Old 09-20-2006, 04:59 PM   #1
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Default Spring rates for Picco Integra??
Any body know the spring rates for the picco integra springs?
thanks
Old 09-20-2006, 05:19 PM   #2
color coded spring rates??
dynamicracing is offline   Reply With Quote
Old 09-20-2006, 05:41 PM   #3
Super Moderator
Marcos.J's Avatar
yes they are color coded but i need the lb rate
Old 09-20-2006, 10:17 PM   #4
rjr
Does this help?
http://www.marcar.org/springs.htm
rjr is offline   Reply With Quote
Old 09-21-2006, 10:30 AM   #5
Super Moderator
Marcos.J's Avatar
Originally Posted by rjr
well i need the weight of the springs. 20lbs,25lbs,30lbs etc???
Old 09-25-2006, 11:07 AM   #6
garen's Avatar
marcos- you might try getting in touch with the old paris racing drivers- kimbrow, rich browne, robert ronas, or even jim hottinger.
if you need tires for either 1/10th or 1/8th integra, send me a pm
bpengines-usa.com fioroni-usa.com motonica-usa.com
Airtronics Avid RC Byron Fuels VOX Engines
VMR Tires - available at http://motonica.ipower.com/store
garen is offline   Reply With Quote
Old 09-25-2006, 11:13 AM   #7
Super Moderator
Marcos.J's Avatar
i dont have the integra , i just need the rating,
I guess you dont work for GS anymore
Old 09-25-2006, 05:26 PM   #8
Marcos.J - If the info on the MARCAR website isn't what you need. Try calling or emailing Sal DiFazio or Robert Ronas from said website (www.marcar.org). If they don't have that info then probably no one does.
darkangel is offline   Reply With Quote
Old 09-26-2006, 12:04 PM   #9
fraz's Avatar
Send a message via AIM to fraz
Default Paris Picco Spring Chart
Marcos.J,
IMO a specific pound rating that you are asking for is not really correct. Unless all springs that you are trying to compare to have been tested on the same test platform, the numbers will not correlate to the same pound scale. Additionally, if any of the tested springs are not a linear but are progressive, the numbers get skewed even further. What you should be looking at is an entire set of springs that have been rated in the same batch using the identical method. In that case, I have just what you need (man I'm a data pack rat). Attached is the most comprehensive testing done on all of the Picco springs for the Integra and Compact lines of cars compiled from the now defunct Paris Racing. You will not find any better data than this. If you need any help on identifying any of these, let me know because I own a full set!!
fraz is offline   Reply With Quote
Old 09-26-2006, 12:08 PM   #10
Super Moderator
Marcos.J's Avatar
Originally Posted by fraz
Marcos.J,
thanks so much!
Old 09-28-2006, 06:58 PM   #11
mblgjr's Avatar
Trader Rating: 86 (100%+)
Is the Integra still available in the U.S.? Is it still in production? If so, who is the distributor?
I have TWO brand new kits, NIB, tires, as well as a box full of repair parts to cover both cars.
Any help would be greatly appreciated. If they are so far out of date, I'm probably better off building them to play with rather than to start racing again with them.
mblgjr is offline   Reply With Quote
Old 09-29-2006, 12:34 PM   #12
fraz's Avatar
The Integra kits are dated. It was replaced by the Picco Speed and then Alberto Picco sold the tooling and the rights to http://www.picco-deutschland.de/ Werks Racing was the sole importer in the US butnot any more. I do not believe anybody currently imports these cars in the US.
SPRING RATES and set up help HAKYLIKESRDAD Electric Off-Road 22 05-05-2008 01:07 PM
Help..... Spring Rates WopArse Oval, Larger Scales and More 1 03-19-2007 01:54 AM
Spring Rates ford_racing Electric On-Road 3 01-27-2006 09:42 PM
Spring Rates omalley Electric On-Road 1 04-21-2003 02:39 PM
HPI spring rates??? DJ_GenR8 Electric On-Road 3 05-29-2002 04:54 PM
