Old 09-21-2006, 08:04 PM   #1
Default How long can you run a Nitro Motor
I figure my question is pretty simple. I'd like to know how long you can run a Nitro Motor before you're in danger of destroying it. To clarify, I don't mean how many times can you run it before it's going to die.
The reason I ask is because for the racers appreciation day at the end of the season, we've set up an endurance race and I'd like to make sure I'll be able to run the whole race without screwing over my motor. Any assistance in this matter will be greatly appreciated.
slider5634 is offline   Reply With Quote
Old 09-21-2006, 08:13 PM   #2
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Welcome to the forums Slider! There are many variables that have an effect on an engines lifespan. Generally you can get upto 7 gallons without replacing anything. However, under race conditions it's important to replace the conrod after a gallon of fuel to prevent future damage. The sleeve can be "pinched" or resized to be ran for an additional 3 gallons.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 09-21-2006, 08:18 PM   #3
Okay. Thanks for the info, but I already was aware of those logistics. What I need to know is how long can I run the motor safely before it overheats or destroys itself. 40 minutes? an hour? Anybody?
Old 09-21-2006, 08:25 PM   #4
wallyedmonds's Avatar
umm well hmmmm im not the one to ask but my novarossis last a long time one of them has 3 one hour mains on it but my other motors well they blowed up real good like. mostly tho 2 gal fuel then they start to get get old thats up here in the toronto area we run them to the max very fast and tight racing.
wallyedmonds is offline   Reply With Quote
Old 09-21-2006, 08:29 PM   #5
Trader Rating: 15 (100%+)
As long as the air filter is clean and you are not overheating it you could run a gallon of fuel through it.
THE DOCTOR is offline   Reply With Quote
Old 09-21-2006, 08:30 PM   #6
That's helpful. We're planning on running a 40 minute endurance race and I'd just like to make sure my motor's going to hold up to the beating. Normally our races are only 4 minutes races and the longest I've ever run the motor is 11 minutes -- which was one tank of fuel.
Old 09-21-2006, 08:35 PM   #7
11 min on one tank of fuel wow we only get just over 5 min and ya you can go for an hour thats about the time of the batts in the car then they dump.
Old 09-21-2006, 08:38 PM   #8
TrickPonYracing's Avatar
i have run many 30 min mains and some 60 min main with no problems at race speed and temps. how you run your motors and how the car works,clutch set up both motor and two speed,cooling holes,track and amb. temp all play in.
www.TrickPonYracing.Com
FORGASS President 2006/2007.2007/2008. 2008/2009
V/P Charlotte R/C Raceway
Team Anchor for .. ReD CuP RacinG ..
Team Driver for TORO Fuel
[email protected]
TrickPonYracing is offline   Reply With Quote
Old 09-21-2006, 08:47 PM   #9
Well, I've got the stock AE motor that came in my TC3 running. I've got it leaned out, but not too much obviously. It's running on a three shoe clutch with a two speed setup for torque -- the track has only one small straight away on it. On a warm day -- about 75f -- it runs about 230. Considering it's fall here and temps will be in the lower 60's I'll bet it'll run slightly cooler.
Old 09-21-2006, 09:36 PM   #10
devious17's Avatar
If your engine is within the heat range coupled with clean filter it will last a long time provided the con-rod is periodically replaced and internals cleaned (rust)
My buggy engine, RB S7, lasted me a good 4 gallon with a change of con-rod between gallon but the crank pin isnt hardened and that ended it's life
Audio,Video, Disco
devious17 is offline   Reply With Quote
Old 09-22-2006, 06:59 AM   #11
MugenDrew's Avatar
Trader Rating: 30 (100%+)
Talking
Did you take the restrictor out of the carb? If not and you choose to remove it you MUST retune the engine. More air needs more fuel which makes more power which will drop your lap times and say good by to 11 min. of run time. If I remember, they still got 6-7 mins of run time with much improved power. Whats up hot dog man!
Mugen Seiki Racing Desoto Racing Race AKA Byron Original Fuels Arrowmax Sanwa RC America
MugenDrew is offline   Reply With Quote
Old 09-22-2006, 07:48 AM   #12
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
They run till they dont. There has been I believe 24 hour all night events where people ran there motor for 24 hours. Might have been 12. Doesnt matter a nitro motor will go and go. Just as long as the way you have it tuned doesnt allow it to go higher and higher temp and the amount of time needed doesnt surpass the amount of gas that can be run through it.
Artificial-I is offline   Reply With Quote
Old 09-22-2006, 11:25 PM   #13
GABOS's Avatar
Send a message via AIM to GABOS
I am running with an O.S TZ 5 P for about 1 year without changing anything, qualys and 40 minutes final every 15 days and still run good finishing second places
GABOS is offline   Reply With Quote
Old 09-22-2006, 11:30 PM   #14
The OX's Avatar
A club here in Sydney, Australia runs a 1/10 scale Le Mans race once a year. They run the cars non-stop for 2 hours and 24 minutes.
From memory they have never had an engine blow in the 3 years it has been run. (20 cars each year one the track ant the same time)
Their website is www.pdnracing.org.au.
Cheers
The OX
The OX is offline   Reply With Quote
Old 09-24-2006, 02:05 PM   #15
Ive ran 8 hour endurance races before. No problem the engines are bullet proof until something lets go. Have fun and no worries just have backups.
jake alton is offline   Reply With Quote
South Shore Hobbies Nitro Off-road, Long Island MikeWz Track Locator Forum 21 06-30-2007 07:33 PM
wanting to get back into nitro after a long time out shawn17 Electric Off-Road 2 05-01-2007 07:39 PM
Nitro racing Long Island NY Maxx Racing Forum 11 07-30-2005 07:22 AM
how long will a 12 turn motor last witha 2400mah batt silent ghost Electric On-Road 3 04-06-2003 07:57 AM
Long Format Nitro Racing TimPotter Nitro On-Road 11 11-11-2002 05:27 PM
