Old 10-11-2006, 10:06 AM   #16
duneland's Avatar
Does anyone know of a company that use the SAME type of rubber for front & rear? I know Jaco & twister both use a different type of rubber for front. I would like to make my own decisions on how to set-up my car. They seem to think I shouldn't have any steering. I would rather like to have some .
duneland is offline   Reply With Quote
Old 10-11-2006, 04:54 PM   #17
wallyedmonds's Avatar
no front tire is the same as the rear and KAWAHARA are the best for me then GRP have a nice day oh and heres somthing we do up here 37 rear 35 front or 40 rear 37 front try it you may like it.
wallyedmonds is offline   Reply With Quote
Old 10-11-2006, 06:25 PM   #18
You should try 45 on the left side and 40 on the right.
jake alton is offline   Reply With Quote
Old 10-12-2006, 01:28 AM   #19
M7H
M7H's Avatar
Or the other way around, depends on the track your driving.
Serpent
M7H is offline   Reply With Quote
Old 10-12-2006, 03:22 AM   #20
ATS makes 26mm tires which are the same compound with the rears. I use this combination several times, fronts which are made from rears compound wears a little more, but give higher traction. I normally use same shore tires for front and rear, but with this combination I'm planning to use one step harder for fronts.
deepfree_z is offline   Reply With Quote
Old 10-12-2006, 04:21 AM   #21
ive never seen these tires,ok good stuff.
Old 10-12-2006, 04:23 AM   #22
ya iv seen guys do this and it seemes to work,iv never tried so idono.
Old 10-12-2006, 06:58 AM   #23
duneland's Avatar
I have tried running harder shore rears v.s. front. Works, but it is not quite what I am looking for. Guess I will have to find someone that supplies donuts & mount my own fronts with rear donuts.
Old 10-12-2006, 07:18 AM   #24
SalvadoriRacing's Avatar
Send a message via MSN to SalvadoriRacing Send a message via Skype™ to SalvadoriRacing
KAWAHARA
besides tires they produce the best quality car hopup for kyosho and mugen cars.......not to mention the 1/10 world champino bodyshell...
Salvadori Racing
www.salvadoriracing.com.br
O.S. Engines - KM RACING - CONTACT TYRES - SAVOX - LRP - ARC | Blitz | Titan
SalvadoriRacing is offline   Reply With Quote
Old 10-12-2006, 08:36 PM   #25
hey never thot of that thats if you can get them,it just may work for you,tell us if it works or not id like to know.so i can try it too.
Old 10-21-2006, 03:30 AM   #26
Corse-R's Avatar
Originally Posted by SalvadoriRacing
KAWAHARA
Salvatori:
Regarding the Kawahara foams... I looked the japanese page and found two types of 35's in 1/8 foams.. do you know what's the difference between these two part no.?
ZM-1035
ZM-1035S
Are the one ended in S Multiringed? or what makes them different?
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 10-21-2006, 04:50 AM   #27
GQ
ae_ntc3 is offline   Reply With Quote
Old 10-21-2006, 03:37 PM   #28
Originally Posted by Corse-R
Salvatori:
ZM-1035
ZM-1035S
corse,
the S type is "double layer", don't know what does it mean exactly anyway.......
Salvadori Racing
Old 10-21-2006, 06:00 PM   #29
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Probably like the jacos , dual layer. Two different profiles , one for touching the track , the other for providing a second profile to help adjust tuning.
Its kinda like a progressive spring. You get two profiles in one. The question still remains , is this double rate better than a single. Some say yes and some say no. You have more to worry about when building a double layer profile if your jaco / kawa. With a single you at least know its hit or miss. With a progressive you can get mixed results.
But results are results , try a pair , see if you beat your lap record or improve consistency or some sort of benefit that outweighs using the standard tire.
Artificial-I is offline   Reply With Quote
Old 10-21-2006, 06:56 PM   #30
Trader Rating: 15 (100%+)
Salvatori:
ZM-1035
ZM-1035S
They have some differant offset rims also, I think?
THE DOCTOR is offline   Reply With Quote
foam fk05 chasis and foam tires. Branden Moody R/C Items: For Sale/Trade 34 10-09-2007 12:20 AM
What type of foam material are foam tires made from? pirate Electric On-Road 2 04-20-2007 09:40 PM
Foam Tires, Parma, TRC, JACO, Tire truer, Rubbers tires and much much more! Team Speedy R/C Items: For Sale/Trade 43 12-15-2006 10:38 AM
Foam Tires Jye Rookie Zone 1 04-17-2005 05:47 AM
Jaco Foam Tires & Fast Tires Foam, Brand new. MugenMTX3Kid R/C Items: For Sale/Trade 11 01-03-2004 01:53 PM
