Old 09-17-2006, 10:58 AM   #1
Default my car handles like its made out of fruit!
hey guys, the title saids it all
as i dont have a chassis tune up system i do everything by guessing
is it time for a chassis tune up system?? and if so which one??
thanks in advnace
boss
bigboss is offline   Reply With Quote
Old 09-17-2006, 12:22 PM   #2
asw7576's Avatar
Buy Hudy Exclusive Set Up System or Proffesional Set Up System ( complete with suitcase, board and tweak station )
Team SpeedMind also produce Set Up system and it looks fine to me.
Old 09-17-2006, 02:18 PM   #3
Send a message via MSN to Adim_X
whats your car doing? Are you driving on the street in front of your house, a dusty parking lot, or a prepared track? A set up system should help, but a simple camber guage or eyeballing it could at least make the car driveable.
Adim_X is offline   Reply With Quote
Old 09-17-2006, 08:53 PM   #4
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
and what kind of car?........
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 09-18-2006, 01:04 AM   #5
its a mugen mtx4, never been set up properly
when it brakes it starts to slide to one side and eventually ends up doin a 180
and wen i steeer it just has massive oversteer problem
time to save up for a hudy system
and im running it in a school just b4 i take it to a track,
but not goin to take it to a track till its sorted
Old 09-18-2006, 01:59 AM   #6
Pattojnr's Avatar
Trader Rating: 19 (100%+)
if you are running a front oneway, when braking it is quite normal for the car to spin out, if you use too much brake. think of it as a hand brake on a normal car. the only way to solve this is to either run a solid front axle or run a diff in the front. or back the brake off and be gentle when applying. as far as the car oversteering, many things affect that. too harder tires, not enough front droop(on power oversteer) not enough rear droop(off power steering), springs too hard at the rear, too much or not enough camber, roll center too high, roll bars too stiff. go back to the manual and check the basic setup that is provided in the manual. then adjust one thing at a time, and test. as far as tools go, a camber guage is vital, and ride hieght guage. these are the basic tools required. camber guage is used for rear toe as well(stand the car on its rear and use the guage on a flat surface) ride hieght guage can be used for droop as well. you can mesure droop with the tires on(lift the front of the car up while pressing on the front tires, this difference in ride hieght and the upper most travel is your droop (upstop) unless you want to spend the money on a setup station, then id wait a bit, to gain some experience and knowledge on how to setup a tourer. information is plentifull on this forum. what i would suggest, is to go to the track where you will run, ask the guys with the same cars what they are running in terms of springs and camber and tire selection. then just hit the track !! you will find the setup very different on the track, so id go straight to it to get it setup. hope this helps.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 09-18-2006, 07:15 AM   #7
nitrodude's Avatar
You're never going to get the car sorted on a dusty parking lot, to get sorted you have to take to the track where you're going to run it. Its like setting up F1 car on a dirt road.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 09-18-2006, 10:01 AM   #8
thanks for the advice guys
would abs help the spinning out??
Old 09-18-2006, 10:18 AM   #9
Trader Rating: 15 (100%+)
What tires are you running? Is the rear wing on the car?
THE DOCTOR is offline   Reply With Quote
Old 09-18-2006, 10:26 AM   #10
I dont think abs is your answer. With a front oneway, the brakes should only be set up to slow the car, you will never be able to go full wood on the brakes with a front oneway.
Old 09-18-2006, 10:26 AM   #11
foam tyres, 40shore on front and back
just tested it with abs, late breaking but not much spin out
too bad i didnt have my brakes on full and smacked it into a wall
Old 09-18-2006, 07:17 PM   #12
mugenb46's Avatar
bigboss
like they all said the hudy set up will help you get the camber angles and toe set and caster and width. it has it all. as far as what you are driving on other than a track you will never stop that. if you are on a prepared track and you still have that problem, you can go to a thicker diff fluid in the rear this will help the rear diff from unloading and causing it to spin, i whent from 10 thous to 60 thos. it took care of that for me. hope this helps
mugenb46 is offline   Reply With Quote
What do you want to see made? eds24 Micro and Mini Scales 25 01-07-2008 01:34 PM
Traxxas 4-Tec vs Tamiya tt-01r which handles better out of box? mhx Electric On-Road 12 06-01-2007 10:01 PM
WR TC3 F/S * 5 ever made! EDWARD2003 R/C Items: For Sale/Trade 3 10-24-2005 07:51 PM
KYOSHO FW-O4 nitro*handles like a dream heyman R/C Items: For Sale/Trade 6 08-29-2005 10:25 PM
WTB Colored handles for EX1 Mars Radio K1WEY R/C Items: For Sale/Trade 0 06-19-2004 08:00 AM
