Old 09-09-2006, 10:24 PM   #1
Default explain gearing
Can some one please explain gearing to me, I got a used mtx-3 prospec and it came with a bunch of gears that I dont know how to use. correct to if im wrong running .8 means that you should have no more then a 6tooth gap? my current gearing is 20/28 and 60/53 will this work or is this way off all the gears I have except for the default pinions and Im trying to make this work with out breaking anything. I was also wondering how come the default gears are so different then the serpent 710
rcjayy is offline   Reply With Quote
Old 09-10-2006, 01:50 PM   #2
Send a message via AIM to apollo
if you add up the total number of teeth on the first gear (pinion and spur) it should also be the same as the total 2nd gear
example: my rs4
1st: 19t+43t=62t
2nd: 23t+39t=62t
get it?
apollo is offline   Reply With Quote
Old 09-10-2006, 03:33 PM   #3
budachi's Avatar
Actually you can mix and match pinions and spurs however you like on the MTX-3 , be it the 0.8 or 1.0 module. It's true that some cars need to be geared in certain combinations , like the RS4 3 but most "track" cars have pinions that retain the same overall diameter despite the number of teeth , so you can gear them any which way.
As to why the 710 and other cars have different teeth pinions and spurs , that's just one part of the equation. When your gearing your looking at the Final Drive Ratio , cars have different internal ratios so you can have different pinions and spurs between cars but still arrive at the same FDR.
budachi is offline   Reply With Quote
Old 09-10-2006, 04:01 PM   #4
thanks for the reply, I think im getting it now. since I have a bunch of gears I should be able to do something like 20/28 and 53/60 and be OK? what is the thing about the 6 tooth max?
thanks again
Old 09-10-2006, 11:57 PM   #5
nitrodude's Avatar
The thing about the 6 tooth maximum is that most of the times the engine will not be able to pull such a big split. In other words, when the tranny shifts into 2nd gear the engine will bog down, and because of lack of power it will stop accelerating.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 09-12-2006, 07:47 AM   #6
with these new powerful .12's this should no longer be a problem right?
Old 09-12-2006, 08:29 AM   #7
Pattojnr's Avatar
Trader Rating: 19 (100%+)
right ?
they just strip gears now! lol
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 09-12-2006, 08:52 AM   #8
trumpster1's Avatar
I'm running the new Orion CRF Wasp .12 and I had accidently matched a 5 tooth spread on first and 6 tooth spread on 2nd and....oops!! spur gear was gone! Don't mix gear spread numbers, make sure it stays consistent or you will be replacing gears about every 5 minutes, if that.
Nathan
Spektrum DX3R
Traxxas 2wd Slash
Ex-One Eighth Racers of Toledo member :( no mo money
trumpster1 is offline   Reply With Quote
Old 09-12-2006, 11:43 AM   #9
Rapid Roy's Avatar
You need to ask this question in the MTX-3 thread because the answers you have gotten so far may not be correct. First, if your car came with 0.8 pitch gears only use those to run the car. The 0.8 gear pitch is more efficient and will make your car accelerate faster then the standard pitch. If you choose the standard pitch, use ONLY standard pitch pinions and spur gears. Next, I beleive that the Mugen 0.8 pinions are actually variable pitch. The outside diameter of the gear for all the different pinions are the same. That way you can use any combination of 1st gear pinion/spur with any 2nd gear pinion/spur gear. You need to confirm this in the Mugen thread though.
Rapid Roy is offline   Reply With Quote
Old 09-12-2006, 01:13 PM   #10
quietstorm76's Avatar
He's correct. You can use any combination of gearing you want as long as it is within the same pitch. The days of a certain "tooth split" is gone.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 09-12-2006, 02:10 PM   #11
budachi's Avatar
Just to make it clearer in my first reply , I meant that you can mix and match pinions and spurs for 0.8 and 1.0 however you like within their respective module/pitch. The parts list for your car will list all the pinions and spurs you can use.
And "tooth split" is not gone , some cars still need to be geared specifically , mostly the RTR's , but yeah not likely to be seen on a "race" car nowadays. What your hearing about this so called "6 tooth gap" is probably someone trying to tell you not to gear too wide apart between first and second , as someone else mentioned on this thread. And even with the power of .12 nowadays , under or over gearing will still net you a sick engine. Only way to gear a car is ... correctly?
As far as gearing goes , just run whatever is optimal for your track and engine. If there are some people that run the same car ... ask em! As long as the engine doesn't blow up and it goes like a rocket , your all set.
Here's a link for you too regarding your question about gear/ratios.
http://www.radiocontrolzone.com/cars/fastmath.asp
All the best!
Old 09-12-2006, 06:18 PM   #12
thanks, you guys are awesome and im getting a better understanding now, I posted this in the mugen mtx 3 thread and I didnt get many replies (I guess everyone has a mtx 4 now ) the last thing I need to figure out is there a way to look at the gears and tell which ones are 1.0 and .8 because the guy that sold me the car gave me a mixture of both and I dont want to mix them or I will really have problems.
Old 09-12-2006, 06:36 PM   #13
How do u guys determine what gear ratios is fastest for a particular track? Do u try the stock setting first, then time the laps, then change different gear ratios and time the laps? Or u remove the second speed spur and pinion, try different first speed spur and pinion combo and time the laps to find out what is the fastest first speed gear combo, then try second speed gear combo likewise?
raceblast is offline   Reply With Quote
Old 09-12-2006, 07:04 PM   #14
Tire Chunker's Avatar
Trader Rating: 16 (100%+)
You will need to count the teeth, I then took a xacto marked last number of pinion v for 25, ll 22 ect.........
I have attached a link that should help you figure out which gears are which.
I run a prospec .8 and a plain mtx-3 for my back up 1.0 it was a pain until I marked the pinions.
http://www.mugenseiki.com/mtx3-gearratio08m.pdf
Tire Chunker is offline   Reply With Quote
Old 09-12-2006, 07:25 PM   #15
thanks, OK - from what I understand by counting the teeth what ever chart it falls under (1.0 or .8) thats what pitch it is?
Can somebody please explain this to me? sho .21 R/C Racers 4 Christ 222 11-18-2011 03:06 PM
PLZ explain me this! hrnts69 Radio and Electronics 0 02-17-2008 10:45 AM
can someone explain gearing to me!? nc racer Electric On-Road 13 08-24-2007 06:37 AM
Can someone explain... squarehead Onroad Nitro Engine Zone 3 02-11-2005 06:45 PM
Is it possible to even explain to someone why you need more than one car? LosiFromHell986 Chat Lounge 32 05-17-2004 05:15 PM
