Old 02-21-2003, 11:27 AM   #76
rod_b's Avatar
Send a message via AIM to rod_b
Default Re: Re: To put a O.S Tr .12 nitro engine in a Hpi RS4
Originally posted by NTC3Dvr
So What your telling Me and Everyone else Is you Did not say this " The diameter of the flywheel has nothing to do with the starting method. It has to do with the height of the motor mounts. P/S motor mounts are taller to clear the pull start case. you can install a non-P/S engine on these mounts, with the same flywheel and just use a starter box to start the car " Now My Question Is If the Flywheel Is sitting Above Chassis about 35mm(non PS) How In the Hell Is the Starterbox Going to Reach the Flywheel...
Actually, you should re-read it again. What popracer said was that you can mount a non-p\s engine on p\s mounts and use a p\s flywheel and it will still work. You made the assumption that when he said to mount a non-p\s engine, that you'd be using a non-p\s flywheel.
...and if the Flywheel is Sitting Below the Chassis(PS) the First rock you Hit it kills the Engine Because You said it dont matter that the Flywheel sticks below the Chassis 20mm???
There is no way that the flywheel will sit below the chassis if the mounts match the flywheel. That's the point that was trying to be made.
rod_b is offline   Reply With Quote
Old 02-21-2003, 11:33 AM   #77
popsracer's Avatar
Default Rod_B;
Thank you Rod.
There is ONE Truck that actually has the flywheel slightly below the bottom of the chassis. This is the RC10GT with P/S flywheel and mount. It is fine until you snag a board or pipe or slap a landing, then the engine is killed by the flywheel touching.
popsracer is offline   Reply With Quote
Old 02-21-2003, 12:16 PM   #78
Send a message via ICQ to NTC3Dvr
Yes this Is the Way I Had read it "You made the assumption that when he said to mount a non-p\s engine, that you'd be using a non-p\s flywheel."....... Yes I do Agree With This "There is no way that the flywheel will sit below the chassis if the mounts match the flywheel. That's the point that was trying to be made."
The way I understood It was it wouldnt Matter How it was Installed mixed matched. Sorry For any Misunderstanding I may have had with the post.
NTC3Dvr is offline   Reply With Quote
Old 02-21-2003, 08:47 PM   #79
Dan
Dan's Avatar
Trader Rating: 48 (100%+)
Okaaaaay...lets get back to the original topic...
Dan is offline   Reply With Quote
LOOKING TO BUY RC NITRO TRUCKS, CARS, BUGGYS, ELECTRIC OR NITRO CASH IN HAND jd267 R/C Items: Wanted to Buy 26 09-06-2008 12:25 PM
WTTF: mini electric or nitro (nitro perfered) and also looking at all nitro deals.... xxx-ntad2 racer R/C Items: Wanted to Buy 3 04-25-2007 07:53 PM
XM Ready radio and Nitro Buggy to trade for Nitro Rustler or Jato RTR NewNitro R/C Items: For Sale/Trade 1 03-17-2007 11:38 PM
FS/FT Tmaxx, Nitro Rustler, Nitro RS4 Racer, Nitro RS4 RTR, Losi XXXNT RTR ChrisR40 R/C Items: For Sale/Trade 24 03-20-2006 03:47 PM
FOR SALE:Nitro 4tec, Hopped Nitro Rustler, Parts lot, Picco .12 engine, plus more!!!! feel my impact R/C Items: For Sale/Trade 0 08-05-2002 10:41 PM
