Old 10-15-2006, 07:01 PM   #1
Default mugen mrx3 centax clutch
hi, guys sorry to showing up now cause im to busy with my work
guys i just bought used mrx3, but got problem with the centax clutch, both bearing in centax clutch were damage and i dont have manual and tool to look the size of the bearing. do you know what type of the bearing and the size?before that thanks for helping me out here.
dotmatrix is offline   Reply With Quote
Old 10-15-2006, 07:03 PM   #2
JFCJ's Avatar
Trader Rating: 31 (100%+)
I've been using HPI 5x10x4mm bearings.
* www.tsrcar.com * John's BSR Racing Tires * Serpent America * BOCA Bearings *
JFCJ is offline   Reply With Quote
Old 10-15-2006, 09:16 PM   #3
is 5X10X4 are the only size bearing inside the centax clutch? it supose have 2 bearing right, is it the same size? how bout flange bearing cause i know that serpent centax clutch using 5X10 bearing and 5X8 flanged bearing.is mugen using the same thing?
Old 10-15-2006, 09:37 PM   #4
Go to the Mugen website and you will find the part list. For sure is not a flanged bearing like the Serpent.
twoo is offline   Reply With Quote
Old 10-15-2006, 09:42 PM   #5
Tire Chunker's Avatar
Trader Rating: 16 (100%+)
part #
Tire Chunker is offline   Reply With Quote
Old 10-16-2006, 06:07 AM   #6
hi twoo and tire chunker.i, did look look at mugen website, but the picture too blury cant see them clearly.how bout the clutch set for mrx4 are they compatible with mrx3? and guys, do know where to buy parts for novamega zx21 part( piston sleeve and the crankshaft need to be replace) on line?thanks
Old 10-16-2006, 06:53 AM   #7
cdelong's Avatar
mugen uses 5x10x4mm (unflanged) bearings inside and outside the clutch bell. I have used rubber shieded shelf bearings from my LHS without issue for most of the year. I believe they are just Duratrax bearings for $6 a pair. Look on towerhobbies.
KYOSHO EVOLVA
35PLUS21
FUTABA 3PKS/KO PROPO
BYRON'S FUEL/TWISTER TIRES
cdelong is offline   Reply With Quote
Old 10-16-2006, 07:08 AM   #8
ok ,thanks cdelong i will buy it today at my LHS
Old 10-19-2006, 02:09 PM   #9
Lil Paul's Avatar
Default Rubber Shielded???
I always stayed away from rubber shielded bearing inside the clutch figuring that with the heat and movement, the bearing would fall apart in a short period of time. Your saying you have not had any problems??? i would like to try that...Any particular brand bearing??? I thought that its a must to use metal shielded bearings in the clutch.
Lil Paul is offline   Reply With Quote
Old 10-19-2006, 04:05 PM   #10
JFCJ's Avatar
Anyone try ceramic bearings in the clutch?
I've got a pair installed, but haven't run a 30 minute main with them yet, so I'm not sure how they'll do...
Mugen MRX & MTX centax clutch & other mugen parts Got the grip R/C Items: For Sale/Trade 3 05-24-2014 03:35 AM
Mugen Centax Clutch Set plus many many Diva R/C Items: For Sale/Trade 3 10-17-2007 08:52 PM
Mugen mtx Centax Clutch supermoto552 Nitro On-Road 7 02-04-2007 03:52 PM
kfactory ntc3 30mm push clutch bell to mugen centax clutch set mugen_kid Nitro On-Road 1 03-04-2003 05:01 PM
Mugen Centax Clutch Set Diva R/C Items: For Sale/Trade 4 02-13-2003 08:00 PM
