ/publ.asp?pid=10534
fastharry™ is offline
Old 10-18-2006, 07:36 PM
rmdhawaii's Avatar
This might help: http://www.rctech.net/forum/showpost...9&postcount=42
rmdhawaii is offline
Old 10-18-2006, 10:10 PM
mtx-4
BeBop is offline
Old 10-18-2006, 10:28 PM
hav_lova's Avatar
Thats very interesting so clutch gap is different to end play, whoops
hav_lova is offline
Old 10-18-2006, 11:04 PM
Default Clutch
Seems similar to Mugen, although it would be a good idea to get a copy of the Mugen instructions since you have the car.
onthegas is offline
Old 10-18-2006, 11:14 PM
asw7576's Avatar
You need a caliper.
0.6 - 0.8 mm for my taste
0.8 - 1.0 mm for brutal acceleration.
Attached Thumbnails Setting up the Centax Clutch the righ way!-clutch-gap.jpg
asw7576 is offline
Old 10-19-2006, 05:41 AM
Trader Rating: 95 (100%+)
Default Clutch
Go to cefx.net and you will find clutch setup tips.
latemodel13 is offline
Old 10-19-2006, 02:56 PM
lil-bump's Avatar
Trader Rating: 85 (100%+)
Default clutch too tight
What do you do when the clutch is fully assemble with the clutch bell and bearings and you have no end play? (ie the clutch bell will not spin freely). The only thing I seen that fixed this problem is I installed a small shim between the thrust bearing retainer and the end of the crank shaft. It seems that the problem is that my flywheel cone does not sit deep enough into the flywheel which causes my entire clutch assembly to mount further down the shaft than usual. I believe the gap between my flywheel and engine crankcase is to big. anyone have any other ideas?
lil-bump is offline
Old 10-19-2006, 03:05 PM
Default Collet
It sounds like you have the wrong collet for the flywheel. You should have plenty of freeplay and have to use shims to set the endgap.
Old 10-19-2006, 03:11 PM
rmdhawaii's Avatar
Are you having this problem with an engine you haven't run yet - or did this problem develop over time?
Old 10-19-2006, 03:38 PM
Regional Moderator
daniz24's Avatar
Originally Posted by asw7576
You need a caliper.
I think most people run 1.0 - 1.2 mm (with silver hard spring) for MRX
daniz24 is offline
Old 10-19-2006, 04:44 PM
lil-bump's Avatar
It's been this way since day one. The engine in questioned is a nova mega sx-12. I believe I have incorrect collet for my flywheel. But if I'm not mistaken My Mtx-3 prospec kit did not come with a collet.
lil-bump is offline
Old 05-07-2008, 05:35 PM
BLKNOTCH's Avatar
This was a great read.
BLKNOTCH is offline
Old 05-07-2008, 07:39 PM
MugenDrew's Avatar
Trader Rating: 35 (100%+)
Lil bump are there washers between the front bearing and the Collete? Could you measure the length of the Collete your using from the end that touches the front bearing to the "tip" of the Collete?
MugenDrew is offline
